+llabnip Posted November 13, 2022 Share Posted November 13, 2022 It's been a while but I finally got back to working on ColecoDS - an Emulator for the DS/DSi with support for Colecovision, ADAM, MSX1, Sord-M5, Memotech MTX, Spectravision SVI, Hanimex Pencil II, Tatung Einstein, SG-1000/SC-3000 and the Creativision (these systems all use very similar hardware). Version 7.8 is released with preliminary support for the MSX SCC sound chip. This brings music to some amazing games - Gradius II and III, Salamander, Parodius and more. I've also researched how to properly combine audio channels. Previously I had been adding the channels and dividing by the number of channels. While this works, more channel combines cause the volume to be reduced. Life doesn't work this way - if two instruments are playing, they don't both get half-as-loud! So the new method is to add all channels and clip if needed (and with clever sampling, clipping should be minimal). This should normalize the sound across any game type no matter how many emulated sound chips are being combined. https://github.com/wavemotion-dave/ColecoDS 1 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted November 13, 2022 Share Posted November 13, 2022 Nice! Installing it now. I've only setup CV games so far, will have to check out the other systems it supports. FYI - your link is going to a page that says "Leaving Facebook" 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted November 13, 2022 Share Posted November 13, 2022 I see you updated A7800DS as well. The NDS grew 70% in size, is that to be expected? 1 Quote Link to comment Share on other sites More sharing options...
ClassicGMR Posted November 13, 2022 Share Posted November 13, 2022 Oh my. I need to get on board with this. 1 Quote Link to comment Share on other sites More sharing options...
+llabnip Posted November 13, 2022 Author Share Posted November 13, 2022 (edited) 2 hours ago, SpiceWare said: I see you updated A7800DS as well. The NDS grew 70% in size, is that to be expected? I switched to a new audio library to eliminate the audio “zingers” I was experiencing. This came with some bloat but still manageable. Fortunately SD card space isn’t usually an issue Edited November 13, 2022 by llabnip 2 Quote Link to comment Share on other sites More sharing options...
+llabnip Posted November 13, 2022 Author Share Posted November 13, 2022 6 hours ago, SpiceWare said: Nice! Installing it now. I've only setup CV games so far, will have to check out the other systems it supports. If you’re brave and can decipher my Readme, the most obscure system ColecoDS supports is the almost unknown Hanimex Pencil II with only one game dumped: Treasure Hunt. A far cry from what’s been preserved on the Atari front! 1 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted November 14, 2022 Share Posted November 14, 2022 23 hours ago, llabnip said: If you’re brave and can decipher my Readme Readme was fine. I have no problem manipulating binary files via command line - the DPC+ driver has seen a few updates over the year and I've replaced the driver (first 3K of ROM) for a number of games, such as Space Rocks, to fix a compatibility issue with older drivers and the newer Harmony Encore. On 6/24/2017 at 8:03 AM, SpiceWare said: So I've run the following via Terminal on my Mac (these commands also work under Linux) to replace the DPC+ driver used in Space Rocks: dd skip=3 count=29 if=spacerocks20121129_NTSC.bin of=srn29K.bin bs=1024 cat DPC+20121020.arm srn29K.bin > spacerocks20121129_NTSC_encore.bin dd skip=3 count=29 if=spacerocks20121129_PAL.bin of=srp29K.bin bs=1024 cat DPC+20121020.arm srp29K.bin > spacerocks20121129_PAL_encore.bin So creating TreasureHunt.pen was easy. Tricky part was the BIOS. cksum on the Mac outputs in decimal, so I first converted 338d7b59 to 864910169. Then I ran cksum on the files to figure out which one was the BIOS: Darrells-Mac-Pro:pencil2 darrellspice$ cksum * 2382224437 32768 ap2k.ic3c 1273181955 8192 it.em.ou.bin 180276071 32768 lx800.ic3c 39373678 32768 lx810l.ic3c 1905388804 8192 mt.u4 3745853904 1048576 p72.2c 1429391862 3584 pl80.pt6 3323748502 1024 tiny.bin 3314771909 32768 w8_pe9.9b but no match. Checked the man: cksum [-o 1 | 2 | 3] [file ...] ... -o Use historic algorithms instead of the (superior) default one. Algorithm 1 ... This is a 16-bit checksum ... Algorithm 2 ... This is a 32-bit checksum ... Algorithm 3 is what is commonly called the ‘32bit CRC’ algorithm. This is a 32-bit checksum. so I tried 2: Darrells-Mac-Pro:pencil2 darrellspice$ cksum -o 2 * 13074 64 ap2k.ic3c 42488 16 it.em.ou.bin 5875 64 lx800.ic3c 54450 64 lx810l.ic3c 19099 16 mt.u4 4891 2048 p72.2c 3581 7 pl80.pt6 31339 2 tiny.bin 44312 64 w8_pe9.9b and 3: Darrells-Mac-Pro:pencil2 darrellspice$ cksum -o 3 * 4000486583 32768 ap2k.ic3c 457847192 8192 it.em.ou.bin 3657876571 32768 lx800.ic3c 2791593185 32768 lx810l.ic3c 864910169 8192 mt.u4 <----==== BINGO! 734430319 1048576 p72.2c 2919603803 3584 pl80.pt6 2483995117 1024 tiny.bin 1842618011 32768 w8_pe9.9b then copied/renamed mt.u4 to pencil2.rom on the 3DS. 1 Quote Link to comment Share on other sites More sharing options...
+llabnip Posted November 15, 2022 Author Share Posted November 15, 2022 Nice! You know how I did it? I knew the BIOS was 8k in size so I tried one of the 8k bins and then the other 🤓🤪😁 1 Quote Link to comment Share on other sites More sharing options...
