robus Posted October 3, 2022 Author Share Posted October 3, 2022 1 hour ago, Ecernosoft said: It works via the color "3" (Both bits are 1) is different if the 7th bit is set or not. If it isn't it will be COLOR2 and if is it will be COLOR3. Thanks, I got it working and GTIA is now much simpler as I now send the color data through the emulated AN0-2 bus. This has definitely been a learning experience, which was entirely the point 1 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted October 3, 2022 Share Posted October 3, 2022 17 minutes ago, robus said: Thanks, I got it working and GTIA is now much simpler as I now send the color data through the emulated AN0-2 bus. This has definitely been a learning experience, which was entirely the point Just wait untill you get into the 7800 where you need to deal with the wonky sprite system But you can have over 200 sprites 😃 1 Quote Link to comment Share on other sites More sharing options...
robus Posted October 5, 2022 Author Share Posted October 5, 2022 On 10/3/2022 at 7:22 PM, Ecernosoft said: Just wait untill you get into the 7800 where you need to deal with the wonky sprite system But you can have over 200 sprites 😃 If I can get this thing running Star Raiders respectably I’ll consider it job done 1 Quote Link to comment Share on other sites More sharing options...
