Pab Posted October 11, 2022 Share Posted October 11, 2022 My current project is being written in Action!, but a good chunk of the subroutines I will be using in it and as part of it are in machine language. To simplify the process of encoding machine language into Action! source, I wrote this quick-and-dirty utility I call OBJ2ACT. It was written and compiled in Fast Assembler as a relocatable SpartaDOS X command file. If there is call for it, I can rewrite parts of it to run under AtariDOS. I'm attaching an ATR file with the .COM file, source code, and a .MAN file. I'm also pasting the source code below for those who would rather cut-and-paste and assemble on their own than download. The program is in the public domain, free for use, modification, reimplementation, sharing, etc. * OBJ2ACT * Convert object files to Action! Source * By Pab Sungenis, 2022. Public Domain COMTAB smb 'COMTAB' PRINTF smb 'PRINTF' FPRINTF smb 'FPRINTF' U_GETPAR smb 'U_GETPAR' U_GETNUM smb 'U_GETNUM' FOPEN smb 'FOPEN' FGETC smb 'FGETC' FPUTC smb 'FPUTC' PUTC smb 'PUTC' FREAD smb 'FREAD' FWRITE smb 'FWRITE' FCLOSEAL smb 'FCLOSEAL' FCLOSE smb 'FCLOSE' U_SFAIL smb 'U_SFAIL' U_FAIL smb 'U_FAIL' U_XFAIL smb 'U_XFAIL' STATUS smb 'STATUS' srcstr equ $C6 deststr equ $C8 srcfile equ $CA destfile equ $CB datab equ $CC lnlen equ $CE scratch equ $D4 FHANDLE equ $760 FMODE equ $778 FAUX1 equ $782 FAUX2 equ $783 FAUX3 equ $784 FAUX4 equ $785 FAUX5 equ $786 SYSCALL equ $787 blk reloc main jmp start cpystr tya Copy one string into another. pha Adresses in srcstr and deststr cpylp lda (srcstr),y Bytes to copy in y sta (deststr),y dey bpl cpylp pla Bytes copied in A rts findext sta scratch See if there is an extension stx scratch+1 Y holds position if so $FF if not fx_lp lda (scratch),y cmp #'.' beq fx_out dey bmi fx_out jmp fx_lp fx_out rts ctrails lda _TRAILS Retrieve value from TRAILS sta scratch lda _TRAILS+1 sta scratch+1 ldy #0 lda (scratch),y rts ptrails pha Save new value in TRAILS lda _TRAILS sta scratch lda _TRAILS+1 sta scratch+1 ldy #0 pla sta (scratch),y rts writehex ldx destfile Write the hex value to file stx FHANDLE lda HexStr jsr FPUTC lda HexStr+1 jsr FPUTC lda HexStr+2 jsr FPUTC rts dta c'chngeex',b(0) chngeex lda #'.' Change the extension of a filespec sta (scratch),y tya Source in $D4/$D5, ext $D6/$D7 tax Y is position of dot in filespec adc scratch sta scratch Returns with new length in X. lda scratch+1 ASSUMES THREE CHARACTER EXTENSION adc #0 sta scratch+1 ldy #2 ce_lp lda (scratch+2),y sta (scratch),y inx dey bpl ce_lp ldy #3 lda #$9B sta (scratch),y rts getfname lda #$A0 jsr U_GETPAR clc bne gfout sec gfout rts fload lda datab Open file in COMFNAM ldx datab+1 sta FMODE jsr FOPEN lda FHANDLE ldx datab+1 sta srcfile-1,x clc rts finit jsr getfname bcs fi_err jsr ctrails sta sfnlen lda _COMFNAM ldx _COMFNAM+1 ldy sfnlen jsr findext bpl fini_0 lda _COMFNAM sta scratch lda _COMFNAM+1 sta scratch+1 lda _OBJ sta scratch+2 lda _OBJ+1 sta scratch+3 ldy sfnlen jsr chngeex txa stx sfnlen jsr ptrails fini_0 lda _COMFNAM sta srcstr Copy it to variable lda _COMFNAM+1 sta srcstr+1 lda _srcfn sta deststr lda _srcfn+1 sta deststr+1 ldy sfnlen iny jsr cpystr lda #4 Open for read sta datab ldx #1 stx datab+1 jsr fload bcc fini_2 fi_err lda #$9C jmp U_FAIL fini_2 jsr getfname bcc fini_3 lda _srcfn Copy source file name sta srcstr lda _srcfn+1 sta srcstr+1 lda _COMFNAM sta deststr lda _COMFNAM+1 sta deststr+1 ldy sfnlen iny jsr cpystr lda _COMFNAM ldx _COMFNAM+1 ldy sfnlen jsr findext lda _COMFNAM sta scratch lda _COMFNAM+1 sta scratch+1 lda _ACT Change its extension to ACT sta scratch+2 lda _ACT+1 sta scratch+3 jsr chngeex txa jsr ptrails fini_3 jsr ctrails sta dfnlen lda _COMFNAM sta srcstr lda _COMFNAM+1 sta srcstr+1 lda _destfn sta deststr lda _destfn+1 sta deststr+1 ldy dfnlen iny jsr cpystr lda #8 Open for write sta datab ldx #2 stx datab+1 jsr fload bcs fi_err ldx srcfile Check the file header stx FHANDLE We want either SpartaDOS FA,FF jsr FGETC Or AtariDOS FF,FF pha jsr FGETC cmp #$FF bne fi_bad pla cmp #$FA beq fi_ok cmp #$FF beq fi_ok fi_bad pla jmp fi_err fi_ok rts mkhex ldx #2 Hex representation of byte lda datab mkh_lp pha and #$0f clc adc #$30 Numbers are from $30 to $39 cmp #$3a bcc mkh_0 clc adc #$07 Make it a letter mkh_0 sta HexStr,x pla lsr @ lsr @ lsr @ lsr @ dex bne mkh_lp lda #'$' sta HexStr,x rts gethdr clc ldx srcfile stx FHANDLE jsr FGETC Get first byte. cpx #$FF EOF? bne gh_get1 If not, continue. jmp endprog If so, end. gh_bad sec rts gh_get1 sta bstart Save the starting address jsr FGETC cpx #$FF beq gh_bad sta bstart+1 cmp #$FF Is the second byte $FF? bne getadds If not, it's an address. lda bstart cmp #$FA Sparta fixed block? beq gethdr If so, pull the next address cmp #$FF beq gethdr Atari fixed block? Do same. getadds jsr FGETC bpl gh_get4 jmp gh_bad Error reading from file. gh_get4 sta bend jsr FGETC bpl gh_get5 jmp gh_bad gh_get5 sta bend+1 We have the ending address. gh_math sec lda bend sbc bstart sta seglen lda bend+1 sbc bstart+1 sta seglen+1 inc seglen Get the segment length. bne gh_out inc seglen+1 gh_out jsr PRINTF dta c'Module from %4x to %4x (%d bytes).',b($9B,$0) dta v(bstart),v(bend),v(seglen) clc Success rts writeEOL lda #$9B ldx destfile stx FHANDLE jsr FPUTC rts writesp lda #$20 ldx destfile stx FHANDLE jsr FPUTC rts mainloop ldx srcfile stx FHANDLE jsr FGETC Get byte from source file cpx #$FF beq ml_out EOF? sta datab jsr mkhex Convert to hex string jsr writehex Write it. jsr writesp dec lnlen How many bytes in this line? bne ml_0 If 8, start next line. jsr writeEOL jsr writesp lda #8 sta lnlen ml_0 lda cnter Are we done with this block? cmp bend bne ml_1 lda cnter+1 cmp bend+1 beq ml_out ml_1 inc cnter bne mainloop inc cnter+1 bne mainloop ml_out rts vtrap dta v(trap) trap cmp #$9C bne trap_0 jsr PRINTF dta b($9B),c'Usage:',b($9b,$9B) dta c'OBJ2ACT sourcefile[.ext] [destfile[.ext]]',b($9b) dta b($9b,0) lda #0 trap_0 sta STATUS jmp FCLOSEAL start lda vtrap ldx vtrap+1 jsr U_SFAIL jsr finit jsr PRINTF dta b($9B),c'Encoding %s to %s',b($9B,$00) dta v(srcfn),v(destfn) st_lp jsr gethdr bcs endprog ldx destfile stx FHANDLE jsr FPRINTF dta c';%4x-%4x (%d bytes).',b($9B,$0) dta v(bstart),v(bend),v(seglen) lda #'[' jsr FPUTC lda #8 sta lnlen lda bstart sta cnter lda bstart+1 sta cnter+1 jsr mainloop lda #']' ldx destfile stx FHANDLE jsr FPUTC lda #$9B jsr FPUTC jsr FPUTC ldx srcfile stx FHANDLE jmp st_lp endprog jsr FCLOSEAL jsr U_XFAIL lda #1 sta STATUS rts _srcfn dta v(srcfn) _destfn dta v(destfn) _sfnlen dta v(sfnlen) _dfnlen dta v(dfnlen) _COMFNAM dta v(COMTAB+$21) _TRAILS dta v(COMTAB+$1A) objex dta c'OBJ' actex dta c'ACT' _obj dta v(objex) _act dta v(actex) srcfn equ * destfn equ srcfn+30 sfnlen equ destfn+30 dfnlen equ sfnlen+1 bstart equ dfnlen+1 bend equ bstart+2 headr1 equ bend+2 headr2 equ headr1+2 cnter equ headr2+2 HexStr equ cnter+2 seglen equ HexStr+1 blk empty 78 main blk update addresses blk update symbols end obj2act.atr 3 3 Quote Link to comment Share on other sites More sharing options...
