spookt Posted September 23, 2022 Share Posted September 23, 2022 Hi folks Playing around with BASIC XE for the first time and trying some of the examples in the manual. I'm using BXE v 4.1 from Atarimania in Atari800MAC with DOS 2.5. If I try the following example from the manual, I get an error 33 at line 20. Since this is straight from the manual I'm a little surprised. I've tried rolling my own procedure to test but whatever I try I get the same error 33 (which doesn't seem to be listed in the error messages in the manual!) Any pointers? 10 Junk=20 20 Call "Test" Using 12*17 30 Print Junk 40 End 70 Procedure "Test" Using Junk 80 Print Junk 90 Exit Quote Link to comment Share on other sites More sharing options...
Alfred Posted September 23, 2022 Share Posted September 23, 2022 (edited) You need to load the Basic XE extensions in order to use procedures. I suspect error 33 is a keyword not found type of error. Make sure the BASICXE.OSS file that is the right version for 4.1 is on the disk you are using with BasicXE. Edit: Error 33 is: ERRNI INC :BR0 ;FUNCTION OR STMT NOT IMPLEMENTED Edited September 23, 2022 by Alfred Added Error 33 info Quote Link to comment Share on other sites More sharing options...
+MrFish Posted September 24, 2022 Share Posted September 24, 2022 According to the manual, you lose all of these commands when you boot without the extension disk. BSAVE, CALL, DEL, EXIT, FAST, LOCAL, LVAR, MOVE, PROCEDURE, RENUM, RGET, RPUT, SORTUP, SORTDOWN, the fast math routines, and all P/M commands except HITCLR. Quote Link to comment Share on other sites More sharing options...
spookt Posted September 24, 2022 Author Share Posted September 24, 2022 (edited) Ah - thanks folks. I had wondered, but I've only read chunks of the manual. EDIT: Yep a big RTFM to myself! Just booted with extension disk in D1 and all is good. Also just read the beginning of the manual. Would have saved me some time yesterday! Edited September 24, 2022 by spookt Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 24, 2022 Share Posted September 24, 2022 Just a note, the extensions disk or it's contents have to be on the disk or in the folder you run BASIC XE from, for example, I have a BASIC folder on my U1M/SIDE3 setup, I copied all the files off the extension disk into that folder and run BASIC XE from that folder. 1 Quote Link to comment Share on other sites More sharing options...
