new original game - codename jagYONG
joeyaage
Hello, I have been steadily writing a new game with Raptor API. I already have had some success with Hellgate but have got a bit stuck (not without ideas).
what you see is two separate sprites on the screen that are displayed correctly after initialising in rapinit.s.
I am trying to change position of the sprites like I have already achieved in Hellgate like this:
			lea		RAPTOR_sprite_table+(ID_ai_player*sprite_tabwidth),a0				; point to RAPTOR object table
			move.w	sprite_x(a0),d0														; get player current X position
			move.w	sprite_y(a0),d1														; get player current Y position
			move.w  #150,d0																; initial player X pos.
			move.w  #150,d1																; initial player Y pos.
			move.w	d0,sprite_x(a0)														; store the new x-position
			move.w	d1,sprite_y(a0)														; store the new y-position
What I don't know yet is where in memory (.BSS) is the RAPTOR_sprite_table, is it correctly in address a0, why is it that changing the value of sprite_x and sprite_y has no effect.
From within a game loop I :
			jsr		RAPTOR_wait_frame_UPDATE_ALL										; +VSYNC and update the object list with initial values
			jsr		Player_Update_Position												; Move the player
I can't seem to change positions of the sprites at all.
8 hours ago, CyranoJ said:
Happy to take a look if you'd like to share the code,, either here (public) or via a private discussion.
Private message sent..
4 hours ago, 42bs said:
Do you really intent to set x,y to a fixed position? If so, why read x,y in the first place?
It's just left over code. I am aware there are wasted instructions.
Hooray! CJ to the rescue.
My problem was that I was defining sprite 'equ' as 0 - 'x number' for each of my 3 display lists. As soon as I defined all of the sprites from 0 -x number' across all three lists, my game and code magically came to life and now I can progress.
Anyway, not got far yet. Here is a taster...
jagyong15.ABS
  • Like 4
  • 5 months later...
I seem to be stuck on collision detection this time. I have these two subroutines called from the main loop. I don't think it ever goes to .was_hit after the bmi instruction.
What_Was_Hit:
.chk_hit:	tst.l	sprite_was_hit(a0)													; check if this object was hit
			bmi		.not_hit															; skip if not
.was_hit:	move.l	#-1,sprite_was_hit(a0)												; clear RAPTOR collision flag
			jsr		change_direction
.not_hit:	move.l	#$99900000,BG														; set background colour
			rts																			; exit
Check_Collisions:
			clr.l	raptor_result														; reset the RAPTOR collision flag
			move.l	#ID_player,raptor_sourcel										; Object ID for first bullet
			move.l	#ID_player,raptor_sourceh									; Object ID for last bullet
			move.l	#ID_ai_player,raptor_targetl											; Object ID for first enemy
			move.l	#ID_ai_player,raptor_targeth										; Object ID for last enemy
			lea		RAPTOR_GPU_COLLISION,a0												; now call the RAPTOR collision handler
			jsr 	RAPTOR_call_GPU_code
;			tst.l	raptor_result														; check the global collision flag
;			bmi		.no_hit																; if -ve, then nothing collided
;			bsr		change_direction													; otherwise lose a life
;			bra		.no_hit
.no_hit:	rts
Binary and source included (no data files, so won't assemble).
jagyong23.zip
Original games are funny, I keep running into existing games...jagYONG23.thumb.PNG.70dc6b41d8259079b43807ce21638a85.PNG
Well for a start they are commented out :)
;			lea		RAPTOR_sprite_table+(ID_ai_player*sprite_tabwidth),a0					; point to RAPTOR object table
;			move.w	sprite_x(a0),d0														; get player current X position
;			move.w	#-3,sprite_xadd(a0)
;			rts
It probably is working... once...
you need to set reset the collision flags after an impact:
sprite_was_hit needs to go back to -1, and its hitpoints will need to go back to 1.
