Options menu
Hello guys.
The routine below shows the difficulty level that can be changed in a loop with the control to left or right.
The problem is that, when pressing ENTER, the chosen level "goes back" to the previous level before exiting as if the control was pressed to the left (the procedure "Loop2" shows the chosen level, but it should be 1 level above the one shown in the corner of the screen).
Is there any way to avoid this? I made several attempts, but none were successful.
Thanks!
INCLUDE "constants.bas"
Level=1: GOSUB LevelName
Loop1:
    WAIT
    IF CONT.LEFT=0 AND CONT.RIGHT=0 THEN NoCtl=0
    IF CONT.RIGHT>0 AND NoCtl=0 THEN
        IF Level<3 THEN Level=Level+1 ELSE Level=1
        GOSUB LevelName
    ELSEIF CONT.LEFT>0 AND NoCtl=0 THEN
        IF Level>1 THEN Level=Level-1 ELSE Level=3
        GOSUB LevelName
    END IF
    IF CONT.KEY=11 THEN GOTO Loop2
GOTO Loop1
Loop2:
    PRINT AT 1 COLOR 7,<>Level
Loop3:
GOTO Loop3
LevelName:  PROCEDURE
    FOR a=0 to 5: #backtab(147+a)=Levels(a+((Level-1)*6))*8+FG_WHITE: NEXT a
    NoCtl=1
END
Levels:
DATA " EASY ","MEDIUM", " HARD "
It's because the keypad code for the Enter key (101000) includes the bit that signals the Left disc position (001000).  So, you select your level, then when you press Enter, it first passes by the test for the Left position, and decrements the level before acknowledging the key.
You need to disambiguate your input by making sure that it is exclusively either a disc, or a keypad entry.
IntyBASIC already takes care of decoding the keypad, so you are guaranteed to have a valid key; but for the disc, you are on your own.  You should isolate the bits for the disc, and ensure that the signal you got does not contain bits resembling the keypad.
Personally, my recommendation is to go with a more robust decoding that handles the above.  However, you can get around it easily in your code by moving the test for the Enter key to the top.
Still, there is a chance that the input will arrive before the loop recycles and be caught by the Left test again.
    dZ.
Edited by DZ-Jay
 I forgot to mention that IntyBASIC "debounces" the keypad input for two or three frames before acknowledging it, so you have at least that many loop iterations in which your Enter key input may be caught by your other tests if it "looks" sufficiently like a disc code.
    dZ.
Edited by DZ-Jay
    dZ.
Thank you, DZ.
I had already tried moving the test for ENTER to the top with no success. But after your explanation, I made a small modification to the main loop to delay the keypress checking for a few cycles. Maybe not the best way, but now the routine runs as expected.
c=0
Loop1:
    WAIT
    IF CONT.KEY=11 AND NoCtl=0 THEN GOTO Loop2
    IF c>2 AND CONT.KEY=12 THEN
        c=0
        GOSUB LevelName
    END IF
        GOSUB LevelName
        c=c+1
    END IF
GOTO Loop1
Edited by Intellivision Brasil
Error pasting
Like I mentioned, the root of your problem is that the input is not being properly decoded and disambiguated.
Understand that CONT.KEY is decoded and validated by IntyBASIC automatically, but CONT is not.
When you write “CONT.LEFT,” all it is doing is telling you whether the code in the input signal contains the bits for the LEFT direction — but it won’t tell you whether those are the only bits set in the signal.
That is important, because the Intellivision hand-controller has only eight wires to transmit data, but 32 distinct inputs.
This means that the wires are reused and overlap in various inputs — specifically those of the disc and keypad.
So, checking for CONT.LEFT is only useful if you can guarantee that there is only Disc input, because some keypad entries may overlap with it.
And even guaranteeing that it is Disc input is not sufficient, because there are a range of directions on the disc that overlap with CONT.LEFT, including most of the diagonals on the left half of the Disc.
Therefore, delaying the test will not solve the problem in all cases.  There remains a race condition.
I personally recommend you actually isolate the signal to determine if it is a valid Disc input first — then and only then accept it.
That will prevent the signals for the Enter key and the disc from beobg confused.
There are various ways to do this:  you could use a look up table of valid values, or you could look for invalid combinations, etc.
In my opinion, bad or flakey control schemes are the biggest sort of frustration for players.
    dZ.
Edited by DZ-Jay
