Which high-level native TI-99 languages are you most likely to use for a future TI-99 project?
pixelpedant
What TI-native interpreted or compiled language do you want to develop in next?
34 members have voted
  1. 1. What TI-native interpreted or compiled language do you want to develop in next?
    • TI BASIC (OEM/ROM)
    • TI Extended BASIC (OEM)
      10
    • A third party Extended BASIC dialect and/or package of support routines (RXB,XB256,TML,T40XB,etc.)
      12
    • Forth
      10
    • UCSD Pascal
    • TI LOGO
    • Other
There are a few more languages and dialects which made some sort of appearance on the TI-99 natively, to be sure.  Though receiving very little actual use.  If one of those is in your plans, even better.
My list of priorities is probably:
1) TI BASIC (likely use: major long-term game project)
2) TI Extended BASIC (likely use: major synth project)
3) TI LOGO (likely use: action game project)
4) UCSD Pascal (likely use: not sure yet)
1 hour ago, retroclouds said:
Doing an action game in TI logo II would likely make the game fast and responsive.
Where there any done in the past?
Sort of.  There are a few simple games.  A couple were evidently created by students as class projects.
The most complete is I suppose FROGO, a LOGO frogger clone.  The other few I've found are very basic.
A_FROGO
I've never found anything that really exploits LOGO's potential (in particular, to control large sprite groups efficiently).
Imagining something like my TI LOGO II "PLANES" demo from a while back, extrapolated into a game of some sort:
Would choose C with a cross compiler. Mainly because I do all my other 8 bit coding for other machines in C.
Edit: oh, sorry, see the question says native, in that case none, prefer to develop on my PC for my retros.
Edited by xahmol
6 hours ago, Lord Vorkosigan said:
I would be more in favor of C, but requires to have libraries for graphic and sounds.
An interesting language could be ugBasic, which can produce fast code today on some targets.
https://ugbasic.iwashere.eu/
I took the question "Which high-level native TI-99 language..." as something that existed reasonably early for the TI-99.
Edited by apersson850
is Native any language that you can write on a TI-99/4A?
The list should include:
GPL (its possible native right? There were some tools right? RAG or Paolo Bagnaresi?)
c99 (Clint Pulley) existed by 1986
Obscure:
TI Pilot (p-code)
Scott Adams Adventure APL
(Marcus Weiand Adventure Editor.)
10 hours ago, pixelpedant said:
Well, I wouldn't call GPL a high-level language.
i did put out some GPL Tutorials and many of the commands in XB and Basic can be found in GPL as there is the origin.
CALL LABEL is a CALL LABEL in GPL and Basic
RT is a RETURN in GPL and Basic
B (Branch) is a GOTO in GPL and Basic
CASE value is a ON value GOTO in GPL and Basic
RTN (Return) is a RETURN NEXT in GPL and Basic (depends on how your branch from result)
RTNC (Return) is a RETURN ERROR in GPL and Basic (depends on how your branch from result)
BACK color is a CALL SCREEN(color) in GPL and Basic
ALL character is a CALL HCHAR(1,1,character,768) in GPL and Basic
RAND value is a RANDOMIZE value in GPL and Basic
EXIT is a BYE in GPL and Basic
I could go on that many commands are pretty much GPL commands with different names.
This is why I stated that GPL is a great step from XB to Assembly as GPL is a great gradient between XB and Assembly.
The question is not whether GPL uses commands that also appear in BASIC in some way.
High-level language:
- Abstract structures (data types beyond simple types; complex types, classes, objects, structures)
- Abstract control structures (procedures, methods, parameter passing)
- Abstract memory (variables)
- problem-oriented (program design following the actual problem)
- little or no platform dependence (portability)
Low-level language:
- Simple data structures (byte, integer, character, stack)
- Simple control structures (branches, loops, subprograms)
- Direct memory usage (addresses)
- machine-oriented (program design following the capabilities of the machine)
- considerable or full platform dependence (little portability)
GPL is the low-level language of the virtual GPL machine in the TI-99/4A.
Edit: To make it clear, there is no better or worse with low-level and high-level. Each one has its typical area of usage.
  • Like 6
Low-level language:
Ok understood but you did get one thing backwards, Basic uses GPL commands not the way you said it:
"The question is not whether GPL uses commands that also appear in BASIC in some way."
This makes it sound like Basic came first and GPL copied it, that is the opposite of what happened, GPL first Basic later.
@RXB
There is a challenge for anyone wanting to write programs in GPL.  There is very little documentation I am aware such as a "Beginning GPL Programming" book or tutorial.  There is a lot of documentation on assembly language, but very little information to be found.
You are by far the THE GURU on GPL, however most everyone else is still in diapers.  You indicated something out there in a post I saw about youtube video's however a quick search, I could not find your channel to see what has been presented.
If you have not done so already, and if there is even any interest, I might suggest an indepth tutorial document and a DSK image of the TI-99/4A programs all grouped together to write a program from source to compiled to an image that can be used on the FinalGrom, GramKracker and MAME that writes some text, redefines some characters and displays those characters, launches a sprite, and reads/writes a file (DV80 to start).  I know there are some PC utilities out there now that can compile and create runnable code, but think for the moment for people that want to stay on real hardware or at least within MAME/Classic 99 emulation for development purposes.
You may have something already out there that does this, but it is not currently obvious where one may find it.  As I said again, you are by far the expert and Guru on the subject of GPL, but information on programming in GPL is very limited.  My 2 cents.
1 hour ago, 9640News said:
@RXB
You mean like this on Arari Age:
GPL - Manuals/Tutorials
GPL Programmers Guide PDF
The original GPL programming reference manual from Texas Instruments.
Covers all opcodes and advanced stuff like coincidence detection, I/O routines, etc.
http://aa-ti994a.oratronik.de/devres_bookcovers_kombi3.png
The Graphics Programming Language (GPL) PDF
GPL manual with instruction syntax as accepted by the RAG Software GPL Macro Assembler.
Edited by @Lee Stewart
TI-Intern PDF
Details on "Monitor", the OS of the TI-99/4A. Disassembly of console ROM/GROMS and GPL interpreter.
Has details on interrupt routine, utility subprograms, basic interpreter, etc.
GPL HOW 2 Series video
A complete series on how to program GPL (Graphics Progroamming Language) on the TI-99/4A.
Each tutorial has its own support package with example code, GPL assembler, etc.
Video tutorials done by Rich, the programmer of Rich Extended Basic.
(Author: @RXB)
GPLHOW2A - Introduction video / zip
GPLHOW2B - Sprite demo video / zip
GPLHOW2C - How to make a Screen Editor like TI Writer or Editor Assembler video / zip
GPLHOW2D - Editor Assembler TI BASIC support.video / zip
GPLHOW2E - DMII cartridge upgrades and how GPL works video / zip
GPLHOW2F - TI Basic to GPL. Converting a TI Basic program to GPL video / zip
GPLHOW2G - TI Basic CALL SOUND to GPL video / zip
GPLHOW2H - Simultaneous sound lists and interrupt timer in GPL video / zip
GPLHOW2I - XB2GPL demo of a XB game Baloons converted into a GPL program video / zip
GPLHOW2J - Update to GPLHOW2I and adds a automatic music to the game from the last demo video / zip
GPLHOW2K - How to make XB Program Image files into I/V 254 files video / zip
I've got to be honest here.  I've watched GPLHOW2A probably four times in the past couple of years.  I've never moved past it because I didn't understand hardly any of it.  I just watched GPLHOW2F and am eager to learn more.  I really wish those videos were flipped.  Or even better, GPLHOW2A redone as a slower version of GPLHOW2F with some explanation of the development environment/tools.  Perhaps not a complete program, but snippets of code that shows XB CALLS and statements and their corresponding GPL.  The way GPLHOW2F keeps the BASIC commented out above the new code is a great teaching tool.
TI-Intern PDF
(Author: @RXB)
Rich,
I have the TI Intern book and used to have the GPL Manual from TI you referenced.  I know when I look at the TI Intern and the GPL manual, it is easy to become overwhelmed just like I was back in the day when I tried to understand TI's Editor/Assembler manual.  It was the Art of Assembly language (I think that is the name) book that started to make sense to me as it took things line by line and explained what it did and why they were doing it.
I watched your 2A and 2B, and briefly looked at the 2F video since it was mentioned by @Switch1995.  You have obviously put a lot of work into these videos.  I will say though, and I have been guilty of this as well, one can be so familiar with the topic it is easy to make presumptions about your audience and can go over their heads so quick they can get overwhelmed and say another day.  That was the case with me back in the day with assembly language.
Beery
4 hours ago, 9640News said:
Rich,
Beery
Beery
Most of the Tutorials are pretty breif and the source code is completely commented and explained step by step.
Rich
@RXB years ago when you sent me your starting GPL package I compiled the example programs and was amazed it was so easy to get going and one could run GPL without a GRAM device.   Agreeing with @9640News without a Computer Beginners Guide to GPL, I wasn't really sure where to go next. If you or someone else was willing to open a thread on learning GPL with a monthly example, I would enjoy following along, learning GPL is something that interests me. Others would be appreciative of any efforts you might put in that direction.
Beery
Rich
Sometimes, even fully commented source code is not enough.  I have looked at some of your source code in the past and you go far beyond what a lot of programmers do in commenting source code.
For me though back in the 80's and 90's, one would have really had to dumb it down for me to get the basic-basics.  That first step was too big of a step.  Now, I will tell you it is unlikely I will program in GPL in the future, however, I would follow along as @dhe suggested should you put out some kind of monthly tutorial at the beginner's level so that I could understand some of the basics.
Same here! Some of the beginner stuff is to another beginner that is smarter then me, hehehe. And for that reason I will most probably struggle along with the limitations of Ex B. As it has a good guide to learn and make programs. But if I was to get the stupid beginners program... I might try it on!
  • Haha 1
Yeah, I second this (third?) if @RXB showed some beginner GPL exercises and we did homework together.
I’ve always been “afraid” of GPL it being so mysterious and all. Inscrutable back in the day.  I think it’s my fear of having to implement a compiler for an exam. GPL seems so weird.
But it’s our “native language” even if we don’t speak it.
My article from Micropendium:
My Trek Through GPL and a Learning Curve
    I made a choice
between a Myarc Hard/Floppy controller and a GRAM device.  I
picked  the GRAMulator by C.A.D.D. Electronics because I was sick
and tired of swapping modules.  Also, once I had used it for
awhile, I considered programming modules.  Trouble was, no one
knew how to program modules and only GPL was slightly mentioned
as the means of how they  worked.
    Well I saw in a
Micropendium an ad by Jim Lesher and I called him and asked what
he  had, he really did not know exactly what it was but had two
huge books.  He asked $300.00 for it  and I said well ok.  It
turned out to be the Technical Training Manual for TI programmers
and  hardware specs, so I releases this into the TI market years
ago.  I also bought for $350.00 a  manual that Jim stated was
something to do with Extended Basic, he was right, it was the
entire  source code of Assembly and GPL code for TI Extended
Basic versions 100 to 110.
    Now I knew what GPL
was and how it worked but how was I going to create programs  for
modules, At first I was using the GRAM KRACKER method of typing
byte by byte.  Debugging was to say the least a search in the
dark wearing a sack.
    Finally, someone
mentioned a now defunct business and I sent for a copy of the
RYTE  DATA GPL ASSEMBLER by Weiand.  I also got a hold of the
RYTE DATA GPL LINKER and  some example program written for the
GRAM KRACKER FACTS.  And whoosh I dived into the  manuals, then
began the process of writing code that crashed a lot.
    As anyone who has
learned Assembly would know, you must first look at lots of other
people code to understand how it works.  Only then can you change
this then that to see the  results.  I have gone out of my way
many times to explain GPL is like a cross between BASIC  and
Assembly.  If you know Assembly, it will be very easy to learn,
but if you only know BASIC  the curve is going to really go up.
On the other hand if you have been reading the Bruce Harrison
articles in Micropendium the pain will be less than expected.
    Most of the GPL I
have written has been installed into RXB and I really have
enjoyed  fixing the bugs in XB.  Many of the comments written by
the original programmers of XB for TI  are sometimes funny if you
understand the problems they faced.
    An example of a bug
in XB is the REDO key buffer.  If you have the original version
110  of XB type in a line of code and use the insert key to add
more until the line is 4 lines long.  Now  push the REDO key and
watch half of it disappear.  What happened? Well the lines you
type in  are automatically converted to tokenized code and
installed into the execute buffer.
  Trouble is  the REDO buffer is only half as large as the
execute buffer and not tokenized either.  Little stars  were
written into the code to point out this bug but XB was already
released so it was too late.  I  got rid of the REDO key in RXB
and used the space for USER (Batch file server).
    If you have interest
in GPL read my article COMPARING LANGUAGES in  Micropendium and
you can compare XB with GPL and Assembly.  If you have questions
just call  or write me.
            Rich
Gilbertson
            1901 H
Street
            Vancouver,
WA 98663-3352
            Phone: 1-
360-737-7963
This HandOut was compiled by: Dan H. Eicher of the Texas
Instruments Hoosier's Users Group. BBS: 317.782.9942. Email:
Eicher@Delphi.com
This article first appeared in the Micropendium,
December 1992 edition.
Comparing languages
by Rich Gilbertson
How to compare languages presents a Catch 22 situation. I mean,
you would have to know about each language in order to compare
them. Otherwise you're really just taking someone else's word for
it as to which one is best for you.
I can't totally solve your problem as even I and many others in
this field don't know all the computer languages for the TI. I do
know we have ASPIC, LOGO, Fortran, COBOL, Forth, C, Basic and
Extended Basic and GPL. And oh, yes, Assembly language. In this
installment we will only be concerned with the most common
TI99/4a languages. Those are the ones that have been around the
longest, Assembly, GPL and Extended BASIC. I purposely dropped
BASIC, as Extended BASIC will run any BASIC program. (At least my
RichGKXB will.)
So Extended BASIC is known by everyone, or at least you know it
exists even if you can't write programs in it. Assembly is the
mythical language you've heard is the fastest and best, also the
hardest to learn and work with. This leaves GPL, the only
language specifically for the TI. Graphics Programming Language
or GPL is built into the operating system of the TI and actually
is what puts the cartridge menus up on screen. GPL is have the
operating system of the TI and has some distinct advantages over
other languages for the TI. One is, as GPL is built into the TI
to begin with, you never need to load anything to make GPL
programs work. As with Assembly and BASIC, the operating system
has everything need to run these languages. There are tons of
tutorials on Extended BASIC and Assembly, but very few on GPL!
With that in mind I through it best to show all three languages
doing the same thing.
The following programs are not complete program in the sense that
they will work by themselves. The Extended BASIC program will
function because the interpreter is built in the cartridge
through GPL - that's 90 percent of what Extended BASIC is written
in - while only 10 percent of Extended BASIC is Assembly. Both
GPL and Assembly need a compiler to convert the following source
code into a object code that can be loaded and run. So the source
code of the following programs in GRAMKracker
Extended BASIC, GPL and Assembly all do the same thing, but are
not fully functional by themselves.
To simplify what each one does, the Extended BASIC program's
version of each program explains what is going on. If you are not
one who understands Extended BASIC either, now is your chance to
start learning and at the same time see two other languages.
EXTENDED BASIC PROGRAM BYTES USED 14 * NOTE USES GPL Routine.
100 CALL CLEAR
GPL PROGRAM BYTES USED 2     * NOTE SUPPORT NOT NEEDED AS
    ALL 32                     OPERATING SYSTEM IS BUILT IN.
ASSEMBLY PROGRAM BYTES USED 16  * NOTE I AVOIDED COUNTING THE
    LI   R0,>2000                 ASSEMBLY SUPPORT ROUTINES IN
    LI   R1,767                   ORDER TO MAKE THIS PROGRAM
J1  BLWP @VSBW                    WORK. SPACE OF ARTICLE IS
    DEC  R1                       LIMITED. 1k IS NEEDED FOR
    JNE  J1                       SUPPORT ROUTINES.
EXTENDED BASIC PROGRAM BYTES USED 10
100 GOTO 100
GPL PROGRAM BYTES USED 2 OR 3
    BR   LABEL
    BS   LABEL
    B    LABEL
ASSEMBLY PROGRAM BYTES USED 2 OR 4
    JMP  @LABEL
    B    @LABEL
EXTENDED BASIC PROGRAM BYTES USED 41
100 CALL JOYST(1,X,Y1) :: CALL KEY(1,K,S)
GPL PROGRAM BYTES USED 4
        ST   >01,@>8374
        SCAN
ASSEMBLY PROGRAM BYTES USED 12
    LI   >0100
    MOVB R0,@8374
    BLWP @KSCAN
EXTENDED BASIC PROGRAM BYTES USED 17
100 GOSUB 1000
1000 RETURN
    CALL SUB
SUB RETURN
ASSEMBLY PROGRAM BYTES USED 6
    BL   @SUB
    SUB RT
EXTENDED BASIC PROGRAM BYTES USED 30
100 CALL HCHAR(12,16,42)
GPL PROGRAM BYTES USED 6
    ST   42,V@368
    LI   R0,368
    LI   R1,>2A00
    BLWP @VSBW
EXTENDED BASIC PROGRAM BYTES USED 58
100 CALL GCHAR(10,10,G) :: CALL HCHAR(20,20,G,4)
GPL PROGRAM BYTES USED 18
     ST   V@298,@FAC
     DST  >1714,@837E
LOOP ST   @FAC,@837D
     DEC  @837E
     CEQ  >13,@>837E
     BR   LOOP
ASSEMBLY PROGRAM BYTES USED 30
         LI       R0,298
         CLR  R1
         BLWP @VSBR
         LI   R2,3
         LI   R0,628
    LP   BLWP @VSBW
         AI   R0,32
         DEC  R2
         JNE  LP
EXTENDED BASIC PROGRAM BYTES USED 45
100 CALL SUBROUTINE
1000 SUB SUBROUTINE
1010 SUBEND
    CALL SUB
SUB RTN
ASSEMBLY PROGRAM BYTES USED 42
SUBWS  BSS  32
SUB    DATA SUBWS
       DATA SUB2
SUB2   RTWP
       BLWP @SUB
EXTENDED BASIC PROGRAM BYTES USED 21
100 CALL MAGNIFY(3)
GPL PROGRAM BYTES USED 3
    ST   >E2,#1
ASSEMBLY PROGRAM BYTES USED 8
    LI   R0,>01E2
         BLWP @VWTR
100 RANDOMIZE(8)
    RAND >08
    LI   R0,>0800
    MOVE R0,@>83C0
EXTENDED BASIC PROGRAM BYTES USED 20
100 CALL SCREEN(5)
    ST   4,#7
    LI   R0,>0704
         BLWP @VWTR
100 IF VAR=8 THEN 200 ELSE 300
GPL PROGRAM BYTES USED 7
L100   CEQ   8,@VAR
       BS    L200
       BR    L300
L100   CI    8,@VAR
       JEQ   L200
       JMP   L300
GK EXTENDED BASIC PROGRAM BYTES USED 12
100 CALL BYE
    EXIT
    LWPI  >83E0
    BLWP  @>0000
You can see if you just look at the number of bytes used by each
language that all of them suffer in some area. At times Extended
BASIC approaches Assembly in memory usage, while at times
Assembly approaches GPL in memory usage. It is apparent that GPL
can't be beat even in the simplest of the routines that Assembly
should excel in. Texas Instruments did a great job with creating
GPL. It either matches Assembly in size or beats it ever time. By
the way, GPL also uses less memory than any other language I've
compared it to, including Forth and C.
Now you know I think GPL is tops, and you may now have a little
more respect for GPL. So with that in mind I'd like to add what
can be done with GPL and Assembly combined. My work has resulted
in a new Extended BASIC called Rich GK XB. The GK stands for
GRAMKrack, so RICHGKXB is RXB for short. RXB has a number of GPL
commands available as Extended BASIC commands modified slightly
so XB programmers can use them. One of them is a GPL command
called MOVE, what does it do?
EXAMPLE:
EX MOVE BYTES,@FROM,@TO
Breaking down this command we get EX is a label, MOVE is the
command's name, BYTES is a value of how many ranging from 1 to
>FFFF (65535). The @FROM means at label FROM which is an address
and the opposite is the @TO which means the address destination.
Got it, so it will move any number of bytes from any address to
any address. The kicker is it does it with any type of memory
from VDP, GRAM, GROM, ROM, RAM. Best of all, the above example
only uses seven bytes. RXB has a MOVE command that is the exact
same command, bye modified for Extended BASIC users to have.
EXAMPLE:
100 CALL MOVE(TYPE,BYTES,FROM,TO)
Note that the only real difference is the TYPE and it ranges from
0 to 11 with each type number meaning a different type of memory
to a different type of memory. Like, say, 3 is from RMA to VDP,
or 9 is from GRAM to RAM. Get the idea, by using RXB you would
also be learning GPL, as the commands are the same. Note if
you're the owner of a GRAM device like a GRAMKracker, GRAMULATOR,
P-GRAM card, Mechatronics GRAM card, GRAMKART or other GRAM
device you can most likely use RXB. The idea is to teach GPL in
any fashion available.
Another command is a new command I'm just finishing for RXB
called IO. Now IO means Input Output and IO allows the XB
programmer to use a GPL command (the same name IO) in his XB
programs.
EXAMPLE:
CALL IO(0,VDP-ADDRESS)
This command would go out to a VDP address and execute the list
in VDP memory by the sound chip playing whatever it found there.
It will play if whether or not you are running a program. The
sound chip will run it independently of your present program and
can even repeat if the list tells it to.
Other features of IO is its ability to also talk to a type of
memory called CRU (Control Register Unit), better know as the IO
chip. With this command almost every wire or chip in the TI99/4A
can be read or written (controller). At first glance this stuff
may sound like fantasy, but it is true, and I'm adding more to
RXB everyday.
MISC:
Here is a short questions and answer session that I held
with Rich over the phone.
Questions: I noticed the assembler makes multiple passes
through the source code while it is compiling. What is a
pass and how many can the compiler make?
Answer: The first pass the assembler creates an equate
table. The second pass creates a listing file with address
cross references. In most cases the third pass writes the
object code. The multiple number of passes I have been able
to force the compiler to do was 4. I did that by creating
many multiple reference, ie.. a reference, referencing
another reference.. Mack McCormic once got the assembler to
make 9 passes before erroring out. It errored out, not
because of an error in the compiler, but because of an error
in Mack's code! The Weigand assembler on the demo disk
supports labels up to 32 characters in length.
Question: How many GPL compilers are available?
Answer: TI did all of their GPL development on 990
Minicomputers. For the 99/4a their are at least three
available. The first is the Weigand Assembler, which came
from a number of different sources. The second is by Ron Art
Green (RAG) - this one is very well documented, and Ron used
it to write a number of P-Gram utilities. The third and less
well known is..
Question: What would you most like to change?
Answer: The linker that Monty Schmidt developed is very
powerful, but it lacks in user friendlyness, you must read
the manual very carefully in order to make things work
correctly. I would like to modify this to do more prompting
of the user and allow for greater flexability in path names.
All the work I do, I do on a zip drive connected to my WHT
SCSI card. If I had the source to the Weigand assembler, I
would like to modify to create a better cross reference
listing, like the Funnelweb assembler does.
Question: How easy is file I/O in GPL?
Answer: File I/O is easy compared to assembler, somewhat
more complicated then Basic. I once diassembled the entire
Disk Manager II module and modified it to accept drive
numbers up to 9. DM2 is written entirerly in assembler, so
you can see that it is very capable file file I/O.
Quesiton: Is the GPL interpreter built into the console have
provisions for extensions. I am thinking of support of
eighty column devices?
Answer: No direct provisions have been made for doing this,
however the GPL interpreter resides in GROM 0 (For
understanding the interpreter I highly recommend Hienrich
Martins - Intern manual), so if you have a GPL device like
the Gramulator that allows you to modify GROM 0 you can
modify the interpreter itself. I havn't done that, because I
have a SOB and TIM, and a Millers Graphics Gramulator card.
For some reason the GramKracker won't operate with the SOB,
the Gramulator will. I hope to get a Gramulator someday.
As for 80 columns the GPL can't be running while interupts
are enabled, in order for some of the 9938's modes and
commands to operate correctly, interupts must be enabled.
Questions: Whats next for you?
Answer: I would like to take the XHI 80 column routines and
build them into RXB.
HOW TO ASSEMBLE AND RUN YOUR FIRST GPL PROGRAM!
      This disk is to be copied to another disk so you can learn
to assemble your own GPL programs. The OBJECT file is just like
regular object files from the Editor Assembler except the code is
GPL instead of Assembly. ASSM1, ASSM2, and ASSM3 are the
assembler program for turning DV80 SOURCE files into GPL OBJECT
files, also DV80 LIST files are created to see exactly where
every single byte is used.
       A DF80 file named LINK is the GPL LINKER program that will
take your OBJECT file and add UTIL1 to it, then turn it into a
EA5 program file. The linker is also used on this demo disk.
UTIL1 must be on DSK1 in order to work.
       The file TEST-INPUT is the GPL SOURCE file for the demo
program and the file TEST-COPY is a secondary SOURCE file that
TEST-INPUT uses. Way to much would have to be explained in the
GPL SOURCE code so this is the simple-stupid approach. Besides
the SOURCE code is fully commented on throughout.
       Follow these steps after you copy the demo disk to another
disk.
     <enter> means press enter.
1.  Put the COPY of this DEMO disk into Drive one.
2.  FROM EA menu press 2 for ASSEMBLER.
3.  TYPE:      DSK1.TEST-INPUT <enter>.
4.  TYPE:      DSK1.TEST-OBJ   <enter>.
5.  TYPE:      DSK1.TEST-LIST  <enter>.
6.  TYPE:      LCSFPF          <enter>.
7.  TYPE:                      <enter>.
8.  TYPE:                      <enter>.
9.  From EA menu press 3 for LOAD AND RUN.
10. TYPE:       DSK1.LINK      <enter>.
11. From GPL LINKER sceen:
12. TYPE:       DSK1.TEST      <enter>.
13. TYPE:       CG0            <enter>.
14  TYPE:                      <enter>.
15. Now run the EA5 program on disk one you made named TEST.
Enjoy...   Rich
Listing of TEST-COPY
* COPY-FILE FOR  GPL-ASSM              *
* TEXT FOR DISPLAY OF STRING   'HELLO' *
       HOME              * = DCLR @YPT
       FMT               * BEGIN FMT-ROUTINE
       FOR  COPIES       * COPIES IS LOOP COUNTER
       COL  26           * COLUMN 26
       HTEX 'HELLO'      * STRING 'HELLO' TEXT
       ROW+ 2            * ROW PRESENT VALUE +2
       FEND              * END 'FOR'
       FEND              * END FMT
Listing of TEST-INPUT
* EXAMPLE PROGRAM  in GPL (GPL-ASSM)   *
* ASSEMBLER DIRECTIVES
       TITL 'GPL-EXAMPLE PROGRAM1'
       OFFS 0              * NO LOAD-OFFSET (DEFAULT)
       GROM >6000          * FIRST GROM (DEFAULT)
       AORG >0000          * BEGIN AT ADDRESS 0 (DEFAULT)
* STANDARD GROM-HEADER
       DATA GROMID,0,0     * STANDARD ENTRY VECTOR FOR MODULES
       DATA POINTR,0,0,0,0
* START LABEL POINTERS
POINTR DATA 0,START        * NO FURTHER POINTERS
       STRI 'GPL TEST'     * START NAME INCL. BYTE LENGTH
* DEFINED SYMBOLS
GROMID EQU  >AA01          * PREDEFINED FOR STANDARD-GROMS
BLANK  EQU  ' '            * MUST BE EQUATED !!
NORMAL EQU  >07            * 'NORMAL' COLOUR AS IN BASIC
LINLEN EQU  32             * LINE LENGTH(32 COLUMNS)
SCRLEN EQU  24*LINLEN      * SCREEN LENGHT(24 ROWS)
BUFFER EQU  >1000          * BUFFER IN VDP
COLBUF EQU  FAC            *  'DEFAULT'-SYMBOL USED!
COUNTR EQU  FAC+1          * DITO
COPIES EQU  12             * COUNT USED IN COPY FILE
* PROGRAM START
START  ALL  BLANK          * CLEAR SCREEN
* SCREEN SET IN COPY FILE
       COPY 'DSK1.TEST-COPY'
* CONTINUE WITH MAIN PROGRAM
       CLR  @COLBUF               * SET COLOUR '0'
LOOP1  ST   LINLEN,@COUNTR        * SET COUNTER
LOOP   MOVE 1,@COLBUF,#7          * SCREEN COLOUR REGISTER 7 (VDP
REGISTER)
       MOVE SCRLEN,V@0,V@BUFFER   * GENERATE COPY OF SCREEN
       ST   V@0,V@BUFFER+SCRLEN   * COPY FIRST CHARACTER IN REAR
       MOVE SCRLEN,V@BUFFER+1,V@0 * REBUILD SCREEN
       SCAN                       * SCAN KEYBOARD FOR INPUT?
       BS   EXIT                  * NO = CONTINUE
       DEC  @COUNTR               * DECREMENT COUNTER
       CZ   @COUNTR               * ONE NUMBER DONE?
       BR   LOOP                  * IF NO - REPEAT
       INC  @COLBUF               * NEXT COLOUR
       BR   LOOP1                 * FROM THE TOP
EXIT   ALL  BLANK                 * CLEAR SCREEN
       BACK NORMAL                * RESET STANDARD COLOUR
       EXIT                       * PROGRAM END
       END
HOW TO ASSEMBLE AND RUN YOUR SECOND GPL PROGRAM!
3.  TYPE:      DSK1.SPRITESRC  <enter>.
4.  TYPE:      DSK1.SPRITEOBJ  <enter>.
5.  TYPE:      DSK1.SPRITELIST <enter>.
7.  TYPE:                      <enter>.
8.  TYPE:                      <enter>.
9.  FROM EA menu press 2 for ASSEMBLER.
10. TYPE:       DSK1.SCEDITSRC <enter>.
11. TYPE:       DSK1.SCEDITOBJ <enter>.
12. TYPE:       DSK1.SCEDITLST <enter>.
13. TYPE:       LCSFPF         <enter>.
14. TYPE:                      <enter>.
15. TYPE:                      <enter>.
16. From EA menu press 3 for LOAD AND RUN.
17. TYPE:       DSK1.LINK      <enter>.
18. From GPL LINKER screen:
19. TYPE:       DSK1.DEMO      <enter>.
20. TYPE:       C,L            <enter>.
21  TYPE:                      <enter>.
22. FROM EA menu press 3 for LOAD AND RUN.
23. TYPE:       DSK1.LINK      <enter>.
24. From GPL LINKER screen:
25. TYPE:       DSK1.DEMQ      <enter>.
25. TYPE:       C,N,G1         <enter>.
26. Now run the EA5 program on disk one you made named DEMO.
Enjoy...   Rich
L.D.O.M. 10.31.1998 by D.H.E.
ÿÿÿÿÿ
d:\tistuff\chicag98
