SteveB Posted November 6, 2022 Author Share Posted November 6, 2022 Thank you! I just did some speed-testing ... 6min to read all 8kB in XB, XB 2.8 or RXB 2021, but 5 seconds when compiled... I need to get this running with the compiler. Quote Link to comment Share on other sites More sharing options...
SteveB Posted November 6, 2022 Author Share Posted November 6, 2022 1 hour ago, Vorticon said: This document should help. I can't help noticing to slowly slide down the path into learning TMS9900 assembler ... Currently I transfer the resulting addresses from WDATA3 to WDATA7 manually to my XB program. With little reading I figured out to use "DATA WDATA3,WDATA4, ..." to have them handy to be PEEKed dynamically at >2000, >2002, ... Assembly helper routines incomming ... someday. 3 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted November 6, 2022 Share Posted November 6, 2022 Ah sorry I thought you already knew assembly. I do use direct CALL LOADs and CALL PEEKs to save and load an ongoing game session (a little over 4K) from low memory, and that is very slow (about 5 minutes) as you have already found out. I just did not have enough space in low memory to create ML save and load routines... Quote Link to comment Share on other sites More sharing options...
+RXB Posted November 6, 2022 Share Posted November 6, 2022 Many many years ago I published the source code for XB CALL INIT: IDT 'SUPPORTS' * VERSION FOR GROM * * THIS IS THE SUPPORT FOR 9900 ASSEMBLY LANGUAGE WITH * EXTENDED BASIC ON THE TI 99/4. THE CALL INIT * SUBPROGRAM WILL LOAD THIS ROUTINE INTO THE * EXPANSION RAM FROM GROM. TO LOAD THE OBJECT * INTO GROM THE OBJECT MUST BE TEXT EDITED. * IN THE FIRST RECORD CHANGE THE DATA AFTER THE * "9" TAG FROM "E000" OR "2000" TO THE ADDRESS * DESIRED AND CHANGE THE "7" TAG TO A "8" TAG. * NOTE: BSS INSTRUCTIONS CANNOT BE USED IN THIS * PROGRAM IN ORDER TO LOAD PROPERLY INTO GROM. * ON EQU 1 OFF EQU 0 DEBUG EQU OFF FOR DEBUGGER ADDRESSING * * ASMIF DEBUG=ON * ILFA EQU >FFF8 * SET EQU >00EC * ASMELS ILFA EQU >4000 SET EQU >00CE * ASMEND * * SYSTEM EQUATES * SCNKEY EQU >000E EXBASX EQU >6010 EXTENDED BASIC XML TABLES (BASE) BYTE EQU >830C OLDS EQU >8310 OLD VALUE PTR BEFORE EVALUATE SUB * ARGUMENT COUNT EQU >8312 NUMBER OF ARGUMENT SREF EQU >831C ERRCOD EQU >8322 PLACE TO RETURN ERROR CODE BASE EQU >8343 FAC EQU >834A SCTEMP EQU >8354 SCLEN EQU >8355 SCNAME EQU >8356 FAC6 EQU FAC+6 VSPTR EQU >836E VALUE STACK PTR MAXVDP EQU >8370 SNDADD EQU >83CC STFLGS EQU >83CE CRULST EQU >83D0 GPLWS EQU >83E0 GPL/EXTENDED BASIC WORKSPACE * WRVDP EQU >4000 Write enable for VDP VDPRD EQU >8800 VDP read data address VDPWD EQU >8C00 VDP write data address VDPWA EQU >8C02 VDP write address address * * ERROR EQUATES * ERRNO EQU >0200 2 Numeric Overflow ERRSYN EQU >0300 3 Syntax Error ERRIBS EQU >0400 4 Illegal after subprogram ERRNGS EQU >0500 5 Unmatched quotes ERRNTL EQU >0600 6 Name too long ERRSNM EQU >0700 7 String-number mismatch ERROBE EQU >0800 8 Option base error ERRMUV EQU >0900 9 Improperly used name ERRIM EQU >0A00 10 Image error ERRMEM EQU >0B00 11 Memory full ERRSO EQU >0C00 12 Stack overflow ERRNWF EQU >0D00 13 NEXT without FOR ERRFNN EQU >0E00 14 FOR NEXT nesting ERRSNS EQU >0F00 15 Must be in subprogram ERRRSC EQU >1000 16 Recursive subprogram call ERRMS EQU >1100 17 Missing subend ERRRWG EQU >1200 18 RETURN without GOSUB ERRST EQU >1300 19 String truncated ERRBS EQU >1400 20 Bad subscript ERRSSL EQU >1500 21 Speech string too long ERRLNF EQU >1600 22 Line not found ERRBLN EQU >1700 23 Bad line number ERRLTL EQU >1800 24 Line too long ERRCC EQU >1900 25 Can't continue ERRCIP EQU >1A00 26 Command illegal in program ERROLP EQU >1B00 27 Only leagal in a program ERRBA EQU >1C00 28 Bad argument ERRNPP EQU >1D00 29 No program present ERRBV EQU >1E00 30 Bad value ERRIAL EQU >1F00 31 Incorrect argument list ERRINP EQU >2000 32 Input error ERRDAT EQU >2100 33 Data error ERRFE EQU >2200 34 File error ERRIO EQU >2400 36 I/O error ERRSNF EQU >2500 37 Subprogram not found ERRPV EQU >2700 39 Protection violation ERRIVN EQU >2800 40 Unrecongnized character WRNNO EQU >2900 41 Numeric overflow WRNST EQU >2A00 42 String truncated WRNNPP EQU >2B00 43 No program present WRNINP EQU >2C00 44 Input error WRNIO EQU >2D00 45 I/O error WRNLNF EQU >2E00 46 Line not found * * ASMIF DEBUG=ON * AORG >E000 * ASMELS AORG >2000 * ASMEND * DATA NAMLNK XML LINK TO NAME LINK ROUTINE * FFA DATA IFFA FIRST FREE ADDRESS (FFA) POINTER LFA DATA ILFA LAST FREE ADDRESS (LFA) POINTER * HAA DATA >AA55 CONSTANT TO SIGNAL INITIALIZED MEM. * * UTILITY BLWP VECTORS * DATA UTILWS,NUMASG NUMERIC ASSIGNMENT DATA UTILWS,NUMREF NUMERIC REFERENCE DATA UTILWS,STRASG STRING ASSIGNMENT DATA UTILWS,STRREF STRING REFERENCE DATA UTILWS,XMLLNK LINK TO SYSTEM UTILITIES DATA UTILWS,KSCAN KEYBOARD SCAN DATA UTILWS,VSBW VDP single byte write DATA UTILWS,VMBW VDP multiple byte write DATA UTILWS,VSBR VDP single byte read DATA UTILWS,VMBR VDP multiple byte read DATA UTILWS,VWTR VDP write to register DATA UTILWS,ERR Return error code to EXENDED BASIC * * UTILITY WORKSPACE UTILWS DATA 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 R2LB EQU UTILWS+5 R4LB EQU UTILWS+9 * * D A T A C O N S T A N T S * CBH65 BYTE >65 EQBIT BYTE >20 * * * NAME LINK ROUTINE * ALC ROUTINE NAME IN FAC * NAMLNK MOV @LFA,R1 ADDRESS POINTER NAML10 CI R1,ILFA JEQ NAMERR NAME NOT FOUND * TEST NEXT NAME MOV R1,R0 R0=SOURCE LI R2,FAC R2=DESTINATION C *R0+,*R2+ TEST 2 BYTES JNE NAML20 C *R0+,*R2+ TEST 2 BYTES JNE NAML20 C *R0+,*R2+ TEST LAST 2 BYTES JNE NAML20 MOV *R0+,R0 NAME MATCHES GET CODE ADDRESS B *R0 AND BRANCH TO IT * NAML20 AI R1,8 NAME DOESN'T MATCH, GO TO NEXT ONE JMP NAML10 * NAMERR LI R0,ERRSNF "NOT FOUND" ERROR * * GENERAL ERROR RETURN * ERROR MOV R0,@ERRCOD ERR2 LWPI GPLWS B @SET * ERR MOV *R13,@ERRCOD JMP ERR2 * * * NUMERIC ASSIGNMENT UTILITY * * * * UTILITY ROUTINE NUMASG * A utility to allow a numeric value to be assigned * to a numeric variable or a numeric array passed * as an argument to sub. * The floating point variable to be assigned is in * FAC. * The stack has information for each argument. * For a simple numeric variable, the stack entry looks * like this : * ------------------------------------------------- * :Pointer to : >00 : :Pointer to : : * :S. T. entry : : :Value space : : * ------------------------------------------------- * For a array argument, the stack entry looks * like this: * ------------------------------------------------- * :Pointer to : : :Pointer to : : * :S. T. entry : : :Dim. info. : : * ------------------------------------------------- * REGISTER USAGE * R0 : Array element number or zero * R1 : Argument number * R0,R1,R2,R3,R4,R5,R6,R7,R8 are used in this * routine * * 5 types of arguments : * Identifier 0 : Numeric Expression * Identifier 1 : String Expression * Identifier 2 : Numeric Expression * Identifier 3 : String Variable * Identifier 4 : Numeric Array * Identifier 5 : String Array * * NUMASG MOV *R13,R0 For the change of the work space MOV @2(R13),R1 For the change of the work space BL @CKARG Check valid argument number and ******************** set up stack entry pointer in R5 ********* **** CHECK THE ARGUMENT IDENTIFIER IN CPU RAM ******************** **** A SIMPLE NUMERIC VAIABLE OR AN ARRAY REFERENCE ************** MOV R1,R3 Get the argument number DEC R3 Offset 1 AI R3,>8300 For CPU address MOVB *R3,R3 Get the one byte identifier in * CPU JEQ NUERR2 Can't do the assignment to a * numeric expression argument SRL R3,8 Make it double DECT R3 Flag 2 is for NUMERIC VARIABLE JNE NUM04 ********* FOR ASSIGMENT TO A SIMPLE NUMERIC VARIABLE ************* MOV R0,R0 In this case, R0 must contain 0 JNE NUERR2 ERROR : BAD ARGUMENT MOV R5,R3 Get the pointer to the stack entry INCT R3 Point to the ID byte of the * stack entry BL @GETV1 Get 1 byte (ID) from VDP * JNE NUERR1 ERROR : STRUNG NUMBER MISMATCH INCT R3 Point to the value space pointer BL @GET1 Get the value space pointer in R1 NUM00 LI R4,FAC Source is in FAC NUM01 LI R2,8 8 bytes to copy NUM02 MOVB *R4+,*R1+ Move ONE byte DEC R2 Decrement the counter - done? JGT NUM02 No - loop for more RTWP Yes - return to the caller ******** FOR ASSIGNMENT TO ONE ELEMENT OF AN ARRAY *************** **** R0 : ARRAY ELEMENT NUMBER R5 : POINTER TO STACK ENTRY ******* NUM04 BL @ARYBND Check array element within boundries * and fine the pointer to element in ERAM JMP NUM00 Go to the general code to move * from FAC to ERAM ****************************************************************** **** CHECK VALID ARGUMENT NUMBER AND SET UP STACK ENTRY ********** ****** POINTER IN R5 *********** CKARG MOV R1,R1 Argument number can't be 0 JEQ NUERR2 ERROR : BAD ARGUMENT SLA R1,8 Make one byte CB @COUNT,R1 Valid argument? JLT NUERR2 ERROR : BAD ARGUMENT SRL R1,8 Make it two byte again MOV R1,R5 Get the argument number SLA R5,3 8 bytes per stack entry AI R5,8 Skip the 8 bytes file name * on top of stack A @OLDS,R5 Add to the old stack pointer * R5 : Pointer to the stack entry RT ****************************************************************** ***** CHECK THE ARRAY ELEMENT NUMBER IS WITHIN BOUNDRIES ******* ARYBND MOV R11,R9 Save return address DECT R3 Flag 4 is for ARRAY JNE NUERR1 NO - Assume string argument * ERROR : STRING-NUMBER MISMATCH MOV R5,R3 Get the stack entry pointer BL @GET1 Get the S. T. entry pointer MOV R1,R3 R1 : Data register for GET1 * R3 : Address register for GET1 BL @GETV1 Get the 1st byte of S. T. entry JLT NUERR1 String bit is set - ERROR * STRING-NUMBER MISMATCH BL @ARY1 Go through this general routine BL @GET1 Get the pointer to ERAM in R1 S R4,R0 Check the BASE : 0 : O.K. * BASE : 1 : offset 1 SLA R0,3 8 bytes per element A R0,R1 Add to the pointer in ERAM B *R9 ****************************************************************** ARY1 MOV R11,R10 Save RTN address SLA R1,5 R1 still contains 1st buyte from * func bits * SRL R1,13 Shift back to use as a double ******* R1 : NUMBER OF DIMENSION, R5 : STACK ENTRY POINTER ******* MOV R1,R8 Save number of dimension for later MOVB @BASE,R4 Check the BASE SRL R4,8 Make it double JEQ NUM08 If BASE=0, INDEX=0 -- it's o.k. DEC R0 Decrement the INDEX JLT NUERR3 BASE=1, INDEX=0 --- ERROR * BAD SUBSCRIPT INC R0 Restore INDEX NUM08 LI R6,1 Initial value for accumulator MOV R5,R3 Put the stack entry pointer in R3 AI R3,4 Try to get the dim. info. pointer BL @GET1 Go to get the dim. info. pointer MOV R1,R3 Put it in R3 DECT R3 For the following INCT insturction: NUM10 INCT R3 Point to dimension information entry * 2-byte maximum per dimension BL @GET1 Get the dimension maximum in R1 INC R1 BASE=0, add 1 offset S R4,R1 BASE=1, O.K. MPY R1,R6 Get the maximum array index * R6 : accumulator MOV R6,R6 First 2 bytes must be 0 here JNE NUERR3 else BAD SUBSCRIPT MOV R7,R6 Get last two bytes result DEC R8 Decrement the counter * R8 : number of dimension JGT NUM10 Loop for more DEC R6 BASE=0 :element number must range * from 0 to (R6-1) A R4,R6 BASE=0 :element number range 1 -- R6 C R0,R6 User's INDEX must <= maximum INDEX JGT NUERR3 NO - ERROR : BAD SUBSCRIPT INCT R3 Points to value space which * contains pointer to the beginning * of array element value in ERAM B *R10 RTN ****************************************************************** NUERR1 LI R0,ERRSNM STRING-NUMBER MISMATCH B @ERROR Error out NUERR2 LI R0,ERRBA BAD ARGUMENT B @ERROR Error out NUERR3 LI R0,ERRBS BAD SUBSCRIPT B @ERROR Error out * * * NUMERIC REFERENCE UTILITY * * * * UTILITY ROUTINE NUMREF * A utility to allow reference to a numeric expression, * numeric variable or a numeric array passed * as an argument to sub. * The floating point variable assigned will be * in FAC after calling NUMREF. * The stack has information for each argument. * For a simple numeric variable, the stack entry looks * like this : * ------------------------------------------------- * :Pointer to : >00 : :Pointer to : : * :S. T. entry : : :Value space : : * ------------------------------------------------- * For a array reference, the stack entry looks * like this: * ------------------------------------------------- * :Pointer to : : :Pointer to : : * :S. T. entry : : :Dim. info. : : * ------------------------------------------------- * For a numeric expression, the stack entry has the * 8 bytes floating points value come back from * a parse. * REGISTER USAGE * R0 : Array element number or zero * R1 : Argument number * R0,R1,R2,R3,R4,R5,R6,R7,R8 are used in this * routine * * NUMREF MOV *R13,R0 For the change of the work space MOV @2(R13),R1 For the change of the work space BL @CKARG Check valid argument number * and set up stack pointer ****** R5 : Pointer to the stack entry, R1 : Argument number. *** ******** CHECK THE ARGUMENT IDENTIFIER IN CPU RAM **************** **** A NUMERIC EXPRESSION, SIMPLE NUMERIC VARIABLE OR AN ARRAY *** MOV R1,R3 Get the argument number DEC R3 Offset 1 AI R3,>8300 For CPU address MOVB *R3,R3 Get the one byte identifier in * CPU SRL R3,8 Make it double JNE REF00 Not a numeric expression **** A NUMERIC EXPRESSION, MOVE THE 8 BYTES STACK ENTRY ********** **** FROM VDP TO FAC. ********** MOV R0,R0 R0 in this case must contain 0 JNE RFERR2 ERROR : BAD ARGUMENT LI R2,8 8 bytes to move LI R4,FAC Destination address MOV R5,R3 Source address : stack entry pointer REF03 BL @GET1 Get 2 bytes from VDP MOV R1,*R4+ Put 2 bytes in FAC INCT R3 Update source address DECT R2 Update the counter JGT REF03 More to move RTWP Return to caller ********** SIMPLE NUMERIC VARIABLE OR AN ARRAY ******************* REF00 DECT R3 Flag 2 is for NUMERIC VARIABLE JNE REF04 NO - go to the code for array ****** FOR REFERENCE TO A SIMPLE NUMERIC VARIABLE **************** MOV R0,R0 In this case, R0 must contain 0 JNE RFERR2 ERROR : BAD ARGUMENT MOV R5,R3 Get the pointer to the stack entry INCT R3 Point to the ID byte of the * stack entry BL @GETV1 Get 1 byte (ID) from VDP * Numeric ID byte must be 0 JNE RFERR1 ERROR : STRING-NUMBER MISMATCH INCT R3 Point to the value space pointer BL @GET1 Get the value space pointer in R1 REF01 MOV R1,R4 Put the source address in R4 * for the "general move" code LI R1,FAC Desination address is in FAC B @NUM01 Goto the "general move" code and * return to caller ****** FOR ASSIGNMENT TO ONE ELEMENT OF AN ARRAY ***************** ****** R0 : ARRAY ELEMENT NUMBER, R5 : POINTER TO STACK ENTRY **** REF04 BL @ARYBND Check array element is within bounds * and find the pointer to the array element in ERAM JMP REF01 Go to the general code to move * from ERAM to FAC ****************************************************************** RFERR1 B @NUERR1 STRING-NUMBER MISMATCH RFERR2 B @NUERR2 BAD ARGUMENT * * * * STRING ASSIGNMENT UTILITY * * UTILITY ROUTINE STRASG * A utility to allow a string to be assigned to a * sting variable or one element of an string variable * array passed as an argument to subpro. * The stack has information for each argument. * For a string variable, the stack entry looks * like this : * -------------------------------------------------- * :Pointer to : >65 : :Pointer :string: * :Value space : : :to sting :length: * -------------------------------------------------- * For a string array, the stack entry looks like this: * ------------------------------------------------- * :Pointer to : : :Pointer to : : * :S. T. entry : : :Dim. info. : : * ------------------------------------------------- * USER'S REGISTER USAGE * R0 : Array element number or zero * R1 : Argument number * R2 : String address in ERAM, (the first byte * of the string is the length of the string.) ****************************************************************** * THIS ROUTINE REGISTER USAGE * R0 : Always is the string address in ERAM * except when routine ARY1 is called, * then has the array element number. * R1 : Argument number * R0, R1, R2, R3, R4, R5, R6, R7, R8, R9, R10 are used in * this routine * UTILWS workd space usage * UTILWS : Array element provided by user * UTILWS+2 : RTN address for VGASSN * UTILWS+4 : Temporary place for R5 when VPUSH, * GETSTR, ASSGNV are called. * UTILWS+6 : Temporary place for @BYTE when * GETSTR is called. * UTILWS+8 : RTN address for GPL * UTILWS+12 : String address in ERAM provided by user * * STRASG MOV *R13,@UTILWS Array element from user MOV @2(R13),@GPLWS+2 For change of work space * Argument number provided by user MOV @4(R13),@UTILWS+12 String address probided by user LWPI GPLWS Load GPL work space registers * which has string information * address in VDP MOV R11,@UTILWS+8 RTN address for back to GPL MOV @UTILWS+12,R0 ERAM string address is in R0 now BL @CKARG Check valid argument number and set * up pointer to stack entry in R5 MOV R1,R3 Get argument number DEC R3 Offset 1 AI R3,>8300 For CPU address MOVB *R3,R3 Get the one byte identifier in * CPU SRL R3,8 make it double DEC R3 Check if string expression JEQ STERR2 Can't do the assignment to a * string expression argument DECT R3 Flag 3 is for string variable JNE STARY NO : Is STRING ARRAY ? ******* ASSIGMENT TO STRING VARIABLE ***************************** MOV @UTILWS,R10 In this case : array element * has to be 0 JNE STERR2 ERROR : BAD ARGUMENT MOV R5,R3 Address register for GETV1 INCT R3 Point to the ID byte of the * stack entry BL @GETV1 Get 1 byte (ID) from VDP CB R1,@CBH65 Is this a string variable ? JNE STERR1 No - STRING-NUMBER MISMATCH ERROR ****************************************************************** **** PUSH THIS STACK ENTRY ON TOP OF THE STACK FOR *************** **** ROUTINE "ASSGNV" TO USE *************** ****************************************************************** **** MOVE THIS STRING VARIABLE ENTRY TO CPU FAC AREA ************* **** IN ORDER TO DO A VPUSH ************* LI R6,8 Number of bytes to move LI R4,FAC Destination address in CPU MOV R5,R3 Restore stack entry pointer * R3 : address register for GET1 STR02 BL @GET1 Get 2 bytes from VDP MOV R1,*R4+ Put to FAC area INCT R3 Update source address DECT R6 Update the counter JGT STR02 More to move ***** DO THE VPUSH, GETSTR, COPY STRING TO STRING SPACE ********** ***** AND ASSIGNMENT ********** BL @VGASSN ********* NOW UPDATES THE STACK ENTRY OF THIS ******************** ********* STRING VARIABLE ******************** ********* R5 STILL POINTS TO THE OLD STACK ENTRY ***************** ********* FOR THIS STRING VARIABLE ***************** AI R5,4 "POINTER TO STRING" entry MOV R5,R4 Address register for PUT1 MOV R6,R1 Put the pointer to string * (come back from ASSGNV) into data register for PUT1 BL @PUT1 Put 2 bytes of data to VDP INCT R4 "LENGTH OF STRING" entry MOVB *R0,R1 Put the length into data register SRL R1,8 Make it two bytes BL @PUT1 Put 2 bytes of data to VDP STRTN MOV @UTILWS+8,R11 Restore RTN address * MOV @UTILWS+6,@BYTE Restore @BYTE * LWPI UTILWS Go back to old workspace RTWP Return ****************************************************************** STERR1 LI R0,ERRSNM STRING-NUMBER MISMATCH ERRTN MOV @UTILWS+8,R11 Restore RTN address B @ERROR STERR2 LI R0,ERRBA BAD ARGUMENT B @ERROR Error return ****************************************************************** ************* Common routine for STRASG & STRREF to check ************* valid array element STARYC MOV R11,R2 Save RTN address DECT R3 Flag 5 is for string array JNE STERR1 ERROR : STRING-NUMBER MISMATCH MOV R5,R3 Get the stack entry pointer BL @GET1 Get the S.T. entry pointer MOV R1,R3 R1 : Data register for GET1 * R3 : Address register for GET1 BL @GETV1 Get the 1st byte of S.T. entry JLT STARY1 O.K. B @STERR1 ERROR : STRING-NUMBER MISMATCH STARY1 MOV @UTILWS,R0 Put array element in R0 now * for the general routine ARY1 BL @ARY1 Go through general routine to * check array element is out of bound * R4 : BASE, R0 : ARRAY ELEMENT, R3 : POINTER TO BEGINNING OF * VALUE SPACE S R4,R0 Check the BASE : 0 : O.K. * BASE : 1 : Offset 1 SLA R0,1 2 bytes per element A R0,R3 Pointer to the exact element we want BL @GET1 Get the string pointer B *R2 RTN ****************************************************************** ****************************************************************** STARY BL @STARYC Go through general routine * shared by STRREF * NOW R1 : POINTER TO THE OLD STING * R3 : POINTER TO THE VALUE SPACE *** SET UP FAC ENTRY AND PUSH IT ON STACK FOR ASSIGN ROUTINE ***** LI R6,FAC Desination address MOV R3,*R6+ Put pointer to value space in MOVB @CBH65,*R6+ Put >65 ID in MOVB R4,*R6+ Clear the unuse byte MOV R1,*R6+ Put the pointer to string in MOV R1,R3 Set up address register for GETV1 JNE STARY4 Not null pointer : o.k. CLR *R6 Clear the length bytes JMP STARY6 Go on STARY4 DEC R3 Point to string length BL @GETV1 Get the length from VDP SRL R1,8 Make it two bytes MOV R1,*R6 Put the length in FAC area ***** FAC ENTRY HAS BEEN SET UP NOW ****************************** STARY6 MOV @UTILWS+12,R0 Restore the ERAM string address * to R0 BL @VGASSN Do the VPUSH, GETSTR and ASSIGN ***** ASSIGNMENT WILL POP THE STACK, OLD STACK ENTRY ************* ***** DOES NOT NEED TO BE UPDATED IN THIS CASE ************* B @STRTN RTN ****************************************************************** ****************************************************************** VGASSN MOV R11,@UTILWS+2 Save return address ***** VPUSH changed R0, R5 ************************************ MOV R5,@UTILWS+4 ****************************************************************** MOV @>601E,R11 XML table address for VPUSH BL *R11 Do the VPUSH ********* RESTORE R0, R5 ***************************************** MOV @UTILWS+12,R0 MOV @UTILWS+4,R5 ****************************************************************** **** GETS THE STRING SPACE, COPIES THE STRING FROM ERAM ********** **** INTO VDP STRING SPACE, AND SETS UP THE FAC WITH A ********** **** STRING ENTRY OF THE FOLLOWING FORM: ********** **** -------------------------------------------- ********** **** : >001C : >65 : XX : POINTER : LENGTH : ********** **** : : : : TO STRING : OF STRING : ********** **** -------------------------------------------- ********** **** FAC +2 +3 +4 +6 ********** ****************************************************************** MOVB *R0,R6 R0 : Address of string (length by * & string) supplies by ALC SRL R6,8 Set up the length byte * MOV @BYTE,@UTILWS+6 Save @BYTE * MOV R6,@BYTE For GETSTR routine MOV R6,@FAC6 Set up length byte entry in FAC *********** GETSTR changes R0, R5 value ************************* ***************************************************************** MOV @>6012,R11 XML table address for GETSTR BL *R11 Call GETSTR routine MOV @UTILWS+12,R0 Restore R0 *********** SET UP FAC ENTRY ************************************ LI R6,FAC Optimize to save bytes LI R4,>001C Get address of SREF MOV R4,*R6+ Indicate a temporary string MOVB @CBH65,*R6+ Indicate a string MOVB R4,*R6+ Byte is not used MOV @SREF,*R6 Save pointer to the string *********** COPY THE STRING TO STRING SPACE ********************* MOV @BYTE,R2 Get number of bytes to copy JEQ STR04 If none to copy MOV *R6,R4 Get pointer to destination * R4 : address register for PUTV1 below MOV R0,R3 RO : pointer to string (length byte) INC R3 Skip the length byte pointer to string STR06 MOVB *R3+,R1 Get one byte from ERAM BL @PUTV1 Put 1 byte in VDP INC R4 Update the destination address DEC R2 1 less to move JGT STR06 If not done-loop for more * ASSGNV destroys all the registers STR04 MOV @>6028,R11 XML table address for ASSGNV BL *R11 Call ASSGNV ******** RESTORE R0, R5 ****************************************** MOV @UTILWS+12,R0 MOV @UTILWS+4,R5 MOV @UTILWS+2,R11 Restore RTN address RT * * * * STRING REFERENCE UTILITY * * * UTILITY ROUTINE STRREF * A utility to allow a reference to a string expression, * sting variable or a string array passed as an * argument to a subprogam. * * The stack has information for each argument. * For a string expression, the stack entry looks * like this : * -------------------------------------------------- * : >001C : >65 : : : : * :or Pointer to : : :Pointer :String: * :Value space : : :to sting :Length: * -------------------------------------------------- * >001C : For a temporary string * pointer to value space : for a perment string * For a string variable, the stack entry looks like this: * -------------------------------------------------- * :Pointer to : >65 : :Pointer to :String: * :S. T. entry : : :String :Length: * -------------------------------------------------- * For a string array, the stack entry looks like this: * -------------------------------------------------- * :Pointer to : : :Pointer to : : * :Value space : : :Dimension info: : * -------------------------------------------------- * * USER'S REGISTER USAGE * R0 : Array element number or zero * R1 : Argument number * R2 : String address in ERAM, (the first byte * of the string is the length of the string.) * Before calling STRREF : The string length has * the maximum length which indicates how many * spaces followed the length byte has been * allocated for the string. * After calling STRREF : The length byte has * the actual length of the string which * locates right after the length byte. * * * ****************************************************************** STRREF MOV *R13,R0 For the change of the work space * Array element now is in R0 MOV @2(R13),R1 For the change of the work space * Argument number is in R1 BL @CKARG Check valid argument number * set up pointer to stack entry in R5 MOV R1,R3 Get the argument number DEC R3 Offset 1 AI R3,>8300 For CPU address MOVB *R3,R3 Get one byte identifier in CPU SRL R3,8 Make it double DEC R3 Flag 1 is for string expression JEQ SRF01 String expression is o.k. DECT R3 Flag 3 is for string variable JNE STARYF Not string expression or variable, * must be string array in this case. ********** REFERENCE TO STRING EXPRESSION OR STRING VARIABLE ***** SRF01 MOV R0,R0 R0 must be 0 in this case JNE SRFER2 ERROR : BAD ARGUMENT MOV @4(R13),R0 Now move string pointer in ERAM * into R) MOV R5,R3 Address register for GETV1 INCT R3 Point to the ID byte of the * stack entry BL @GETV1 Get 1 byte (ID) from VDP CB R1,@CBH65 Is this a string varialbe ? JNE SRFER1 No - STRING-NUMBER MISMATCH ERROR INCT R3 Points to "pointer to string" BL @GET1 Get the "pointer to string" from * stack entry in VDP SRF03 MOV R1,R1 Is it null pointer ? JEQ SRF05 Yes - put 0 in length byte MOV R1,R6 R6 now contains "pointer to string" DEC R1 Points to the length byte of * this string in string space MOV R1,R3 Set up address register for GETV1 BL @GETV1 Get the 1 byte actual length * of this string in R1 CB *R0,R1 Compare the maximem length user * provided with the actual length JL SRFER3 Not enough space - ERROR * STRING-TRUNCATED ERROR SRF05 MOVB R1,*R0+ Enough space - o.k. * Put the actual length into the * length byte JEQ SRF08 0 byte length - don't move ******** R0 : Points to the allocated string space in ERAM ******* * Destination address register for the * following move MOV R6,R3 Set up address register for GETV1 * R3 now cantains "pointer to string" * Source address for following move SRL R1,8 Make actual length byte a double MOV R1,R5 R5 : number of bytes to move SRF07 BL @GETV1 Get 1 byte into VDP MOVB R1,*R0+ Put 1 byte into ERAM INC R3 Update the source address DEC R5 Update the counter JGT SRF07 More to move - loop back SRF08 RTWP Return to caller ****************************************************************** ************ REFERENCE TO STRING ARRAY *************************** STARYF BL @STARYC Check array element is within bound * and find the string element pointer in value space MOV @4(R13),R0 Put string address in ERAM provided * by the user into R0 now. (for the change of work space) JMP SRF03 Go to the general code to move * the string from VDP to ERAM ****************************************************************** SRFER1 B @NUERR1 STRING-NUMBER MISMATCH SRFER2 B @NUERR2 BAD ARGUMENT SRFER3 LI R0,ERRST STRING TRUNCATED B @ERROR Error out ****************************************************************** *** UTILITY ROUTINES TO ACCESS VDP **** ****************************************************************** ***** GET1 : Get two bytes of data from VDP ***** R3 : Address in VDP ***** R1 : Where the two bytes data stored GET1 SWPB R3 MOVB R3,@VDPWA SWPB R3 MOVB R3,@VDPWA NOP MOVB @VDPRD,R1 SWPB R1 MOVB @VDPRD,R1 SWPB R1 RT ***** PUT1 : Put tow bytes of data into VDP ***** R4 : Address on VDP ***** R1 : Data PUT1 SWPB R4 MOVB R4,@VDPWA SWPB R4 ORI R4,WRVDP MOVB R4,@VDPWA NOP MOVB R1,@VDPWD SWPB R1 MOVB R1,@VDPWD SWPB R1 RT ***** GETV1 : Get 1 byte of data from VDP ***** R3 : Address in VDP ***** R1 : Where the 1 byte data stored GETV1 SWPB R3 MOVB R3,@VDPWA SWPB R3 MOVB R3,@VDPWA NOP MOVB @VDPRD,R1 RT ***** PUTV1 : Put 1 byte of data into VDP ***** R4 : Address in VDP ***** R1 : Data PUTV1 SWPB R4 MOVB R4,@VDPWA SWPB R4 ORI R4,WRVDP MOVB R4,@VDPWA NOP MOVB R1,@VDPWD RT * * * LINK TO SYSTEM XML UTILITIES * XMLLNK MOV *R14+,@GPLWS+2 GET ARGUMENT LWPI GPLWS MOV R11,@UTILWS+22 Save GPL return address MOV R1,R2 CI R1,R2 JH XMLL30 IF SYSTEM XML WE HAVE ADDRESS MOV @EXBASX(R1),R2 Get address from XML table CI R1,4 Is it MEMCHK? JNE XMLL30 No MOV @2(R2),R2 BL *R2 Special case for MEMCHK DATA MEMERR Error return from MEMCHK JMP XMLL40 XMLL30 BL *R2 GO TO ROUTINE XMLL40 LWPI UTILWS GET BACK TO RIGHT WORKSPACE MOV R11,@GPLWS+22 Restore GPL return address RTWP MEMERR LI R0,ERRMEM B @ERROR * * * KEYBOARD SCAN * KSCAN LWPI GPLWS MOV R11,@UTILWS+22 Save GPL return address BL @SCNKEY LWPI UTILWS MOV R11,@GPLWS+22 Restore GPL return address RTWP * ** VDP single byte write * VSBW BL @WVDPWA Write out address MOVB @2(R13),@VDPWD Write data RTWP Return to calling program * ** VDP multiple byte write * VMBW BL @WVDPWA Write out address VWTMOR MOVB *R1+,@VDPWD Write byte DEC R2 Decrement byte count JNE VWTMOR More to write? RTWP Return to calling program * ** VDP single byte read * VSBR BL @WVDPRA Write out address MOVB @VDPRD,@2(R13) Read data RTWP Return to calling program * ** VDP multiple byte read * VMBR BL @WVDPRA Write out address VRDMOR MOVB @VDPRD,*R1+ Read byte DEC R2 Decrement byte count JNE VRDMOR More to read? RTWP Return to calling program * ** VDP write to register * VWTR MOV *R13,R1 Get register number and value MOVB @1(R13),@VDPWA Write out value ORI R1,>8000 Set for register write MOVB R1,@VDPWA Write out register number RTWP Return to calling program * ** Set up to write to VDP * WVDPWA LI R1,>4000 JMP WVDPAD * ** Set up to read VDP * WVDPRA CLR R1 * ** Write VDP address * WVDPAD MOV *R13,R2 Get VDP address MOVB @R2LB,@VDPWA Write low byte of address SOC R1,R2 Properly adjust VDP write bit MOVB R2,@VDPWA Write high byte of address MOV @2(R13),R1 Get CPU RAM address MOV @4(R13),R2 Get byte count RT Return to calling routine ************************************************************ * >24EA to >24F3 are not used (10 bytes unused) * ************************************************************ IFFA EQU >24F4 INITIAL VALUE FOR FFA FOR INIT END Quote Link to comment Share on other sites More sharing options...
SteveB Posted November 6, 2022 Author Share Posted November 6, 2022 4 minutes ago, RXB said: AORG >2000 * ASMEND * DATA NAMLNK XML LINK TO NAME LINK ROUTINE * FFA DATA IFFA FIRST FREE ADDRESS (FFA) POINTER LFA DATA ILFA LAST FREE ADDRESS (LFA) POINTER This means in >2000 (=NAMLNK) is the pointer to the procedure-table? Then I don't understand the CALL LOAD for XB256: I would expected something like below >3FFF in low memory? Where am I wrong? So all CALL LINK will crash when I overwrite >2000. Quote Link to comment Share on other sites More sharing options...
+RXB Posted November 6, 2022 Share Posted November 6, 2022 In XB >FFD4 is the first byte used by XB and it goes down to >A040 XB 256 is using >FF98 which is most likely the WORD in the XB program that has the address for his routines. So he replaced NAMLNK MOV @LFA,R1 ADDRESS POINTER with his own address for LFA into R1. See -4 is >FFFC and that address is >FFFC Workspace for LOAD Function (non-maskable interrupt, not DSK1.LOAD) And >FFFE is start of LOAD Function I would assume for XB 256 registers address and address for LOAD Function. Now 10574 is >294E and in XB CALL INIT that is the address he uses to run his routines I would guess. No way to show for sure as unlike him I show all my source code for last 30 years to help others do stuff. Also if I make mistakes people can correct me and the source code in future. If no one shows the source, then what is the point in such a small community that is shrinking? Quote Link to comment Share on other sites More sharing options...
