Shannon Posted November 22, 2022 Share Posted November 22, 2022 I used to have one.. but it was years ago. Can anyone hook me up? Even better if one is available that can run on a windows PC rather than through emulation. Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted November 22, 2022 Share Posted November 22, 2022 The most accessible program would be SETUP.COM on your DOS 2.5 disk. Quote Link to comment Share on other sites More sharing options...
invisible kid Posted November 22, 2022 Share Posted November 22, 2022 I thought I would just rename the basic program autorun.sys, but I guess that only works with machine code programs? Memory is fading as the years go on. Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 22, 2022 Author Share Posted November 22, 2022 57 minutes ago, www.atarimania.com said: The most accessible program would be SETUP.COM on your DOS 2.5 disk. Thanks... all these years and I didn't even know about that command! I thought autorun.sys was limited to machine code games! Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 22, 2022 Author Share Posted November 22, 2022 That did the trick.. Just tested it! 1 Quote Link to comment Share on other sites More sharing options...
xxl Posted November 22, 2022 Share Posted November 22, 2022 xBootDOS: Dsk Operating System (DOS) stored in BOOT SECTORS. Features of this minimalist DOS: - MEMLO = $980, does not use the 4, 5 or 6 page, - automatically starts a program named "AUTO", - supports BiboDOS and TopDOS systems with 64/128 directory entries, - supports BINARY LOAD function, e.g. XIO 40,#1,0,0, "D:FILE.EXE", - additional NOTE and POINT commands stored in xBDext file (can be loaded automatically - rename it to AUTO) A file xBDext when it is loaded, START.COM is automatically started and if BASIC is enabled, START.BAS will be automatically started - you do not need a separate program to autostart programs in BASIC. https://xxl.atari.pl/xbootdos/ 2 Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted November 23, 2022 Share Posted November 23, 2022 There is one on the superdos master disk. Rename SBAS.SYS to autorun.sys. Lock the files you want to display in the load menu. Quote Link to comment Share on other sites More sharing options...
Madi Posted November 23, 2022 Share Posted November 23, 2022 15 hours ago, Shannon said: I used to have one.. but it was years ago. Can anyone hook me up? Even better if one is available that can run on a windows PC rather than through emulation. MENUTEAC.ATR Several programs inside 2 Quote Link to comment Share on other sites More sharing options...
