ray76it Posted October 23, 2022 Share Posted October 23, 2022 (edited) Hello and first of all I will apologize for the "noobness" of my questions. On request of my 9 years old child, I rescued my old TI 99/4a from my parents' garage. Surprisingly it is working (even if it was just sat into his original box without any other protection from dust and humidity). The problems are: 1) I don't have the original cassette recorder I was using in 80s and the one I'm trying to iuse now sometimes works and some other times don't. 2) the PAL antenna signal is noisy, and I am not skilled enough to understand wy. I don't know if it's because of the PAL adapter or the cable or the plug or the video card itself. I wanted to ask some very EASY ways to: 1) obtain a better video signal 2) tranfer data (programs or downloaded disk/cartidge/cassette images) from a PC to the TI99 3) save/load data directly from TI99 (avoiding cassettes preferably). points 2 and 3 could have the same solution maybe. The easiest way for me would be buying prompt hardware but I don't know where to search it and which one I should buy. Other solutions will be appreciated too. Thank you. PS: few minutes ago my TI stopped to turn on 😞 ... Maybe its the power supply... How can I test it? Edited October 23, 2022 by ray76it Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted October 23, 2022 Share Posted October 23, 2022 Hello Ray76 and welcome, I am Ciro from Italy (Roma). check also this thread where I explained about video signal output: Be sure also to read this Thread: 2 Quote Link to comment Share on other sites More sharing options...
Serafini Lapo Posted October 24, 2022 Share Posted October 24, 2022 Ciao Ray76it, benvenuto tra noi! Sono Lapo da Firenze (Italia) Anche io sono da poco in questa fantastica community. Provo comunque a risponderti. La scelta di "salvare" una Ti99 ti sarà ripagata nel tempo con tanto divertimento, credimi! Per te e tuo figlio. Allora: 1) Per il registratore, io mi sono armato di pazienza e ho aspettato ebay per acquistare l'originale Texas Instrument. È tutta un'altra cosa rispetto ad altri, molto robusto e affidabile. 2) per il segnale video, prova ad acquistare un cavo "composito". Devi avere la fortuna di avere un televisore compatibile con questo segnale. Aime' non esiste un metodo per vederlo.. devi tentare, ma il segnale composito è uno tra i migliori che puoi ottenere.. quindi per me vale la pena tentare! Altrimenti, sempre su ebay, trovi i cavi scart, che offrono un segnale ottimo! 3) Nelle FAQ troverai tutte le risposte. 4) per questo, esiste una cartuccia chiamata "Finalgrom" che ti permette di caricare tutti i giochi-programmi su SD e caricarli sulla tua Ti99! Ricorda di acquistare anche la sua "copertura" che non è altro che una cartuccia vuota con due comodi pulsanti, che, con un semplice montaggio, ti permetterà di sfruttarla a dovere e soprattutto di proteggere la scheda da polvere e cadute eventuali.. Spero di esserti stato in qualche modo utile e benvenuto ancora! Ciao Lapo. Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted October 24, 2022 Share Posted October 24, 2022 @Serafini Lapo Just to not create misunderstanding... The cable for the PAL version of the TI-99/4A need to be "Component" NOT "composite". Composite for the PAL version of the TI-99/4A is only Black&White if you will not create this modifying a modulator PHA2036/2030. 1 Quote Link to comment Share on other sites More sharing options...
Serafini Lapo Posted October 24, 2022 Share Posted October 24, 2022 11 minutes ago, ti99iuc said: @Serafini Lapo Just to not create misunderstanding... The cable for the PAL version of the TI-99/4A need to be "Component" NOT "composite". Composite for the PAL version of the TI-99/4A is only Black&White if you will not create this modifying a modulator PHA2036/2030. Grazie per la precisazione Ciro.🙏🏻 1 Quote Link to comment Share on other sites More sharing options...
ray76it Posted October 26, 2022 Author Share Posted October 26, 2022 Grazie a tutti per le risposte. Devo documentarmi un po' per capire come metterle in pratica (ad esempio: dove si può acquistare il device per inserire le schede SD nel TI?). Ma al momento devo fare resuscitare il computer che ha proprio smessi di accendersi... Mi sa che dovrò portarlo a far riparare. 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted October 26, 2022 Share Posted October 26, 2022 @ray76it I am sorry for the problem, Contact me if I can help in someway. Quote Link to comment Share on other sites More sharing options...
