Grevle Posted September 17, 2022 Share Posted September 17, 2022 I still not quite familiar on how a DLI is done..mostly because of the parsing. I understand the display list iself pretty good , So the easiest way for me is to start with something simple. Just a single display list line with a differen color. Line 2 is better to start on since line 1 also involves the LMS instruction. Here is the standard display list for gr2+16 (graphics mode 2 with no bottom text bar) ;GR 2+16 .Byte 112,112,112 ; three blank lines .byte 71,64,156 ; first is lms command INCLUDING FIRST MODE LINE two other is for screen adress low byte,highbyte = 40000 .byte 7,7,7,7,7,7,7,7,7,7,7 ;mode 2 lines .byte 65,144,0 ; first is jump on vertical blank instructions,2 other is the adress low byte first. the adress for the display list itself If someone kan add the simple dli here to have line2 a different color and explain whats being done then it should be pretty fast for me and others who want to learn the basics of DLI. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 17, 2022 Share Posted September 17, 2022 To set a DLI and enable it you need something like this:- Once color2 is changed, the new colour will persist from this line down until the next VB processing when the original colour will be reset setdli: LDA # <dli STA $0200 LDA # >dli STA $0201 LDA #$C0 ; ENABLE DLI STA NMIEN RTS dli: ; 2 DLI lines only pha ; MUST SAVE ANY REGISTERS YOU USE ON THE STACK sta Wsync sta $d018 ; color2 change pla rti Quote Link to comment Share on other sites More sharing options...
Grevle Posted September 17, 2022 Author Share Posted September 17, 2022 2 hours ago, TGB1718 said: setdli: LDA # <dli STA $0200 LDA # >dli STA $0201 LDA #$C0 ; ENABLE DLI STA NMIEN RTS Is this to set the adress for the DLI itself ? Lowbyte+Highbyte gives the adress ? and is this code in the displaylist itself ? or can it be elsewhere ? Nmien = 54286 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted September 18, 2022 Share Posted September 18, 2022 2 hours ago, Grevle said: Is this to set the adress for the DLI itself ? Lowbyte+Highbyte gives the adress ? and is this code in the displaylist itself ? or can it be elsewhere ? Nmien = 54286 That tells the OS where to "look" to run the actual DLI code. It is not part of the DLI itself, and yes, that code can live anywhere. Something to keep in mind. The OS only has one DLI vector (the 16-bit address pointed to by $0200 and $0201). BUT - this does not mean you cannot run multiple DLIs. If you want to do this, you have your 1st DLI end with code that sets the addresses (you can usually only set one byte), and continue this. The final DLI will reset the address(es) back to the address of the 1st so that the process just repeats. When doing this, steps have to be made to make sure the 1st DLI fires in the correct position. Quote Link to comment Share on other sites More sharing options...
Grevle Posted September 18, 2022 Author Share Posted September 18, 2022 (edited) So i did try and to make this work. But i only get a one color screen. There's something missing. I did put the DLI flag + mode 2 Directly in the Display list (the number 135) The full CODE for executable : *=13200 SDMCTL = 559 ; Can turn on and off Antic (needed when creating display list) SDLSTL = 560 ; Shadow display list pointer low - Antic må vite hvor den nye display listen er SDLSTH = 561 ; Shadow display list pointer high LDA #0 STA SDMCTL ;TURN ANTIC OFF LDA #0 ; LOW BYTE STA SDLSTL ; store low byte of display list adress LDA #144 ; HIGHBYTE STA SDLSTH ;store high byte of display list adress LDA #34 STA SDMCTL ; ... Turn on Antic again ; SETUP VERTICAL BLANK ADRESS LDX #121 ;Setup VBI Highbyte 121*256+Lowbyte 69 = adress for VBI = 31045 LDY #69 LDA #7 JSR $E45C ; SetVB ; PUT SOME NUMBERS ON SCREEN LDX #17 STX 40009 LDX #18 STX 40229 LDA #0 STA 512 LDA #150 ; DLI ADRESS 38400 STA 513 LDA #192 ; =192 ; ENABLE DLI STA 54286 ;NMIEN MAIN JMP MAIN *= 31045 ; Vertical Blank interupt JMP $E462 ; Exit DVI ; The Display list *=36864 ;GR 2+16 .Byte 112,112,112 ; three blank lines .byte 71,64,156 ; first is lms command INCLUDING FIRST MODE LINE two other is for screen adress low byte,highbyte = 40000 .byte 7,7,7,135,7,7,7,7,7,7,7 .byte 65,144,0 ; first is jump on vertical blank instructions,2 other is the adress low byte first. the adress for the display list itself ; THE DLI *=38400 PHA ; Save accumulator LDX #32 ; CHOOSE COLOR STX $D40A ;WSYNC Wait STX 712 ; Store color PLA ; Restore registers RTI ; Done ; always end DLI with RTI! Edited September 18, 2022 by Grevle Quote Link to comment Share on other sites More sharing options...
glurk Posted September 18, 2022 Share Posted September 18, 2022 Just from a quick look, in your display list you have the LSB and MSB for the jump reversed. And in your DLI you save and restore 'A' but then you use 'X' instead ?? 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 18, 2022 Share Posted September 18, 2022 And you're hitting shadow register instead of the actual hardware register so that'll never properly work. 1 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted September 18, 2022 Share Posted September 18, 2022 For a very good introduction with real world examples go to Rob's website: https://playermissile.com/dli_tutorial/index.html# 2 Quote Link to comment Share on other sites More sharing options...
Grevle Posted September 18, 2022 Author Share Posted September 18, 2022 That was it. Finally i understand the basics of a DLI. Thanks for the Help. Heres the changes i did: Reversed the LSB and MSB in the last line of the Displaylist: .byte 65,0,144 ; first is jump on vertical blank instructions,2 other is the adress low byte first. the adress for the display list itself Then in the DLI routine write color to Hardware register and not shadowregister and USE Accu to store: ;DLI *=38400 PHA ; Save accumulator LDA #32 ; CHOOSE COLOR STA $D40A ;WSYNC Wait STA $D01A ; Store color PLA ; Restore registers RTI ; Done ; always end DLI with RTI! So it's all about the Parsing. Reading on the net is Helpful but often Small things like parsing and different approaches can be confusing. Thank you. 👍 5 Quote Link to comment Share on other sites More sharing options...
