Donkey Kong (NES) Level 133 Fix?
Having gotten myself acquainted with the logic for what triggers the "kill screen" on both the arcade and NES versions of Donkey Kong, may I ask you how you guys have managed to come up with a fix for Level 133 on the latter version?
For your information, these are the links I visited to get this info:
http://www.donhodges.com/how_high_can_you_get.htm
(arcade version)
http://metopal.com/2012/03/24/porting-the-kill-screen/
(NES version)
What I wish to do to correct the kill screen for the NES DK is to make a similar fix as to what Don Hodges did for the arcade version.
Here's the original NES version code for the kill screen:
CB7E  A4 54     LDY $54      ; loads current level number into Y
CB80  C8        INY          ; increment level number by 1
CB81  20 D1 F4  JSR $F4D1    ; jump to subroutine to calculate level number tile
CB84  A9 00     LDA #$00     ; set sign of bonus number as positive
CB86  85 2C     STA $2C      ; store this number in variable
CB88  A9 80     LDA #$80     ; load A with max bonus timer value (8000 bonus points)
CB8A  88        DEY          ; decrement variable in Y by 1
CB8B  C0 04     CPY #$04     ; check if level number < 5
CB8D  10 03     BPL $CB92    ; check for negative flag
CB8F  B9 07 C2  LDA $C207,Y  ; load bonus timer value from memory
CB92  85 2E     STA $2E      ; store in bonus timer value queue
My proposed fix for this, based on Hodges' fix for the arcade version:
CB80  C0 03     CPY #$03     ; check if level number >= 4
CB82  90 02     BCC $CB86    ; if level 1, 2 or 3 (variables $00 thru $02), continue with code normally
CB84  A0 03     LDY #$03     ; otherwise, load Y with #$03 (level 4)
CB86  C8        INY          ; increment level number by 1 (only if for level variables $00 thru $02)
CB87  20 D1 F4  JSR $F4D1    ; jump to subroutine to calculate level number tile
CB8A  A9 00     LDA #$00     ; set sign of bonus number as positive
CB8C  85 2C     STA $2C      ; store this number in variable
CB8E  B9 07 C2  LDA $C207,Y  ; load bonus timer value from memory
CB91  85 2E     STA $2E      ; store in bonus timer value queue
What I want to do is make it check the level number right after it's loaded into the variable that is stored at $0054 in the game's RAM. We want to compute the bonus timer based on the level number, so that level 4 and up will always start with 8000 points on the bonus timer. If the level number is 4 or higher, then we set a carry flag for, and this means we also only want it to increment the level number if we're on levels 1, 2 or 3 (variables $00 thru $02). The subroutine jump to $F4D1, which follows the INY, must also be modified for a check to see if the level number is 9 or higher, and if we're at level 9, to keep it there via a similar carry flag.
~Ben
Edited by ColecoFan1981
