800_Rocks Posted November 22, 2022 Share Posted November 22, 2022 (edited) Hi - I just acquired the ICD FA-ST shown in the pictures below. I know they made these for both the Atari 8bit and the ST lines so I am not sure which system this one is for. Right now I do not get anything when I power it on. No lights, no fan, no sound from the drive. It looks like there is room and power for a second drive as well. 1) Does anyone have a manual for the FaST device? 2) Does anyone have schematics for this? 3) I expect there was/is some software on diskette to setup/config the FaST. Does anyone know of or have these? 4) The power supply fuse is good and the on/off switch is good. I don't know much about trouble shooting when it comes to power supplies. Any guidance on where to start would be very helpful. FYI - I did replace the 3V button battery with a known good one. Smaller in size but it should be a good substitute. Replacing it did not help (yet). FYI - Info on the HDD itself is found at this link: On 11/14/2022 at 4:22 PM, David_P said: Some info on the HDD here: https://stason.org/TULARC/pc/hard-drives-hdd/seagate/ST157N-0-49MB-3-5-HH-SCSI1-SE.html No obvious bulging caps. I tested the fuse and the on/off switch for continuity and they tested good. What do I check next? (please be specific as I am a newbie with power supplies) Edited November 22, 2022 by 800_Rocks Added comment Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 22, 2022 Share Posted November 22, 2022 4 hours ago, 800_Rocks said: I know they made these for both the Atari 8bit and the ST lines so I am not sure which system this one is for. I think that's the ST one, it has a 50 pin SCSI connector to it, you would need a 15 pin 'D' to 50 pin SCSI cable to connect it to your ST. 4 hours ago, 800_Rocks said: I tested the fuse and the on/off switch for continuity and they tested good. What do I check next? (please be specific as I am a newbie with power supplies) Disconnect the power supply from the drive and test the voltages on the white plug, black is the 0V , red and yellow should be 5VDC and 12VDC 1 Quote Link to comment Share on other sites More sharing options...
larrylaffer Posted November 23, 2022 Share Posted November 23, 2022 Please be careful when working on power supplies. Don't touch underneath the capacitors, they can keep quite a bit of a charge even after they psu is powered off. 1 Quote Link to comment Share on other sites More sharing options...
Atari030 Posted November 23, 2022 Share Posted November 23, 2022 You can use the ICD pro tools with this. It is for the ST. You will need a DMA cable, the scsi port is for adding additional SCSI devices. It is basically just a PSU, DMA-SCSI controller and a hard drive. Quote Link to comment Share on other sites More sharing options...
Bee Posted November 23, 2022 Share Posted November 23, 2022 (edited) Did you check the fuse? Thank you Edited November 23, 2022 by Bee Quote Link to comment Share on other sites More sharing options...
800_Rocks Posted November 23, 2022 Author Share Posted November 23, 2022 11 hours ago, Bee said: Did you check the fuse? Yes... if I did it right... I held my meter probes on either side of the fuse and tested for continuity/connection. I assume that is a valid test, right? Or do I need to physically remove the fuse before testing it? Quote Link to comment Share on other sites More sharing options...
800_Rocks Posted November 23, 2022 Author Share Posted November 23, 2022 11 hours ago, Atari030 said: You can use the ICD pro tools with this. It is for the ST. You will need a DMA cable I have the DMA cable to hook to the ST hard drive port. Do you know where I can find the ICD pro tools? Also, any idea the latest/last version of the ICD pro tools? Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted November 23, 2022 Share Posted November 23, 2022 7 minutes ago, 800_Rocks said: I have the DMA cable to hook to the ST hard drive port. Do you know where I can find the ICD pro tools? Also, any idea the latest/last version of the ICD pro tools? On dev-docs. 1 Quote Link to comment Share on other sites More sharing options...
Chri O. Posted November 23, 2022 Share Posted November 23, 2022 What is this ? Can you take a better picture of this area. Quote Link to comment Share on other sites More sharing options...
Atari030 Posted November 23, 2022 Share Posted November 23, 2022 I replaced the PSU in a Megafile with a meanwell, worked a treat. Pretty cheap and easy to do. 2 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 23, 2022 Share Posted November 23, 2022 1 hour ago, Chri O. said: What is this ? Can you take a better picture of this area. They are Diodes mounted on heat sinks, probably one of the first things to look at due to the heat they experience 1 Quote Link to comment Share on other sites More sharing options...
800_Rocks Posted November 23, 2022 Author Share Posted November 23, 2022 Pictures as requested. The shiny bit at the base just looks like clear glue. Quote Link to comment Share on other sites More sharing options...
Bee Posted November 24, 2022 Share Posted November 24, 2022 Yes - continuity is a valid test of the fuse. Thank you Quote Link to comment Share on other sites More sharing options...
bandit Posted November 30, 2022 Share Posted November 30, 2022 On 11/22/2022 at 4:28 PM, larrylaffer said: Please be careful when working on power supplies. Don't touch underneath the capacitors, they can keep quite a bit of a charge even after they psu is powered off. LOL! I learned that back in the 70's working on microwaves... 1 Quote Link to comment Share on other sites More sharing options...
larrylaffer Posted November 30, 2022 Share Posted November 30, 2022 (edited) 28 minutes ago, bandit said: LOL! I learned that back in the 70's working on microwaves... I am always careful with those. But one day something distracted me and I touched one of those charged capacitors... Oh my... My sight got darker and I felt a tension in pretty much all my muscles. Of course my fingers kept holding because of the tension that was induced so it was like I was shutting down... And then all of a sudden I made a sudden sound like a scream and got unintentionally pushed back and let that board go off my hands... Totally different feeling than the tingling sensation of AC... And it only takes a moment of not paying attention. Do be careful... 🙂 Edited November 30, 2022 by larrylaffer 1 Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted December 7, 2022 Share Posted December 7, 2022 Did ICD have a kit to mount a 2nd HD in there? I remember their print ad for the FA-ST was eye-catching... Quote Link to comment Share on other sites More sharing options...
Zogging Hell Posted December 7, 2022 Share Posted December 7, 2022 The coin battery is presumably for a battery based real time clock. Should be a nice unit if you can get it started. For my two pennies worth, the drive itself looks to run off a standard Molex power connector, have you got a PC hanging about somewhere that you can plug it into to see if it actually spins up itself (might save you the trouble of fixing the PSU if it has the click of death/ has siezed or something) 1 Quote Link to comment Share on other sites More sharing options...
800_Rocks Posted December 25, 2022 Author Share Posted December 25, 2022 Update - When I remove the MOLEX power connector to the hard drive the 12V fan (hidden under the ribbon cable) starts spinning and the little LED lights-up on the front of the FAST case. The voltages test fine at the MOLEX itself. So I assume there is a short in the hard drive itself or in the PCB underneath the drive. How do I determine which is the case? Are hard drives available as replacements (image of drive shown below)? If yes, what should I look for? TIA Some info on the HDD here: https://stason.org/TULARC/pc/hard-drives-hdd/seagate/ST157N-0-49MB-3-5-HH-SCSI1-SE.html Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted December 26, 2022 Share Posted December 26, 2022 You can always use a SCSI2SD as a drive replacement. SCSI2SD - SCSI2SD.COM Quote Link to comment Share on other sites More sharing options...
