+dhe Posted November 15, 2022 Share Posted November 15, 2022 Is anyone producing new MIDI cables for Atari ST's? Quote Link to comment Share on other sites More sharing options...
MasterMotorola Posted November 15, 2022 Share Posted November 15, 2022 Lots of companies are producing new stock and pretty much any music store you walk into sells standard MIDI cables as well as MIDI-to-USB cables. I bought some extra MIDI cables for my "new" secondary keyboard last year on Amazon (a friend returned my Yamaha keyboard he borrowed 25 years ago). 1 Quote Link to comment Share on other sites More sharing options...
Cubeast Posted November 15, 2022 Share Posted November 15, 2022 2 hours ago, MasterMotorola said: Lots of companies are producing new stock and pretty much any music store you walk into sells standard MIDI cables as well as MIDI-to-USB cables. I bought some extra MIDI cables for my "new" secondary keyboard last year on Amazon (a friend returned my Yamaha keyboard he borrowed 25 years ago). Most of what is being sold as MIDI cables these days have all 5 pins wired unlike say an old cable from Roland which will only have the 3 pins wired. The reason why you might not want to use a cable with all 5 pins wired is because Atari combined MIDI Thru with the MIDI Out socket and that could potentially cause problems with instruments that also use non-standard wiring. Now ideally what you actually want connected to the MIDI Out port of your Atari is a special Y cable or adaptor which gives you both the Out and the Thru which will knock off about 2ms of latency in comparison to monitoring via soft thru via the out port. 2 Quote Link to comment Share on other sites More sharing options...
+dhe Posted November 15, 2022 Author Share Posted November 15, 2022 What I would like to do is hook up a mt-32 pi - looks like depending on the "hat" - they either take a USB cable or a five pin DIN connector. Since I just bought an Atari a could of weeks ago (1040SF) - I'm new to the market, so if you could show me where and what to buy, I would appreciate it. Thanks! Quote Link to comment Share on other sites More sharing options...
ggn Posted November 15, 2022 Share Posted November 15, 2022 For the mt32-pi have a look at this page: https://github.com/dwhinham/mt32-pi/wiki/USB-MIDI-interfaces. Basically if you buy one of those usb->midi cables then you don't need a hat at all because you can just plug it to the raspberry pi directly. Otherwise if you already ordered a mt32-pi hat then you just buy 2 bog standard midi cables like https://www.amazon.com/Monoprice-MIDI-Cable-Connector-Molded/dp/B009GUP7U8/ref=sr_1_2?keywords=midi+cable&qid=1668518587&sr=8-2 and you're good to go. 1 Quote Link to comment Share on other sites More sharing options...
Cubeast Posted November 15, 2022 Share Posted November 15, 2022 For that I would assume any commonly available 5 pin din cable will do the trick. Quote Link to comment Share on other sites More sharing options...
zzip Posted November 15, 2022 Share Posted November 15, 2022 46 minutes ago, ggn said: For the mt32-pi have a look at this page: https://github.com/dwhinham/mt32-pi/wiki/USB-MIDI-interfaces. Basically if you buy one of those usb->midi cables then you don't need a hat at all because you can just plug it to the raspberry pi directly. Definitely heed that pages warning about those cheap Chinese USB/MIDI cables! I have a couple of that exact one and it basically corrupts everything (can't even play a song without the music going out of sync) 1 Quote Link to comment Share on other sites More sharing options...
