Pab Posted October 1, 2022 Share Posted October 1, 2022 I'm working on rewriting my Action! library of SpartaDOS routines to use calls under SDX 4.4+ instead of the old "under OS" vectors and the link. The problem is that when I look up the symbols for most calls (U_GETPAR, U_GEFINA, U_GETADR, U_GONOFF, U_SLASH, U_TOKEN, U_GETATR, and U_EXPAND) it seems that none of them are in the symbol table. This is the ML code I'm using to lookup a symbol (pointed to by A and X registers as passed through Action!): JSR $07EB BPL OUT ERR LDA #$00 LDX #$00 OUT STA $A0 STX $A1 RTS And here are the byte arrays passed to look up each symbol: BYTE ARRAY t_igettd(9)=['I '_ 'G 'E 'T 'T 'D 32 0] BYTE ARRAY t_isettd(9)=['I '_ 'S 'E 'T 'T 'D 32 0] BYTE ARRAY t_ugetpar(9)=['U '_ 'G 'E 'T 'P 'A 'R 0] BYTE ARRAY t_ugetnum(9)=['U '_ 'G 'E 'T 'N 'U 'M 0] BYTE ARRAY t_ugetadr(9)=['U '_ 'G 'E 'T 'A 'D 'R 0] BYTE ARRAY t_ugonoff(9)=['U '_ 'G 'O 'N 'O 'F 'F 0] BYTE ARRAY t_uslash(9)=['U '_ 'S 'L 'A 'S 'H 32 0] BYTE ARRAY t_utoken(9)=['U '_ 'T 'O 'K 'E 'N 32 0] BYTE ARRAY t_ugefina(9)=['U '_ 'G 'E 'F 'I 'N 'A 0] BYTE ARRAY t_ugetatr(9)=['U '_ 'G 'E 'T 'A 'T 'R 0] BYTE ARRAY t_file_p(9)=['F 'I 'L 'E '_ 'P 32 32 0] BYTE ARRAY t_uexpand(9)=['U '_ 'E 'X 'P 'A 'N 'D 0] When I do the lookups, all the symbols except I_GETTD, I_SETTD, and FILE_P show up as missing. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
