How to Duplicate PHX, PHY on NES 6502?
Hi,
Inspired by the topic in the link above, what I wish to do is to try to duplicate this 65816-based code from Super Mario All-Stars, but to make it work for a classic 6502.
Here is the code in question:
KillPlayer:
stx Player_X_Speed
phx
lda #$01
sta PlayerSize
jsl GetPlayerColors (jsl is a special code used in 65816 to bring up subroutines from faraway program banks)
plx
inx
lda #DeathMusic
sta EventMusicQueue
lda #DeathMusic
sta EventMusicQueue
What I am dealing with here is a phx after stx and before lda, and a plx after sta and jsl.
For 6502, to duplicate phx I might:
pha
txa
pha
Whereas for plx:
pla
tax
pla
I read that to preserve the x register, I would also:
lda $0100,x
~Ben
Thank you,
Ben
10 hours ago, splendidnut said:
For this particular case, you should be able to remove PHX and replace the PLX with LDX PLAYER_X_SPEED.  That should work as long as the GetPlayerColors subroutine doesn't change it.
UPDATE: I tried this modified code as Small Mario, and it works fine. I will update you later as to if it works right when I'm Fiery Mario and run out of time.
Here is the rest of the SMAS version's code:
sta $0e67 (what's this supposed to do in SMAS?)
sta ScrollLock ($0723)
lda #$fc
sta player_y_speed ($a0)
lda #$0b (a game engine subroutine bit)
bne SetKRout (sets player's state and other things)
And here's the original NES version's code, which did not explicitly take into account the player's size ($0754), colors (GetPlayerColors) and scroll lock ($0723). As the latter is halted when the player dies, I would make an LDA before it and set that as #$01.
KillPlayer:
stx Player_X_Speed (halts player's X movement by setting speed)
inx (this increments the last value loaded in X to get the DeathMusic)
stx EventMusicQueue
lda #$fc
sta Player_Y_Speed (#$fc sets the player's new Y speed)
lda #$0b (subroutine bit to call routine on next frame)
bne SetKRout (a branch to set player's state and other things)
And here's the code that comes right before it...
ForceInjury:
LDX PlayerStatus ($0756; in this case, the player becomes smaller)
BEQ KillPlayer
STA PlayerStatus
LDA #$08
STA InjuryTimer ($079e NES, $07ae SNES)
LDA #$04 (NES used the single-byte ASL to multiply the current A value to switch to the pipedown/player injured sound)
STA Square1SoundQueue
JSL GetPlayerColors (JSR for NES)
LDA #$0a (sets subroutine to run on next frame)
SetKRout:
LDY #$01 (sets player's new state)
SetPRout:
STA GameEngineSubroutine (#$0f; loads new subroutine to run on next frame)
STY PlayerState ($18 NES, $28 SMAS)
LDY #$ff
STY TimerControl ($0747)
INY
STY ScrollAmount ($0775)
ExInjColRoutines:
LDX ObjectOffset ($08 NES, $9e SMAS) (in KillPlayer routine; this X value is incremented using INX to get the DeathMusic jingle when stored into $FC, the EventMusicQueue)
RTS
~Ben
Edited by ColecoFan1981
  • 2 months later...
Thank you; I finally found out how to do that:
KillPlayer:
stx Player_X_Speed
txa
pha
lda #$01
sta PlayerSize
pla
tax
inx
stx EventMusicQueue
stx ScrollLock
~Ben
