unpacking LZ4 on Jaguar
Ericde45
hello,
in case you need to use compressed files on Jag, on my github, in my YM emulation code, there is an unpacking subroutine to decompress LZ4 using 68000, and the same for DSP
https://github.com/ericde45/YM2149_JAG/blob/main/ym1.s
the PC exe packing program is here :
compressing is done with : lz4.exe -9 -l --no-frame-crc [input file] [output file]
start of packed datas are at +8
the -l command generate a legacy frame format lz4, more simple then usual lz4 format
documentation of the format is here  : https://android.googlesource.com/platform/external/lz4/+/HEAD/doc/lz4_Frame_format.md
( bloc size is 8 MB which is enough to only create 1 block file for the Jaguar )
if creg is tagging registers to create aliases for them, i don't have a clear answer.
i use it in complex code, for example in the gpu sprite collisions routine of Jalaga, but most of the time i code with directly the registers.
i may see things better with registers, and i'm using my own custom colors in notepad++ to help
Slighly optimized/size reduced (250 > 186)
; input: R20 : packed buffer
;		 R21 : output buffer
;		 R0  : LZ4 packed block size (in bytes)
; A4 => R24
; A0 => R20
; A1 => R21
; A3 => R23
; D0 => R0
; D1 => R1
; D2 => R2
; D4 => R4
; adresse saut 1 => R10
; adresse saut 2 => R11
; R12=$FF pour mask
; R13=tmp
lz4_depack_smallest_DSP:
		move	R20,R24
		add	R0,R24	; packed buffer end
		moveq	#0,R0
		moveq	#0,R2
		moveq	#$F,R4
		movei	#.lenOffset_smallest_DSP,R10
		movei	#$FF,R12
.tokenLoop_smallest_DSP:
		loadb	(R20),R0
		addq	#1,R20
		move	R0,R1
		shrq	#4,R1
		jump	eq,(R10)
		nop
.readLen_smallest1_DSP:
		cmp	R1,R4			; cmp.B !!!!
		jr	ne,.readEnd_smallest1_DSP
;;->		nop
.readLoop_smallest1_DSP:
		loadb	(R20),R2
		addq	#1,R20
		add	R2,R1			; final len could be > 64KiB
		not	R2
		and	R12,R2			; not R2.b
		jr	eq,.readLoop_smallest1_DSP
		nop
.readEnd_smallest1_DSP:
.litcopy_smallest_DSP:
		loadb	(R20),R13
		addq	#1,R20
		subq	#1,R1
		storeb	R13,(R21)
		jr	ne,.litcopy_smallest_DSP
		addq	#1,R21
		; end test is always done just after literals
		movei	#.readEnd_smallest_DSP,R11
		cmp	R20,R24
		jump	eq,(R11)
		nop
.lenOffset_smallest_DSP:
		loadb	(R20),R1	; read 16bits offset, little endian, unaligned
		addq	#1,R20
		loadb	(R20),R13
		addq	#1,R20
		shlq	#8,R13
		add	R13,R1
		move	R21,R23
		sub	R1,R23		; R1/d1 bits 31..16 are always 0 here
		moveq	#$F,R1
		and	R0,R1		; and.w	d0,d1 .W !!!
.readLen_smallest2_DSP:
		jr	ne,.readEnd_smallest2_DSP
		nop
.readLoop_smallest2_DSP:
		loadb	(R20),R2
		addq	#1,R20
		not	R2
		jr	eq,.readLoop_smallest2_DSP
		nop
.readEnd_smallest2_DSP:
		addq	#4,R1
.copy_smallest_DSP:
		loadb	(R23),R13
		addq	#1,R23
		subq	#1,R1
		storeb	R13,(R21)
		jr	ne,.copy_smallest_DSP
		addqt	#1,R21
		movei	#.tokenLoop_smallest_DSP,R11
		jump	(R11)
		nop
.readLen_smallest_DSP:
		jr	ne,.readEnd_smallest_DSP
		nop
.readLoop_smallest_DSP:
		loadb	(R20),R2
		addq	#1,R20
		not	R2
		jr	eq,.readLoop_smallest_DSP
		nop
.readEnd_smallest_DSP:
YM_DSP_retour_depack_LZ4_boucle_principale_DSP:
	movei	#YM_LZ4_nb_bloc_LZ4_disponibles,R0
	load	(R0),R1
	addq	#1,R1
	store	R1,(R0)
	movei	#DSP_boucle_centrale,R0
	jump	(R0)
	nop
  • Like 4
Could save a few more, there are a couple of places you can do this:
		loadb	(R20),R0
		addq	#1,R20
		move	R0,R1
		shrq	#4,R1
		jump	eq,(R10)
		nop
into this....
        loadb   (R20),r0
        move    r0,r1
        shrq    #4,r1
        jump    eq,(R10)
        addq    #1,r20
Down to 146  142 bytes plus some speed optimization:
;;; -*-asm-*-
; A4 => R24
; A0 => R20
; A1 => R21
; A3 => R23
; D0 => R0
; D1 => R1
; D2 => R2
; D4 => R4
; R12=$FF pour mask
; R13=tmp
		move	R20,R24
		moveq	#$F,R4
		movei	#$FF,R12
		loadb	(R20),R0
		addqt	#1,R20
		move	R0,R1
		shrq	#4,R1
		jump	eq,(R10)
		and	r4,r0			; remove high nibble
		cmp	R1,R4			; r1 == 15 ?
		loadb	(R20),R2
		jr	ne,.readEnd_smallest1a_DSP ; skip first addq in copy loop!
		addqt	#1,R20
		cmp	R12,R2			; r2 = $ff ?
		loadb	(R20),R2
		addqt	#1,R20
.readEnd_smallest1a_DSP:
		subq	#1,R1
		storeb	R2,(R21)
		addqt	#1,R21
		loadb	(R20),r2
		cmp	R20,R24
		jr	ne,.lenOffset_smallestx_DSP
;;; .readEnd_smallest_DSP:
	;; Return to caller
		load	(R0),R1
		addq	#1,R1
		store	R1,(R0)
		jump	(R0)
.lenOffset_smallestx_DSP:
		move	R21,R23
		addqt	#1,R20
		loadb	(R20),R13
		addqt	#1,R20
;;;readLen_smallest2_DSP
		cmp	R0,R4			; cmp.B !!!!
		loadb	(R20),R2
		add	R2,R0			; final len could be > 64KiB
		addq	#1,R20
	;; finish offset calculation
		shlq	#8,R13
		add	R13,R1
		addq	#4,R0
.copy_smallest_DSP:
		loadb	(R23),R13
		addq	#1,R23
		subq	#1,R0
		storeb	R13,(R21)
		addqt	#1,R21
		jump	(R11)
		loadb	(R20),R0
		align 4
YM_LZ4_nb_bloc_LZ4_disponibles:	ds.l 1
Edited by 42bs
No "not" needed
So, final version. Register usage reduced, more comments.
;;; -*-asm-*-
; input:
;;; R20 : packed buffer
;;; R21 : output buffer
;;; R0  : LZ4 packed block size (in bytes)
;;; Register usage (destroyed!)
;;; r1,r2,r4,r10,r11,r12,r13
;;; R1,R2     : temp register
;;; r4        : mask $0f
;;; r10       : jump destination
;;; r11       : jump destination
;;; r12       : mask $ff
;;; r13       : end of packed data
		move	R20,R13
		add	R0,R13			; packed buffer end
		moveq	#$F,R4
		movei	#$FF,R12
		loadb	(R20),R0
		addqt	#1,R20
		move	R0,R1
		shrq	#4,R1
		jump	eq,(R10)
		loadb	(R20),R2
		addqt	#1,R20
		loadb	(R20),R2
		addqt	#1,R20
		subq	#1,R1
		storeb	R2,(R21)
		addqt	#1,R21
		loadb	(R20),r2
		cmp	R20,R13
	;; Return to caller
		load	(R0),R1
		addq	#1,R1
		store	R1,(R0)
		jump	(R0)
		addqt	#1,R20
		loadb	(R20),R2
		addqt	#1,R20
		shlq	#8,R2
		add	R2,R1
		neg	r1
		add	r21,r1		; source = dest - offset
		cmp	R0,R4		; r0 == 15 ?
		loadb	(R20),R2
		addq	#1,R20
		addq	#4,R0
.copy_smallest_DSP:
		loadb	(R1),R2
		addq	#1,R1
		subq	#1,R0
		storeb	R2,(R21)
		addqt	#1,R21
		jump	(R11)
		loadb	(R20),R0
		align 4
regarding this depacking using the dsp, while playing a module, during the lz4 depacking, the music seems to be off tone.
it seems the interrupts are not able to do all their duty
aren't the interrupts I2S and timer 1 supposed to have priority upon the main DSP code ?
replay frequency is ~16000 Hz
