Adventures Lock 'n' Chase (Keystone Kapers Hack)
alfredtdk
Adventures Lock 'n' Chase (NTSC / PAL)
Lock 'n' Chase was one of the first police and thief arcade games, where you are in a sort of maze, Pacman style, which served as the default model for many games in the 80s. Now you control the policeman who goes out to capture the famous thief of jewels and money, besides being a thief he is a master of magic and illusion. Watch out for his tricks and the creatures that come out of your hat to get in your way, like the famous rabbit-out-of-the-hat trick.
                                                         Old versions (NTSC / PAL)
Adventures Lock'n'Chase (Keystone Kapers Hack) (2022) (Alfredtdk) PAL.bin Adventures Lock'n'Chase (Keystone Kapers Hack) (2022) (Alfredtdk).bin
Edited by alfredtdk
3 hours ago, Bomberman94 said:
Here is a PAL check 😄: I like the new graphic elements/characters and your choice of colors!
Maybe you could change the walls (hard to see the bricks) and whilst man stands before closed lift, colors don’t differentiate much:
OK. Tell me if it got better.
I had already noticed this problem with the colors of the bricks in the NTSC version, that's why I released a second one that fixed it. I believe it should also be happening in the PAL version. But the closed elevator doors share the same color pattern with some objects (sprites) in the scene, I mean the radio and also the handrail of the escalators. I opted for the darkening of the elevator door, I hope the result was good, the same goes for the bricks.
