5200 OE HSC Challenge 10/2022 Super Breakout
zylon
In this 40th year of the 5200, we'll break out the original pack-in game, Super Breakout. We'll run the "Cavity" mode of the game. Play on original 5200 systems, using Atari Mfg controls. For this game, I'd suggest opening a controller and just using the L-R pot to turn like a paddle knob. If doing so, note the directions will be reversed. Switching the outer wire to the opposite side terminal, will fix that. Only modern exceptions are flashcarts/SD loaders running original Roms. Pics preferred, but not required, except for HSC wins and records.
Round ends when month does.
*for this round, anything made from actual 1980's Atari parts, in a cx52, can be used for control* -1 hsc pt handicap for doing so, as just opening controller as I mentioned, will yield same results. For those using the stick, I recommend using a thumb on top of stick, hold.
Current HSC record, bust it for a bonus point!
Super Breakout -
(Cavity Mode)
jnice 2,499
Final scores-
2,063  phuzaxeman +11
603  rubeon +10
466  Crazy Climber +9
430  DamonicFury +8
430  zylon +8
386  RangerG +7
Current standings-
DamonicFury - 98
rubeon - 90
RangerG - 59
zylon - 59
jeremiahjt - 50
jetset - 40
mark griff - 35
IICCEEMMAANN - 15
Cafeman - 9
SINGLE TOOTH - 8
jerry32 - 6
Super Breakout.BIN
Edited by zylon
  • The topic was pinned
I don’t suppose replacing the 5200 pot with a 2600 paddle pot and attaching its knob would be considered legitimate?   Still all OE Atari equipment, just with some of it originally meant for another console.
  • Haha 1
Go for it. The 2600 was already out and preexisting. I'll have to work up a handicap on those perhaps. I made one ages ago, and just found it.
Edited by zylon
On 10/8/2022 at 5:41 PM, phuzaxeman said:
Just wondering why you would make this suggestion.  The controls work amazing (when working) and really utilize the 5200 analog advantages.
I don’t know that the cx-52 stick is quite as good as a 2600 paddle with a 2600 Breakout game, but its certainly not bad.  My 2600/5200 hybrid paddle seems to have become rather prone to glitches, so I stuck with the stick.
430
430
The mods look actually cool. I just grew up with 5200 sticks.
beats having to calibrate the system every time, and with the shorter throw, you can move further, faster. In my case, I can play Gyruss, or Super Breakout, but not both, without adjusting calibration. Once, I just tried tweaking the pot arm over a bit, then played a bit for testing. I found it quite good.
4 hours ago, DamonicFury said:
Very impressive!
Sure do love to see that RF fuzz on a CRT, the way the gods intended it to be.
Original controllers (updated), 5200, and that stock tube TV.
I do hook up the 5200 occasionally to a screen monitor but the tube TV is fun. Memories.
can't do it in the UK unfortunately, all the TV frequencies are different! no channel 3 at all.  I had to solder up an S-Video graphics circuit to get mine to work, but it's still hooked up to a tube so it looks like I remember it 🙂
Major kudos on importing a 5200 and modding it to work with a TV over there. 👍
interestingly, though the 5200 completely lacks the circuitry for it, the PAL Atari 800XL that I have just outputs s-video like it's no big thing. I was looking forward to modding it, but I've been using it for years now and have never even opened the case 🙂
  • 2 weeks later...
430
Mine has a shot flexi. Even a screwdriver across fire button contacts won't release a ball. At last minute, hit same score as you. Was stuck on 429 forever...
Edited by zylon
Da phuz takes Halloween with a score nearly beating the HSC combined effort, using stock controller. 👍 Thanks to all who played and continue to celebrate the 5200 as it was intended. I'll get next round up tomorrow morning. :) Bit of headache from combined shooting black powder colt 1851 replica, and cleaning my Steyr 1888, while I had the stuff out.
Final scores-
603  rubeon +10
430  DamonicFury +8
430  zylon +8
386  RangerG +7
Edited by zylon
  • The topic was unpinned
