Shannon Posted November 8, 2022 Share Posted November 8, 2022 I was wondering if any of the following games ever got converted to a single disk images or to the MaxFlash cart..? 221B Baker Street Blade Of Blackpoole Bop'n Wrestle Field Of Fire Golf Championship Jinxter Jupiter Mission Lode Runners Rescue Mail Order Monsters Millionaire Mindshadow Pawn, The Phantasie Phantasie II Racing Destruction Set Seven Cities Of Gold Star Fleet I - The War Begins Universe Wargame Construction Set Thank you Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 8, 2022 Share Posted November 8, 2022 Fairly sure 7 Cities of Gold has writes to the disk during gameplay. Flashcarts aren't really suited to short, frequent write operations. The blocksize is such that multiple Kilobytes have to be read in then written back with the required changed data. I produced a memory resident single-load version of Spelunker some time back. Though it's a single side game and will write high scores to the disk (I didn't support that operation) Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 8, 2022 Share Posted November 8, 2022 (edited) The only one I have on that list is Millionaire by MPG... For the reasons Rybags says, it's not really suited to those other games. Things like AVG cart that support this sort of thing will do it, but it needs to be recoded to do that. PS, I imagine the flashcarts are like the way an SSD drive works ie there's a certain amount of writes before it starts to die (not really a worry as they can be written to a huge number of times. I imagine the flash carts have the same limitation, so have games that write back to them constantly perhaps is not the best option if you want the cart to carry on working for many many years I've not researched this, so I could be utterly wrong (people please correct me if I am wrong) Edited November 8, 2022 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
ivop Posted November 8, 2022 Share Posted November 8, 2022 (edited) 32 minutes ago, Mclaneinc said: PS, I imagine the flashcarts are like the way an SSD drive works ie there's a certain amount of writes before it starts to die (not really a worry as they can be written to a huge number of times. I imagine the flash carts have the same limitation, so have games that write back to them constantly perhaps is not the best option if you want the cart to carry on working for many many years I've not researched this, so I could be utterly wrong (people please correct me if I am wrong) You are right. Flash memory can be written to a limited amount of times. After that, it won't work anymore. That's why CF, SD, SSDs an the likes have wear leveling algorithms in their firmware. If you overwrite a block, it's not necessarily located at the same physical location afterwards as where it was before, in order to reduce wear (not constantly overwrite the same block) and increase the lifespan of the device. Edit: and most Flash ROM and EEPROM ICs don't have that, so you would have to do that in software yourself if you are going to store high scores on the cartridge. Edited November 8, 2022 by ivop 1 Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 8, 2022 Author Share Posted November 8, 2022 Thanks guys.. I figured the two most likely culprits were either custom read/write code or lack of interest in a particular game. I didn't think about the limitations of rewriting to flash carts too much. I'm mostly interested in these multidisk 2 cart images for emulation anyways. Just to save the hassle of disk swaps. I did forget to mention Gauntlet Deeper Dungeons. Which I know was converted.. but the guy created a Multi Game cart for that one. So it's not standalone. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted November 9, 2022 Share Posted November 9, 2022 Infocom titles Magnetic Scrolls The Serpent's Star Mask Of The Sun Dallas Quest Winter Olympiad 88 / Challenge Some of these are just the ATRs. You can try putting them on MaxFlash carrt via a workbook with auto-start. In theory the adventures should still permit a save to a mounted ATR on drive 1. 1 Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 9, 2022 Author Share Posted November 9, 2022 1 hour ago, Wrathchild said: Infocom titles Magnetic Scrolls The Serpent's Star Mask Of The Sun Dallas Quest Winter Olympiad 88 / Challenge Some of these are just the ATRs. You can try putting them on MaxFlash carrt via a workbook with auto-start. In theory the adventures should still permit a save to a mounted ATR on drive 1. Thanks for these.. I completely forgot about Dallas Quest! Quote Link to comment Share on other sites More sharing options...
