SecondBASIC Studio HBLANK Example
Gemintronic
dra600n of Second Dimension posted a small HBLANK example I'd like to share here.  Basically, if you want to mess with the display on a certain scanline this is how you do it.  In this example we're changing out a whole palette on a certain line.  This is good if you want a status bar with a different set of palettes or a water effect like in Sonic 3.
Note that you will most likely get artifacts like "CRAM dots" if you mess with hblank even a little.
    hBlank 111
    On hInt GoSub hbl
    On vInt GoSub vbl
    Enable hInt
    Enable vInt
    hint_counter = 111
    End
vbl:
    Palettes pal1,0,0,16
    j = JoyPad(0)
    If j.0 = 1 Or j.1 = 1 Then
        hint_counter+=j.1-j.0
        hBlank hint_counter
    End If
    Return
hbl:
    Palettes pal2,0,0,16
    Return
pal1:
    DataInt $0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000
pal2:
    DataInt $0EEE,$0000,$0000,$0000,$0000,$0000,$0000,$0000
