Igor Posted September 10, 2022 Share Posted September 10, 2022 Hi All! We’re super happy to announce our new online shop is now live! All of the Atari Gamer items are now sold on K-Retro 😻 We have a 20% off sale on our items to celebrate! 🎉🥳👏 We're also selling BennVenn IPS LCD kits, capacitor kits, MOSFET and zener replacements, cart readers/rippers and programmers. Many replacement parts for the Atari Lynx. Home-brew games too. Check it out! 5 2 Quote Link to comment Share on other sites More sharing options...
xhul Posted February 9, 2023 Share Posted February 9, 2023 (edited) Hello there. I may have a question regarding the USB power kit. I've read that it's a bad idea to have something plugged in both the original power port and the micro USB port, which makes sense. But what about using just the the original power port? In other words, can the soldering of the micro USB port alone compromise the original power circuit? Thanks in advance. Great shop, keep up the good work =] Edited February 9, 2023 by xhul 1 Quote Link to comment Share on other sites More sharing options...
Igor Posted February 10, 2023 Author Share Posted February 10, 2023 9 hours ago, xhul said: Hello there. I may have a question regarding the USB power kit. I've read that it's a bad idea to have something plugged in both the original power port and the micro USB port, which makes sense. But what about using just the the original power port? In other words, can the soldering of the micro USB port alone compromise the original power circuit? Thanks in advance. Great shop, keep up the good work =] You should not have power plugged into both that's true. The USB socket is soldered in past the power circuit so should not have an effect on the original power socket, so you can use it just fine, as long as you don't plug anything into both. Also you should not have batteries and USB plugged in at the same time. 1 1 Quote Link to comment Share on other sites More sharing options...
xhul Posted February 10, 2023 Share Posted February 10, 2023 5 hours ago, Igor said: You should not have power plugged into both that's true. The USB socket is soldered in past the power circuit so should not have an effect on the original power socket, so you can use it just fine, as long as you don't plug anything into both. Also you should not have batteries and USB plugged in at the same time. Thanks a lot for the reply =] So that's cool that the mod itself doesn't completely condemn the original power socket. If everything goes well, i should receive my wall adapter today. So if there's an issue with the adapter+cable, like not enough power or something, at least i can use the original power supply for a while. 1 Quote Link to comment Share on other sites More sharing options...
