Grevle Posted October 14, 2022 Share Posted October 14, 2022 (edited) My game Dracula Story is only missing a title tune , and i'm no musician. So i have a simple two tone music engine ready. I't Plays two channels pokey clearnote. It reads Byte in this format Example .BYTE $0,$58,$50,$55,$50,$60,$40,$40,$60,$50,$55,$50,$60,$70,$70 - For channel 1 and one more like this for channel 2 with is normally the bass notes. Not to long tune. perhaps max 60 notes. Setting $0 shuts off that channel until next note is set . useful for the bass note mostly Tempo is controlled by having two of the same notes after each other. then it will play that note twice as long All i need is the right byte data for a fitting titletune. Anyone have some data like this i can use ? Thank you. Tried make one myself. The most annoying tune. lol TST.xex Edited October 14, 2022 by Grevle 2 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted October 14, 2022 Share Posted October 14, 2022 I'm not a musician, but check out the book The Musical Atari and you'll find several tunes that are easy to convert to assembler. 😉 1 Quote Link to comment Share on other sites More sharing options...
VinsCool Posted October 15, 2022 Share Posted October 15, 2022 What do the bytecode mean in musical notation? Is there a chart for notes? 1 Quote Link to comment Share on other sites More sharing options...
ivop Posted October 15, 2022 Share Posted October 15, 2022 (edited) It looks like your data are just frequencies and zero is silence? For a spooky sound track to fit the Dracula theme, try something in the Phrygian scale of E. On a piano, that's playing from E to e on the white keys. Very simple, but not your regular do-re-mi. E F e f E F e f is a popular spooky motive. Or f e B F E. That one is used a lot in TV Shows, like Who Wants to Be a Millionaire? If you share the source of the small player, I might be able to come up with something. Edit: and E F E F repeated ad infinitum is Jaws Edited October 15, 2022 by ivop 1 Quote Link to comment Share on other sites More sharing options...
Grevle Posted October 16, 2022 Author Share Posted October 16, 2022 (edited) Here's the simple engine for 1 channel tune.. ; 1 CHANNEL MUSIC *= 37000 SOUNDC = 1600 TITMS = 1601 LDX #0 ; INITILASE POKEY STX 53768 LDX #3 STX 53775 LDX #0 STX 20 MAIN JSR TITLETUNE JMP MAIN TITLETUNE LDY TITMS CPY #1 BEQ VLA LDX #170 STX 53761 LDY #1 STY TITMS LDX #0 STX SOUNDC VLA LDX 20 ; Check RT clock CPX #10 ; tempo for tune BCC HOI LDX #0 STX 20 LDX SOUNDC INC SOUNDC LDA TUNE,X STA 53760 LDX SOUNDC CPX #57 ; number of notes BCS VLO HOI RTS VLO LDX #0 STX TITMS JMP TITLETUNE TUNE ;v3 v4 v5 .BYTE 50,55,50,50,50,50,0,50,50,60,70,75,80,85,85,80,80 .BYTE 0,0,0,60,65,60,60,0,0,0 .BYTE 70,70,64,64,80,80,88,88,88,0,0 .BYTE 90,90,80,80,70,70,75,75,80,80,75,75,70,70,65,65,70 .BYTE 60,70,60,70,60,55,65,55,50,60,55,60,65,60,65,70,65,60,65,60,55,60,55,50,55,60 .BYTE 65,75,65,75,70,65,0,0,0 Edited October 16, 2022 by Grevle 1 Quote Link to comment Share on other sites More sharing options...
ivop Posted October 16, 2022 Share Posted October 16, 2022 Thanks! Is there a reason why you don't just use RMT or another music tracker? Quote Link to comment Share on other sites More sharing options...
Grevle Posted October 16, 2022 Author Share Posted October 16, 2022 1 hour ago, ivop said: Thanks! Is there a reason why you don't just use RMT or another music tracker? Yes. Out of memory. Turbobasic is used for some setups and to draw the backround still images, Then all gameplay and sfx and such is Assembler. Combined it uses a lot of memory. 1 Quote Link to comment Share on other sites More sharing options...
ivop Posted October 16, 2022 Share Posted October 16, 2022 14 minutes ago, Grevle said: Yes. Out of memory. Turbobasic is used for some setups and to draw the backround still images, Then all gameplay and sfx and such is Assembler. Combined it uses a lot of memory. I see. So how many bytes do you have free for a player plus data? Quote Link to comment Share on other sites More sharing options...
Grevle Posted October 16, 2022 Author Share Posted October 16, 2022 25 minutes ago, ivop said: I see. So how many bytes do you have free for a player plus data? Hmm around 200 bytes max. Quote Link to comment Share on other sites More sharing options...
ivop Posted October 16, 2022 Share Posted October 16, 2022 2 minutes ago, Grevle said: Hmm around 200 bytes max. O wow, that's really limited. I could do some notes, but that would be it. Or generative music like I did in several size coding competitions. I'm about to watch the cyclocross in Fayetteville (USA), but after that I might do some experiments and try to keep below 200 bytes. For the record, you boot Turbo Basic, do some initialization (I assume lots of pokes?), pre-draw some images, and then run your assembly code? Does it ever return to Turbo Basic or is it all assembly after that? I'm asking, because the pre-drawn images could be dumped as a binary file, and the init code is probably easily ported to assembly, which would bring you to the 100% assembly realm and more free memory But maybe that's too much work. And I like size coding Quote Link to comment Share on other sites More sharing options...
Grevle Posted October 16, 2022 Author Share Posted October 16, 2022 (edited) NO. it's kinda old fashion plot and drawto from custom character set. The way i use to do it back in 1983,old habit. But it works. hehe. It, jumps back and forth between Basic and assembly. for everytime a new screen is drawn. But This is my last Game with basic code in it. Will use Assembly only code for new projects. Edited October 16, 2022 by Grevle Quote Link to comment Share on other sites More sharing options...
ivop Posted October 16, 2022 Share Posted October 16, 2022 14 minutes ago, Grevle said: NO. it's kinda old fashion plot and drawto from custom character set. The way i use to do it back in 1983,old habit. But it works. hehe. It, jumps back and forth between Basic and assembly. for everytime a new screen is drawn. But This is my last Game with basic code in it. Will use Assembly only code for new projects. Okay, thanks! Jumping back and forth between TB and assembly is no easy feat to convert to 100% assembly So, size coding it is then But first some sports on the seeing-far! 1 Quote Link to comment Share on other sites More sharing options...
Grevle Posted October 16, 2022 Author Share Posted October 16, 2022 (edited) Ok Thank you..See private message Edited October 16, 2022 by Grevle Quote Link to comment Share on other sites More sharing options...
