thegamezmaster Posted September 23, 2022 Share Posted September 23, 2022 (edited) Is there a mod that can be done on a joystick that will work on the Colecovision? I did the Sega 3 button controller mod and wondered if there were any mods for like the Sega 3 button arcade stick? Or NES Advantage or something simular to use? I'm trying to come up with a real good joystick for the CV on a budget. Any guides that would help do this. Thanks for any help with this project! Edited September 23, 2022 by thegamezmaster Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted September 23, 2022 Author Share Posted September 23, 2022 (edited) Has anyone mod a joystick from back in the day as mentioned Sega or any other joysticks from back then? If so how to do? Please need help with this. Just want to play with a joystick I know how to use. Thanks. Edited September 23, 2022 by thegamezmaster Quote Link to comment Share on other sites More sharing options...
+mytek Posted September 24, 2022 Share Posted September 24, 2022 This might help you out for starters. ColecoController.pdf 1 Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted September 24, 2022 Author Share Posted September 24, 2022 11 hours ago, mytek said: This might help you out for starters. ColecoController.pdf 23.86 kB · 4 downloads Thanks for the reply but this skill is past me to do. Was more looking to see if anyone has modded a real joystick vintage or not to work on the Colecovision. Like the Sega Genesis 3 button controller to CV to play. Anyone please help with this. Thanks! Quote Link to comment Share on other sites More sharing options...
xdurable Posted September 24, 2022 Share Posted September 24, 2022 I have converted a not overly reliable original ColecoVision controller to a "Fighting stick" style - I removed the PCB and did a little soldering to connect some wires to the original contacts and then put it and some Arcade quality parts in a box - this is rev 2 - the box is made out of thin MDF - the holes under the joystick are for some buttons for games like Asteroids and Star Castle. 1 Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted September 25, 2022 Author Share Posted September 25, 2022 17 hours ago, xdurable said: I have converted a not overly reliable original ColecoVision controller to a "Fighting stick" style - I removed the PCB and did a little soldering to connect some wires to the original contacts and then put it and some Arcade quality parts in a box - this is rev 2 - the box is made out of thin MDF - the holes under the joystick are for some buttons for games like Asteroids and Star Castle. Wish I had your skills to do this but don't. How hard or not was this to make? Any guide or something on how to make? Thanks. Quote Link to comment Share on other sites More sharing options...
chart45 Posted September 25, 2022 Share Posted September 25, 2022 buy this kit should be pretty easy https://edladdin.com/Easy-CV-Input-Output-Board-Keypad-ec-pcb-02.htm Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted September 26, 2022 Author Share Posted September 26, 2022 16 hours ago, chart45 said: buy this kit should be pretty easy https://edladdin.com/Easy-CV-Input-Output-Board-Keypad-ec-pcb-02.htm Beyond my knowledge and skills. Wish I could. Thanks for input! Any suggestions? Quote Link to comment Share on other sites More sharing options...
Cartermw Posted September 28, 2022 Share Posted September 28, 2022 I designed one a while back that would allow you to plug a Neo Geo joystick on the colecovision. I picked up a NeoGeo Bluetooth adapter so I could use Xbox and playstation controllers with it. 1 Quote Link to comment Share on other sites More sharing options...
