+dhe Posted October 25, 2022 Share Posted October 25, 2022 Here is your chance to call the baby ugly! My main annoyances: Using a DB9 for both the joystick and cassette port. Almost no CPU RAM on bare console. Writing an interpreted language in GPL. Even the VIC and Sinclair people got to kick sand in my face, because you did for i=1 to 100 in ten minutes. 32K Interface - on an 8-bit bus with wait states. No headphone jack. Digital, not analog joystick interface. DMA lines not brought to the pbox. Soldering all the interrupt levels together. The transformer stays on, even when the unit is off. Hard to use on/off switch. Fctn-= to easy to reset basic. Out of the box, no way to load machine code - not that there was a place to load it. 6K GROMS - why 6? Why not 8K or 1 or 2? A memory map that looks like someone just started listing things that need a 'block'. A 90 degree GROM Port 3 Quote Link to comment Share on other sites More sharing options...
pixelpedant Posted October 25, 2022 Share Posted October 25, 2022 2 minutes ago, dhe said: No headphone jack. Clearly, 99/4 was best TI-99 all along. But seriously, I do use the headphone jack on my 99/4 pretty often, when I take it out. So fair enough. 4 1 Quote Link to comment Share on other sites More sharing options...
WhataKowinkydink Posted October 25, 2022 Share Posted October 25, 2022 5 minutes ago, dhe said: Hard to use on/off switch. LOL - Surely you speak of the silver units. I can remember near splitting my cuticle as a kid trying to turn it on 🤣 (Thankfully that issue was resolved with the beige units, but I still wish I had my Black and Silver Beauty) 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 25, 2022 Share Posted October 25, 2022 No. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted October 25, 2022 Share Posted October 25, 2022 Looks like someone had a rough day at work today 1 4 Quote Link to comment Share on other sites More sharing options...
matthew180 Posted October 25, 2022 Share Posted October 25, 2022 1 hour ago, dhe said: Using a DB9 for both the joystick and cassette port. Almost no CPU RAM on bare console. Writing an interpreted language in GPL. Even the VIC and Sinclair people got to kick sand in my face, because you did for i=1 to 100 in ten minutes. 32K Interface - on an 8-bit bus with wait states. No headphone jack. Digital, not analog joystick interface. You can attribute these to "cost". TI was (is?) cheap. GPL was to create lock-in for software. 16-to-8 bit bus was cost, and rumored to prevent the 99/4A from performing as well as the 990-minicomputer. 1 hour ago, dhe said: DMA lines not brought to the pbox. Soldering all the interrupt levels together. Design decisions, maybe cost. Probably additional attempts to not compete with the 990-minicomputer. 1 hour ago, dhe said: The transformer stays on, even when the unit is off. Hard to use on/off switch. Bad engineering. 1 hour ago, dhe said: Fctn-= to easy to reset basic. Can be disabled with E/A or XB carts. There is a CALL LOAD to prevent FCNT= 1 hour ago, dhe said: Out of the box, no way to load machine code Found out that is not the case. Look around the forum for breaking the 99/4A sandbox. For some reason I suddenly can't remember the name of the tool. 1 hour ago, dhe said: 6K GROMS - why 6? Why not 8K or 1 or 2? GROM is lame anyway. Again, die space == cost. 1 hour ago, dhe said: A memory map that looks like someone just started listing things that need a 'block'. Typical on computers of the era. I have never seen a memory map that was not greedy, or that looked like it was made with any forward thinking. 1 hour ago, dhe said: A 90 degree GROM Port Bad design, mostly. 4 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted October 25, 2022 Share Posted October 25, 2022 Writing an interpreted language in GPL. Even the VIC and Sinclair people got to kick sand in my face, because you did for i=1 to 100 in ten minutes. Originally TI was supposed to make a CPU that would natively run GPL like a FORTH CPU but ran out of time and money for project. It has been shown that a GPL or Forth CPU would be very fast. Also I put EA Assembly support into TI Basic GROMs you can download and use including running CALL LOAD("DSK#.FILENAME") I did this project several years ago and surprised more people do not use it. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted October 25, 2022 Share Posted October 25, 2022 9 minutes ago, matthew180 said: Found out that is not the case. Look around the forum for breaking the 99/4A sandbox. For some reason I suddenly can't remember the name of the tool When was that discovered? Before or after 2010? As far as I know, it was unknown back in the 80s. Quote Link to comment Share on other sites More sharing options...
Frozone212 Posted October 25, 2022 Share Posted October 25, 2022 TI's sprite system flies in the face of established 6502 programming. As a non standard basic, I get that they needed to keep up with the crowd but did you have to murder the memory map and make it HARDER for a newbie to make sprites? I still haven't come to grips with it. Everyone else can make games for it. I'm still trying to figure out their reasoning for a long string of hex numbers instead of straight binary that the Sinclair and Commodore machines use for sprites. My brain does not understand "e7158b2" or whatever. I can make a decent image out of 1's and 0's but that's all. Joysticks are hard as hell to get working and by TI's own admission, JOYST was not even written for the machine! Why put a legacy command on your new computer if it won't even work? It boggles my mind as to how this is acceptable. Also, ANSI blew apart so why use a dead basic language that's no longer backed. It's not like the GPL is hardcoded into the system. Surely someone can burn a new rom onto it and override the base software. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 25, 2022 Share Posted October 25, 2022 10 minutes ago, mizapf said: When was that discovered? Before or after 2010? As far as I know, it was unknown back in the 80s. 1984. 2 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted October 25, 2022 Share Posted October 25, 2022 The tape port and joystick port look too similar. 3 Quote Link to comment Share on other sites More sharing options...
RXB Posted October 26, 2022 Share Posted October 26, 2022 30 minutes ago, Frozone212 said: TI's sprite system flies in the face of established 6502 programming. As a non standard basic, I get that they needed to keep up with the crowd but did you have to murder the memory map and make it HARDER for a newbie to make sprites? I still haven't come to grips with it. Everyone else can make games for it. I'm still trying to figure out their reasoning for a long string of hex numbers instead of straight binary that the Sinclair and Commodore machines use for sprites. My brain does not understand "e7158b2" or whatever. I can make a decent image out of 1's and 0's but that's all. Joysticks are hard as hell to get working and by TI's own admission, JOYST was not even written for the machine! Why put a legacy command on your new computer if it won't even work? It boggles my mind as to how this is acceptable. Also, ANSI blew apart so why use a dead basic language that's no longer backed. It's not like the GPL is hardcoded into the system. Surely someone can burn a new rom onto it and override the base software. The entire menu and interface is built into the TI99/4A, the first screen you see is GPL, the Menu of cartridges and TI Basic are all GPL including all of TI Basic is GPL. 75% of XB is written in GPL. You might be confused as there is 18K of GROM and only 8K of ROM in the TI99/4A console. Also 80% of the ROM is devoted to GPL. 1 Quote Link to comment Share on other sites More sharing options...
matthew180 Posted October 26, 2022 Share Posted October 26, 2022 (edited) 49 minutes ago, mizapf said: When was that discovered? Before or after 2010? As far as I know, it was unknown back in the 80s. True, it was undiscovered BITD, however that does not mean it was not possible BITD. But the topic is not limited to a time frame of when something was known. Edited October 26, 2022 by matthew180 Quote Link to comment Share on other sites More sharing options...
matthew180 Posted October 26, 2022 Share Posted October 26, 2022 49 minutes ago, Frozone212 said: I'm still trying to figure out their reasoning for a long string of hex numbers instead of straight binary Hexadecimal is a compact way to represent binary (one hex digit for every 4-bits). I suspect the reason TI BASIC uses hex over binary for character definitions is due to memory use. Writing "F5" instead of "11110101" is 6 less characters to store in RAM, and that adds up quick for a lot of character definitions. Retro computers, especially the stock 99/4A, are very limited on RAM, so it makes a difference. 58 minutes ago, Frozone212 said: My brain does not understand "e7158b2" or whatever. I can make a decent image out of 1's and 0's but that's all. These days (and even BITD) there are great tools for designing character patterns and sprites, so just use those instead if the hex does not make sense to you. Check out Magellan from the resources sticky-thread here in the forum. All computers, retro or not, will require using and being comfortable with hex, once you get into them deep enough. Hex and computers go hand-in-hand. Personally I like that TI BASIC used hex to define graphics. It is a very elegant way to introduce a learner to hex, and help make the connection between binary and hex. 6 Quote Link to comment Share on other sites More sharing options...
Switch1995 Posted October 26, 2022 Share Posted October 26, 2022 SteveB’s TiCoded is my go to for character definition tools: http://lizardware.de/ 2 1 Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted October 26, 2022 Share Posted October 26, 2022 1 hour ago, matthew180 said: True, it was undiscovered BITD, however that does not mean it was not possible BITD. But the topic is not limited to a time frame of when something was known. It’s a loophole, an exploit, enabled by overflowing the device name buffer in OPEN. Was there ever a printed article about it? If it had been known and exploited BITD, around when TI dropped the E/A manual on our heads like an anvil, it would have gotten fixed in the V2.2 console . 1 Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted October 26, 2022 Share Posted October 26, 2022 I’m going to dump on the 99/4, clearly not TI’s brightest move. Phantom keys. Just when you thought the keyboard could not be any worse, you are holding down that bright orange SHIFT key and S to backspace, and some weird letter combo like SW creates the phantom Q. SHIFT-Q. Quit. Kablooey, the dreaded blue title screen of reset. BASIC had so many bugs, you could trash your program just by inspecting your variables during a breakpoint after making a CALL CLEAR. It put the fear into you every time the computer paused for even two seconds to collect its thoughts, I mean garbage. What’s this GOTO 32767 in my program? Yikes! I did not type that. My computer is about to freak out and erase my program! What a hideous number! To this day I hate and fear 32767. Keyboard overlays. Never the one you need, like someone at the library put on the overlay for Terminal Emulator, the Phantom Duplex Menace, and lost the plain one that tells you what key is BACK OR REDO TO START. Then you’re playing Munch Man, hot and heavy on those ASDX keys and WHOOPS, fingernail catches the overlay up and over the S key and it’s NEEEEEEEEERUM BING you’re dead. Better throw out that overlay. Who cares what key is REDO OR BACK. They’ll probably put back the overlay from Hunt the Wumpus or something, if it even had one, the sheer number of people who never understood that game. Boxcar peripherals. They refute themselves. Oops, I nudged the disk controller off the speech synthesizer because I wasn’t comfortable typing at that angle. External Disk drive terminators? What’s those? I’m supposed to remove a thingamajig from my perfectly good system before using my new $400 DSK2? I don’t like it. I’m turning off the power to this fancy DSK2, don’t need it today. I’ll just save my file to DSK1 now oh shrit what is I/O ERROR 66 and where is my previous disk contents??? But oh, the warm dusty smell of the 99/4 cooking the 70s shag carpet it rests on. The calming MMmmMMmmMMmmMMmm sound of the cursor blinking and fuzzing the RF Modulator. The exciting day you find the last bug you fat-fingered into the code from the game listing in 99er. So to preserve that happy feeling, you SAVE CS1, obediently rewind the cassette tape, and trash the only good backup you had. 4 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 26, 2022 Share Posted October 26, 2022 2 hours ago, matthew180 said: True, it was undiscovered BITD 12 minutes ago, FarmerPotato said: Was there ever a printed article about it? https://forums.atariage.com/topic/342847-things-that-annoy-me-about-the-994a/?do=findComment&comment=5144331 2 Quote Link to comment Share on other sites More sharing options...
youxia Posted October 26, 2022 Share Posted October 26, 2022 (edited) I, too, can't comprehend how is it possible that people who were pioneering an industry could make some bad moves/mistakes, at least "bad" in a context it seems to us, the armchair designers who have the benefit of 40+ years of hindsight. Edited October 26, 2022 by youxia 1 Quote Link to comment Share on other sites More sharing options...
matthew180 Posted October 26, 2022 Share Posted October 26, 2022 6 hours ago, OLD CS1 said: 1984. The capability of senior_falcon's "Playground" was documented in 1984? 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 26, 2022 Share Posted October 26, 2022 12 minutes ago, matthew180 said: The capability of senior_falcon's "Playground" was documented in 1984? The CS1 DSR buffer overflow was. 4 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted October 26, 2022 Share Posted October 26, 2022 4 hours ago, FarmerPotato said: External Disk drive terminators? What’s those? I’m supposed to remove a thingamajig from my perfectly good system before using my new $400 DSK2? I don’t like it. I’m turning off the power to this fancy DSK2, don’t need it today. I’ll just save my file to DSK1 now oh shrit what is I/O ERROR 66 and where is my previous disk contents??? Data signal termination is an electrical thing. Has nothing to do with TI's implementation of the computer. As long as you keep the cables connected and the termination at the end, it will work. Quote Link to comment Share on other sites More sharing options...
TheMole Posted October 26, 2022 Share Posted October 26, 2022 If fear of cannibalization of the mini computer line was the reason for some of the more egregious decisions, it's a textbook example of bad business decisions: if your own product can eat into revenues of another product line, so can anyone else's. Make the best product you can, or someone else will... 8 Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted October 26, 2022 Share Posted October 26, 2022 4 hours ago, TheMole said: If fear of cannibalization of the mini computer line was the reason for some of the more egregious decisions, it's a textbook example of bad business decisions: if your own product can eat into revenues of another product line, so can anyone else's. Make the best product you can, or someone else will... I wonder if that was a real concern or not. I mean, the 99/4A is clearly not built to the standards of a business application. Quote Link to comment Share on other sites More sharing options...
matthew180 Posted October 26, 2022 Share Posted October 26, 2022 16 hours ago, dhe said: Out of the box, no way to load machine code - not that there was a place to load it. 15 hours ago, matthew180 said: Found out that is not the case. Look around the forum for breaking the 99/4A sandbox. 15 hours ago, mizapf said: When was that discovered? Before or after 2010? As far as I know, it was unknown back in the 80s. 15 hours ago, OLD CS1 said: 1984. We all pretty much ignored this. 14 hours ago, matthew180 said: True, it was undiscovered BITD, FALSE! But I cannot edit my post, it seems. 12 hours ago, FarmerPotato said: Was there ever a printed article about it? YES! Just to capture the series of wrong assumptions about the CS1 buffer overflow, and the frustration of user "OLD CS1" (aptly confusing handle given the context of this topic) as we all ignored his post... I'm guilty of not following links to other threads (or Wiki articles, it seems). But I did read it today and I see the catalyst for the "Sandbox" also seems to come from that thread. The exploit to break out of the BASIC sandbox was known in 1984 and published in print. It appears to have been primarily used to get access to sprites from console BASIC. In 2017 sernior_falcon took it to the next level with the "Sandbox" tool (see development resource sticky-thread). This level of access could have been done BITD, and was to some extent in some BASIC software. 2 2 Quote Link to comment Share on other sites More sharing options...
