"Fog" on screen
Mostro Joe
Hi everyone! A few days ago I just turned on my old Intellivision (it is more than 40 years old). Las time I did it, everything was fine. This time instead a sort of "fog" has appeared on screen.
Audio, controls and colors are really ok. The quality of the image is not.
Any idea about the problem?
Yes, I have put the modulator lever fully on the "game" side. And yes, I have tried yet the fine tuning of the TV. I have also tried a brand new RCA cable.
What can be the reason of the "fog"?
Thanks!!
Do you mean static, that you would typically get with RF interference?  The cable should be RF insulated, typical av cables are not.  Do you have the original cable that came with the Intellivision.  You can also skip the switchbox and use a straight rca to f-connector adaptor.  Those switchboxes usually pickup some interference but not as much as an uninsulated cable.
A few other things to consider...
Connections themselves.  Make sure they're not corroded, dirty or broken.  Clean all contact points on the TV as well as INTV.  Make sure the Ch3/Ch4 switch is properly set in either and not in between.  Try each side of the switch as well.
And... Believe it or not.  Make sure there is no LED light near the Intv.  The RF coming off some of these LED bulbs will give off static.  I found that out as well.   Drive myself to madness until I turned off the light...crystal clear picture.
Best way to run these now is what Mr.mr said above.  Straight in to the F port via the RCA adaptor.
  • 4 weeks later...
Sorry, I'm very late in replying, but I had no time for plugging in again my Intellivision to the TV.
So I'm sending a photo of the problem.
I'm starting to think it could be RF Modulator (UM1285-8). It can be a problem because it seems replacement parts are no more available.
Edited by Mostro Joe
