robus Posted September 9, 2022 Share Posted September 9, 2022 Got stuck on trying to get the Blackboard to load and go in my homebrew Atari emulator. This code gets stuck in an infinite loop because LDA (ADRESS),Y is returning 0 (and DMASK is also returning 0) GETPLT: JSR CONVRT LDA (ADRESS),Y AND DMASK SHIFTD: LSR SHFAMT BCS SHIFT1 LSR A BPL SHIFTD During my run: 2022-09-09 13:04:19.504201-0500 SimAtari[16036:6342964] 0xF5A5 LDA (0x3C42),y -> 0x0 2022-09-09 13:04:21.770797-0500 SimAtari[16036:6342964] 0xF5A7 AND 0x2A0 -> 0x0 2022-09-09 13:10:01.155249-0500 SimAtari[16036:6342964] 0xF5AA LSR 0x6F -> 0x0 2022-09-09 13:10:14.366960-0500 SimAtari[16036:6342964] 0xF5AC BCS 0x3 (C = 0) 2022-09-09 13:10:15.976096-0500 SimAtari[16036:6342964] 0xF5AE LSR -> 0x0 2022-09-09 13:10:16.591118-0500 SimAtari[16036:6342964] 0xF5AF BPL 0xFFFFFFF9 (N = 0) So obviously something's gone wrong somewhere in the setup. All the init code seems happy along the way though. Just wondering if anyone has an insight into this area? Quote Link to comment Share on other sites More sharing options...
robus Posted September 9, 2022 Author Share Posted September 9, 2022 (edited) Some more exploration is revealing that the issue seems to be in CONVRT: The DMASKT index referred to here "TMPLBT IS NOW THE INDEX INTO DMASKTB" in the source is 0, which is $00 in the mask array: DMASKT: .BYTE $00,$FF,$F0,$0F .BYTE $C0,$30,$0C,$03 So it all falls apart. I guess I'm confused about what is supposed to happen when ROWCRS is 0. This logic all assumes that there is something other than 0 to work with? LDA ROWCRS ;PUT 10*ROWCRS INTO MLTTMP STA MLTTMP LDA #0 STA MLTTMP+1 LDA MLTTMP ;QUICK X8 ASL A ROL MLTTMP+1 STA HOLD1 ;(SAVE 2X VALUE) LDY MLTTMP+1 STY HOLD2 ASL A ROL MLTTMP+1 ASL A ROL MLTTMP+1 CLC Mapping the ATARI says it can be 0 though, so how does it avoid getting into the infinite loop I have in the first post? Quote ROWCRSCurrent graphics or text screen cursor row, value ranging from zero to 191 ($BF) depending on the current GRAPHICS mode (maximum number of rows, minus one). This location, together with location 85 below, defines the cursor location for the next element to be read/written to the screen. Rows run horizontally, left to right across the TV screen. Row zero is the topmost line; row 192 is the maximum value for the bottom-most line. Edited September 9, 2022 by robus More clarification Quote Link to comment Share on other sites More sharing options...
robus Posted September 9, 2022 Author Share Posted September 9, 2022 Oh and DINDEX is 0 because we're in Mode 2: ; ; ANTIC CODE FROM INTERNAL MODE CONVERSION TABLE ; ; INTERNAL ANTIC CODE DESCRIPTION ; 0 2 40X2X8 CHARACTERS So it's zeros everywhere. Quote Link to comment Share on other sites More sharing options...
dmsc Posted September 10, 2022 Share Posted September 10, 2022 i! 6 hours ago, robus said: Got stuck on trying to get the Blackboard to load and go in my homebrew Atari emulator. This code gets stuck in an infinite loop because LDA (ADRESS),Y is returning 0 (and DMASK is also returning 0) GETPLT: JSR CONVRT LDA (ADRESS),Y AND DMASK SHIFTD: LSR SHFAMT BCS SHIFT1 LSR A BPL SHIFTD During my run: 2022-09-09 13:04:19.504201-0500 SimAtari[16036:6342964] 0xF5A5 LDA (0x3C42),y -> 0x0 2022-09-09 13:04:21.770797-0500 SimAtari[16036:6342964] 0xF5A7 AND 0x2A0 -> 0x0 2022-09-09 13:10:01.155249-0500 SimAtari[16036:6342964] 0xF5AA LSR 0x6F -> 0x0 2022-09-09 13:10:14.366960-0500 SimAtari[16036:6342964] 0xF5AC BCS 0x3 (C = 0) 2022-09-09 13:10:15.976096-0500 SimAtari[16036:6342964] 0xF5AE LSR -> 0x0 2022-09-09 13:10:16.591118-0500 SimAtari[16036:6342964] 0xF5AF BPL 0xFFFFFFF9 (N = 0) It is not possible to have a 0 in SHFAMT in the real Atari, it is setup at the end of CCA: 00F5F4 1 BE 9D EE LDX TRSC,Y 00F5F7 1 BD 04 FB LDA TMSK,X 00F5FA 1 25 55 AND COLCRS ;and in low cursor column 00F5FC 1 65 66 ADC OPNTMP 00F5FE 1 A8 TAY 00F5FF 1 B9 AC EE LDA TDSM-1,Y ;display mask 00F602 1 8D A0 02 STA DMASK ;display mask 00F605 1 85 6F STA SHFAMT 00F607 1 A0 00 LDY #0 With DINDEX (at Y) zero, A is 0 (from TRSC and TMSK), the and gives 0 and OPNTMP is #1 (initialized at start), so Y = 1, and the table reads $FF, writen to SHFAMT. So, at the first iteration, the LSR sets carry and the BCS skips the loop. Have Fun! 1 Quote Link to comment Share on other sites More sharing options...
phaeron Posted September 10, 2022 Share Posted September 10, 2022 7 hours ago, robus said: 2022-09-09 13:04:19.504201-0500 SimAtari[16036:6342964] 0xF5A5 LDA (0x3C42),y -> 0x0 Check your CPU emulation, this disassembly is bogus -- should be LDA (zp),Y, not LDA (abs),Y. Quote Link to comment Share on other sites More sharing options...
robus Posted September 10, 2022 Author Share Posted September 10, 2022 Thanks, I’ll check into all those. I may have messed up my copy/paste/editing on the questionable LDA line, because it would be weird to get this far with a bug like that, but not impossible Quote Link to comment Share on other sites More sharing options...
robus Posted September 10, 2022 Author Share Posted September 10, 2022 19 hours ago, dmsc said: It is not possible to have a 0 in SHFAMT in the real Atari, it is setup at the end of CCA: I'm looking at my OS source listing and I'm not finding this bit of code? TRSC, for example, is not mentioned. I'm using this as a source reference LIST X ; THIS IS THE MODIFIED SEPTEMBER ATARI 400/800 COMPUTER OPERATING ; SYSTEM LISTING. MODIFIED TO ASSEMBLE ON THE MICROTEC CROSS ; ASSEMBLER. ; THIS VERSION IS THE ONE WHICH WAS BURNED INTO ROM. ; THERE IS A RESIDUAL PIECE OF CODE WHICH IS FOR LNBUG. THIS ; IS AT LOCATION $9000 WHICH IS NOT IN ROM. ; ; THIS IS THE REVISION B EPROM VERSION .PAGE ; ; ; ; ; ; PALFLG = 0 ; COLLEEN OPERATING SYSTEM EQUATE FILE Which is tracking the NTSC Rev B OS ROM I've loaded into my Sim. Quote Link to comment Share on other sites More sharing options...
robus Posted September 10, 2022 Author Share Posted September 10, 2022 19 hours ago, phaeron said: Check your CPU emulation, this disassembly is bogus -- should be LDA (zp),Y, not LDA (abs),Y. Ah the address I was showing is the contents of the zp address with the Y added. Sorry for the confusion. In my disassembly I wanted to see what the calculated address was for easy peeking - but I should print out the input as well as the output. Quote Link to comment Share on other sites More sharing options...
dmsc Posted September 11, 2022 Share Posted September 11, 2022 (edited) Hi! 5 hours ago, robus said: I'm looking at my OS source listing and I'm not finding this bit of code? TRSC, for example, is not mentioned. I'm using this as a source reference LIST X ; THIS IS THE MODIFIED SEPTEMBER ATARI 400/800 COMPUTER OPERATING ; SYSTEM LISTING. MODIFIED TO ASSEMBLE ON THE MICROTEC CROSS ; ASSEMBLER. ; THIS VERSION IS THE ONE WHICH WAS BURNED INTO ROM. ; THERE IS A RESIDUAL PIECE OF CODE WHICH IS FOR LNBUG. THIS ; IS AT LOCATION $9000 WHICH IS NOT IN ROM. ; ; THIS IS THE REVISION B EPROM VERSION .PAGE ; ; ; ; ; ; PALFLG = 0 ; COLLEEN OPERATING SYSTEM EQUATE FILE Which is tracking the NTSC Rev B OS ROM I've loaded into my Sim. You can download an archive of all (reconstructed) OS sources from https://seriouscomputerist.atariverse.com/pages/resource/resource.source.htm , by Tomasz Krasuski. I quoted from version BB000001 Rev. 2, as that is what came with my 800XL. In OSB the code is different, but the result is the same, it is setup at CONVRT, at the end also: 00F988 1 BC A5 FE CONVR2: LDY DIV2TB,X ;NOW DIVIDE HCRSR TO ACCOUNT FOR PARTIAL BYTES 00F98B 1 A5 55 LDA COLCRS 00F98D 1 A2 07 LDX #7 ;* TRICKY * 00F98F 1 88 CONVR3: DEY 00F990 1 30 0A BMI CONVR4 00F992 1 CA DEX 00F993 1 46 56 LSR COLCRS+1 00F995 1 6A ROR A 00F996 1 6E A1 02 ROR TMPLBT ;SAVE LOW BITS FOR MASK 00F999 1 4C 8F F9 JMP CONVR3 00F99C 1 C8 CONVR4: INY ;SO Y IS ZERO UPON RETURN FROM THIS ROUTINE 00F99D 1 18 CLC 00F99E 1 65 66 ADC MLTTMP ;ADD SHIFTED COLCRS TO MLTTMP 00F9A0 1 85 66 STA MLTTMP 00F9A2 1 90 02 BCC CONVR5 00F9A4 1 E6 67 INC MLTTMP+1 00F9A6 1 38 CONVR5: SEC ;* TRICKY * 00F9A7 1 6E A1 02 CONVR6: ROR TMPLBT ;SLIDE A "1" UP AGAINST LOW BITS (CONTINUE TILL X=-1) 00F9AA 1 18 CLC 00F9AB 1 CA DEX ;AND FINISH SHIFT SO LOW BITS ARE 00F9AC 1 10 F9 BPL CONVR6 ;RIGHT JUSTIFIED. 00F9AE 1 AE A1 02 LDX TMPLBT ;TMPLBT IS NOW THE INDEX INTO DMASKTB 00F9B1 1 A5 66 LDA MLTTMP ;PREPARE FOR RETURN 00F9B3 1 18 CLC 00F9B4 1 65 64 ADC ADRESS 00F9B6 1 85 64 STA ADRESS 00F9B8 1 85 5E STA OLDADR ;REMEMBER THIS ADDRESS FOR CURSOR 00F9BA 1 A5 67 LDA MLTTMP+1 00F9BC 1 65 65 ADC ADRESS+1 00F9BE 1 85 65 STA ADRESS+1 00F9C0 1 85 5F STA OLDADR+1 00F9C2 1 BD B1 FE LDA DMASKT,X 00F9C5 1 8D A0 02 STA DMASK 00F9C8 1 85 6F STA SHFAMT 00F9CA 1 68 PLA 00F9CB 1 85 56 STA COLCRS+1 00F9CD 1 68 PLA 00F9CE 1 85 55 STA COLCRS 00F9D0 1 68 PLA 00F9D1 1 85 54 STA ROWCRS 00F9D3 1 60 RTS Here, SHFAMT is setup with $FF from DMASKT, as at $F9C2 X is 1 when DINDEX is 0. The code is more complicated, but you can see that at CONVR6 the ROR shifts a 1 into TMPLBT (from the SEC just above), so TMPLBT is always > 0, in the case of DINDEX=0, the loop is executed 7 times, so at the end TMPLBT is 1. Have Fun! Edited September 11, 2022 by dmsc 1 Quote Link to comment Share on other sites More sharing options...
robus Posted September 11, 2022 Author Share Posted September 11, 2022 2 hours ago, dmsc said: The code is more complicated, but you can see that at CONVR6 the ROR shifts a 1 into TMPLBT (from the SEC just above), so TMPLBT is always > 0, in the case of DINDEX=0, the loop is executed 7 times, so at the end TMPLBT is 1. Thanks, I see that. Going to step through my code to see what happens there. Might have a bug in my ROR logic. I’ll check my tests for it first though! Quote Link to comment Share on other sites More sharing options...
robus Posted September 11, 2022 Author Share Posted September 11, 2022 (edited) And I had a bug in my ROR/ROL logic. I was feeding the Carry flag with the result of the rotate before feeding the current Carry flag into the value. C -> [76543210] -> C Isn't the most clear description of the logic (one could imagine the Carry flag is being used to ferry the exiting bit around to the other end, as I did ) Edited September 11, 2022 by robus 1 Quote Link to comment Share on other sites More sharing options...
robus Posted September 11, 2022 Author Share Posted September 11, 2022 (edited) With that bug eliminated, I'm now back to the more interesting work of getting POKEY to handle some disk IO as my emulator attempts a disk boot (which is of course going to fail, but isn't yet as it's stuck in transmission waiting for some kind of send status response ). Edited September 11, 2022 by robus 1 Quote Link to comment Share on other sites More sharing options...
