+TheBF Posted December 3, 2022 Share Posted December 3, 2022 20 minutes ago, apersson850 said: The drawback of the flexible stack method is that the TMS 9900 doesn't have "deferred indirect". If it did, you could have returned with a mechanism like B @*SP+, which should be read as branch to the address stored in the memory position pointed to by the stack pointer and increment the stack pointer by two. Such instructions do exist, but typically in 32-bit architectures. We need to do as BF did above, MOV *SP+,R11 and then B *R11. <off topic> 6809 can do something like this which makes direct threaded code as used in the BASIC compiler very efficient. The 6809 "thread interpreter" (NEXT) was one instruction, 9 clocks. From Moving Forth by Brad Rodriguez DTC-NEXT: JMP [,Y++] VS something like this on 9900 MOV *IP+,R5 22 B *R5 12 </off topic> Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 3, 2022 Share Posted December 3, 2022 (edited) duplicate entry mistake Edited December 3, 2022 by TheBF Duplicate entry Quote Link to comment Share on other sites More sharing options...
apersson850 Posted December 3, 2022 Share Posted December 3, 2022 Most simpler processors that indeed can do that trick usually has it as some oddball instruction. The double indirection isn't another general addressing mode, as it was where I saw it first. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 4, 2022 Share Posted December 4, 2022 2 hours ago, apersson850 said: Most simpler processors that indeed can do that trick usually has it as some oddball instruction. The double indirection isn't another general addressing mode, as it was where I saw it first. It's a feature on 6809, if I understand this reference from: MC6809-MC6809E 8-Bit Microprocessor Programming Manual [M6809PM/AD] © Motorola Inc., 1981 The indexed addressing modes have been expanded to include: 0-, 5-, 8-, 16-bit constant offsets, 8- or 16-bit accumulator offsets, autoincrement/decrement (stack operation). In addition, most indexed addressing modes may have an additional level of indirection added. Quote Link to comment Share on other sites More sharing options...
+RXB Posted December 4, 2022 Share Posted December 4, 2022 4 hours ago, TheBF said: There is a way around that. It is done on the ARM processor and other modern machines, this way as well. You allocate one register to be a stack pointer. Then your call sequence is as @apersson850 showed previously. RP EQU R10 * call * DECT RP 10 MOV R11,*RP 18 BL @ABCD 20 ------------------------- 48 * RETURN * MOV *RP+,R11 22 B *R11 12 ---------------------------- 34 If you use a macro assembler these can be turned into one line. CALL @MYCODE MYCODE BLAH BLAH . . . RET Nope. It's not faster that BLWP/RTWP, but instead of needing a workspace for every sub-routine you just reserve a few bytes as your return stack. With 20 bytes you can nest sub-routines 10 deep. If you make macros for PUSH and POP, you can also use the return stack for temp storage anytime you need it. PUSH R1 PUSH R2 LI R1,>1234 LI R2 >5678 A R1,R2 MOV R2,@TOTAL POP R2 POP R1 With a stack you are using a small memory space over and over for multiple purposes. Hmmm are we talking about the TI99/4A CPU or a ARM CPU, as far as I know they are not using the same code? Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 4, 2022 Share Posted December 4, 2022 44 minutes ago, RXB said: Hmmm are we talking about the TI99/4A CPU or a ARM CPU, as far as I know they are not using the same code? No of course not. But the many of the modern RISC machines take the same approach as 9900. They allow the programmer to decide how to implement a stack with a general purpose register. 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted December 4, 2022 Share Posted December 4, 2022 13 hours ago, TheBF said: * call * DECT RP 10 MOV R11,*RP 18 BL @ABCD 20 You're saving the value of R11 before you branch? How does that work at the top level? Quote Link to comment Share on other sites More sharing options...
apersson850 Posted December 4, 2022 Share Posted December 4, 2022 45 minutes ago, Asmusr said: You're saving the value of R11 before you branch? How does that work at the top level? At the top level you don't have anything to return to. You are the master, literally. @TheBF My comment about various 8-bit processors having various useful instructions was supposed to say that these processors typically have a large, but not very uniform, amount of instructions and addressing modes. With a lot of "this goes only with that" and "that goes only with this". The approach of the TMS 9900 (or really the mini computer it's supposed to implement) is more the opposite. Not too many instructions, but instead you have the general addressing mode, which can be used for many instructions, and sometimes twice (like for Add, Subtract, MOVe and so on), without restrictions. The register that can be used with most of these addressing modes is also almost up to you. If you need a stack, use a register as the stack pointer. If you need two, then pick another register too. Or yet another, if you need three. Ran out of registers completely, in spite of having 16 of them? Just create a new set. So although execution speed is pretty slow, the TMS 9900 architecture does provide the programmer with an environment that's pretty simple to use. In spite of supporting 69 instructions, the approach with many of them is still RISC-inspired, in that a two operand instruction can have five addressing modes per operand, which in reality creates 25 different such operations. And then you can specify that the operands are bytes or words, so you kind of have 50 versions of each instruction. The obvious deviation is the immediate mode. That's more like 8-bit style, in that it's a special instruction and can only use a register. You have to do LI R3,>ABDC and then MOV R3,@TABLE(R6). You can't do MOV #>ABDC,@TABLE(R6) as a single instruction. This is the price you have to pay for the six instructions with two general addressing modes and byte/word capability. They eat up a large portion of the available opcodes in the CPU. We have said it before here, and now I'm coming back to the core question (BL vs. BLWP), when programming the TMS 9900, the general rule is like if you can do something with less instructions, it's more efficient. Althogh the most complicated instructions consume quite a lot of CPU cycles, the simplest one does use a somewhat unproportional number of clock cycles too. So even if MPY takes a lot of time to execute, doing something equivalent with shift and add instructions typically uses even more. The same goes for the BLWP - RTWP pair compared to BL - B. The first is slower to execute, but it only takes you need to do a few extra maneuvers to save some data (R11 or some other register thing), which you wouldn't have to if you used BLWP, to be even. Then add that your programming task may be easier with a fresh set of registers in a subroutine, and the choice is obvious. It's different if you are writing code that's supposed to execute in a console only, from ROM in a cartridge. Then you have only those 256 bytes of RAM to play with. Using another 32 bytes for a register file may be less optimal in such a case. 3 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted December 4, 2022 Share Posted December 4, 2022 (edited) 2 hours ago, apersson850 said: At the top level you don't have anything to return to. You are the master, literally. I mean when you use * call * at the top level. R11 is undefined and you put that on the stack. When you return from the second level the value on the stack is undefined. Edited December 4, 2022 by Asmusr Quote Link to comment Share on other sites More sharing options...
apersson850 Posted December 4, 2022 Share Posted December 4, 2022 No. When you call the subroutine, you can save R11, which at that time doesn't contain anything relevant, on the stack. Then you do the call and R11 gets updated with the return address. Now if your subroutine calls another subroutine, it will save R11 prior to that call. At this time R11 contains the return address to the top level, so it's relevant. When returning from the second level, R11 has the return address already. No stack pop needed to get that. When returning from the first level, you pop the return address from the stack and return correctly. Now you come back to the top level, where you should pop the stack for no other reason but to get rid of the unnecessary value there. Or you can let it stay, but then you have consumed one stack level for no good reason. A better practice is to do a simple BL from top level and only do calls with return address push on the lower levels. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 4, 2022 Share Posted December 4, 2022 5 hours ago, Asmusr said: You're saving the value of R11 before you branch? How does that work at the top level? What @apersson850 said far more eloquently than I could. 1 Quote Link to comment Share on other sites More sharing options...
+RXB Posted December 4, 2022 Share Posted December 4, 2022 None of these changes what I said. BL makes you run out of Registers pretty fast and thus you are forced to use memory address in Scratch pad instead. As I have been stuck with Console Only and Scratch Pad with only GPL Registers to work with. I am forced to use MOV instruction from memory to Register or Register to memory so I can free up that Register. Or use stack, but the stack is not in the Scratch Pad so uses slower VDP memory. If you guys programed in Console only you would see BL sucks compared to having more Registers in BLWP. Look over the XB ROMs or CONSOLE ROM to tell me I am wrong. This is why you guys just ADDED A CPU to take the place of the 9900! Quote Link to comment Share on other sites More sharing options...
apersson850 Posted December 4, 2022 Share Posted December 4, 2022 (edited) Oh yes it does. It's already been shown that you don't run out of registers that fast, since a large number of subroutine levels is pretty uncommon. Two or three registers occupied caters for a lot of situations. On the other hand, if you are programming console only, then you'll run out of suitable memory for new register files, needed by the BLWP concept, literally before you start. The RAM available is almost all used up already, if you want to preserve the GPL environment. The use of BLWP on the 99/4A only makes sense when you have some kind of RAM expansion, in almost all cases. A lot of my own assembly was as support to Pascal programs, which of course implies the memory expansion is available, or it would not run. I've used BLWP inside some of my own programs. Typically if a subroutine needs to reference a few parameters from the caller but also requires several registers by itself, to be efficient. No, we haven't replaced the TMS 9900 either, wherever you got that from? @Asmusr Even at the top level, R11 is usually relevant. At least my own assembly programs have almost always been support for some high level language. Frequently Pascal, sometime Extended BASIC. In both cases you want to be able to return to the caller, and then R11 is your ticket there. Even if you make a stand alone assembly program, you may want to be able to return to the operating system, i.e. the GPL code that invoked you program, in which case you may want to push your return link to the stack first thing you do, then do all calls from your top level with BL, not the macro CALL and eventually leave your program via a link poped off the stack. That one you saved at the beinning. Edited December 4, 2022 by apersson850 4 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted December 5, 2022 Share Posted December 5, 2022 I think there is something to be said (when RAM expansion is present) for the usefulness of BLWP for building reusable code modules that can be used anywhere. With parameters passed via labeled memory locations, a fresh workspace and the automatic storage of the previous workspace pointer and return address, just plunk in the code module and BLWP it without concern for trashing previous register contents or worry over which workspace the calling routine was using. Mostly I use BL. But now and then... 3 Quote Link to comment Share on other sites More sharing options...
+RXB Posted December 6, 2022 Share Posted December 6, 2022 I thought I would show the ROM3 that Lee Stewart helped me with. ************************************************************ AORG >6000 TITL 'RXB ROM3' ************************************************************ * EQUATES BIAS EQU >6000 PAD EQU >8300 * TEMP PAD1 EQU >8301 * TEMP PAD2 EQU >8302 * VDP ADDRESS PAD3 EQU >8303 * TEMP PAD4 EQU >8304 * TEMP PAD5 EQU >8305 * TEMP PAD6 EQU >8306 * TEMP BUFFER FOR COINSP PAD8 EQU >8308 * SPRITE 1 PADA EQU >830A * SPRITE 2 BYTES EQU >830C * STRING LENGTH SREF EQU >831C * STRING POINTER FAC EQU >834A * RAM line buffer FAC1 EQU >834B * GCHAR buffer FAC4 EQU >834E * String Address FAC6 EQU >8350 * String Length ARG EQU >835C * ARGUMENT FOR ERRORS STATUS EQU >837C * GPL STATUS BYTE ISR EQU >83C4 * ISR INTERUPT HOOK GR0LB EQU >83E1 * GPLWS R0 LSB GR4LB EQU >83E9 * GPLWS R4 LSB VDPRD EQU >8800 * VDP Read Data address VDPWD EQU >8C00 * VDP Write Data address ************************************************************ * VDP EQUATES VBUFF EQU >03C0 * line buffer in VRAM ************************************************************ UNUSED DATA >0000,>0000,>0000,>0000 DATA >0000,>0000,>0000,>0000 ****************************************************************** * XML table number 7 for RXB ROM3 - must have * * it's origin at >6010 * ****************************************************************** * 0 1 2 3 4 5 6 7 DATA RROLL,LROLL,UROLL,DROLL,HCHAR,VCHAR,ASCHEX,HPUT * 8 9 A B C D E F DATA VPUT,CLEARP,HGET,VGET,>0000,>0000,ALPHA,CHRLDR ***************************************************************** * XML table number 8 for RXB ROM3 - must have * * it's origin at >6030 * ***************************************************************** * 0 1 2 3 4 5 6 7 DATA COLLSP,>0000,>0000,>0000,>0000,>0000,>0000,>0000 * 8 9 A B C D E F DATA >0000,>0000,EAINIT,CINIT,XISRON,XISROF,>0000,>0000 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * Write VRAM address * Expects address in R0 * * BL here for writing data * VWADD ORI R0,>4000 * set to write VRAM data * * BL here for reading data * VWADDA MOVB @GR0LB,*R15 * write LSB of R0 to VDPWA MOVB R0,*R15 * write MSB of R0 to VDPWA ANDI R0,>3FFF * ensure R0 returned intact RT * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * The following utilities expect * R0 = VRAM address of row * R1 = RAM buffer address * * R2 and R10 will be destroyed * * Copy 1 row of 32 bytes from VDP (R0) to RAM (R1) * VRROW MOV R11,R10 * save return BL @VWADDA * write out VDP read address LI R2,32 * read 1 row LI R8,VDPRD * Register faster then address VRROW1 MOVB *R8,*R1+ * read next VDP byte to RAM MOVB *R8,*R1+ * read next VDP byte to RAM DECT R2 * dec count by 2 JNE VRROW1 * repeat if not done B *R10 * return to caller * * Copy 1 row of 32 bytes from RAM (R1) to VDP (R0) * VWROW MOV R11,R10 * save return BL @VWADD * write out VDP write address LI R2,32 * write one row LI R8,VDPWD * Register faster then address VWROW1 MOVB *R1+,*R8 * write next VDP byte from RAM MOVB *R1+,*R8 * write next VDP byte from RAM DECT R2 * dec count by 2 JNE VWROW1 * repeat if not done B *R10 * return to caller ********************************************************* * CALL ROLLRIGHT(repetion) * ********************************************************* RROLL MOV R11,R9 * save return address CLR R0 * set to screen start LI R3,24 * rows to roll * Write row to RAM buffer RROLLP LI R1,FAC+1 * RAM buffer+1 for roll-right positions BL @VRROW * copy row to RAM buffer 2 bytes at a time * Copy last column before first in RAM buffer MOVB @FAC+32,@FAC * copy roll-out byte to roll-in position * Copy rolled row back to screen (R0 still has correct location) LI R1,FAC * reset RAM buffer pointer BL @VWROW * copy rolled line * Process next row AI R0,32 * next row DEC R3 * dec row count JNE RROLLP * roll next row if not done B @PAGER * return to XB ********************************************************* * CALL ROLLLEFT(repetion) * ********************************************************* LROLL MOV R11,R9 * save return address CLR R0 * set to screen start LI R3,24 * rows to roll * Write row to RAM buffer LROLLP LI R1,FAC * RAM buffer+1 for roll-left positions BL @VRROW * copy row to RAM buffer 2 bytes at a time * Copy first column after last in RAM buffer MOVB @FAC,@FAC+32 * copy roll-out byte to roll-in position * Copy rolled row back to screen (R0 still has correct location) LI R1,FAC+1 * reset RAM buffer pointer BL @VWROW * copy rolled line 2 bytes at a time * Process next row AI R0,32 * next row DEC R3 * dec row count JNE LROLLP * roll next row if not done B @PAGER * return to XB ********************************************************* * CALL ROLLUP(repetion) * ********************************************************* UROLL MOV R11,R9 * save return address CLR R0 * set to screen start LI R3,23 * rows to roll (all but 1st) * Write first row to RAM buffer LI R1,FAC * set RAM buffer BL @VRROW * copy row to RAM buffer 2 bytes at a time * Copy RAM buffer to VRAM buffer LI R0,VBUFF * set VRAM dest to VBUFF LI R1,FAC * set RAM buffer BL @VWROW * copy row to VBUFF 2 bytes at a time * Start copy loop at 2nd row LI R0,32 * point to 2nd row * Write row to RAM buffer UROLLP LI R1,FAC * set RAM buffer BL @VRROW * copy row to RAM buffer 2 bytes at a time * Copy to previous row AI R0,-32 * back up 1 row LI R1,FAC * reset RAM buffer pointer BL @VWROW * copy to previous row 2 bytes at a time * Process next row AI R0,64 * next row DEC R3 * dec row count JNE UROLLP * roll next row if not done * Copy saved row to RAM LI R0,VBUFF * set VRAM source LI R1,FAC * set RAM buffer BL @VRROW * copy row to RAM buffer 2 bytes at a time * Copy saved row to last row LI R0,736 * point to last row LI R1,FAC * reset RAM buffer pointer BL @VWROW * copy to last row 2 bytes at a time B @PAGER * return to XB ********************************************************* * CALL ROLLDOWN(repetion) * ********************************************************* DROLL MOV R11,R9 * save return address LI R0,736 * set to last row LI R3,23 * rows to roll (all but last) * Write last row to RAM buffer LI R1,FAC * set RAM buffer BL @VRROW * copy row to RAM buffer 2 bytes at a time * Copy RAM buffer to VRAM buffer LI R0,VBUFF * set VRAM dest to VBUFF LI R1,FAC * set RAM buffer BL @VWROW * copy row to VBUFF 2 bytes at a time * Start copy loop at 2nd-to-last row LI R0,704 * point to row 22 * Write row to RAM buffer DROLLP LI R1,FAC * set RAM buffer BL @VRROW * copy row to RAM buffer 2 bytes at a time * Copy to next row AI R0,32 * down 1 row LI R1,FAC * reset RAM buffer pointer BL @VWROW * copy to next row 2 bytes at a time * Process next row AI R0,-64 * back up 2 rows DEC R3 * dec row count JNE DROLLP * roll next row if not done * Copy saved row to RAM LI R0,VBUFF * set VRAM source LI R1,FAC * set RAM buffer BL @VRROW * copy row to RAM buffer * * 2 bytes at a time * Copy saved row to first row CLR R0 * point to first row LI R1,FAC * reset RAM buffer pointer BL @VWROW * copy to first row 2 bytes at a time B @PAGER * return to caller *********************************************************** * CALL HCHAR(row,column,character#,repetition[,...]) * *********************************************************** * R0 VDP ADDRESS = PAD2 * R1 CHARACTER = PAD * R3 COUNTER - FAC * HCHAR MOV R11,R9 * save return address LI R8,VDPWD * put VDPWD in R8 for faster loop MOV @PAD2,R0 * VRAM start address for HCHAR4 MOV @PAD,R1 * ASCII char code is in MSB MOV @FAC,R3 * repetition to R3.. MOV R3,R7 * .. and to R4 for manipulation LI R5,768 * get screen end = 768 to a register.. MOV R5,R6 * ..and to R6 for screen size C R6,R7 * scrn_size > cnt, i.e., cnt OK? JGT HCHAR1 * yes; jump MOV R6,R7 * no; cnt = scrn_size HCHAR1 C R0,R5 * VRAM address outside screen? JHE HCHARX * error if so..just exit S R0,R5 * bytes to end of screen HCHAR2 MOV R7,R3 * put cnt in R3 for HCHAR4 JGT HCHAR3 * are we done? JMP HCHARX * yup; we're outta here! HCHAR3 S R5,R7 * no; do we wrap to screen start? JLT HCHAR4 * no MOV R5,R3 * yes, just go to screen end HCHAR4 BL @VWADD * write out VRAM write address LI R8,VDPWD * put VDPWD in R8 for faster loop HCHAR5 MOVB R1,*R8 * Write a byte to next VRAM location DEC R3 * decrement count JNE HCHAR5 * Not done, fill another CLR R0 * wrap for next round MOV R6,R5 * scrn_size to bytes-to-end-of-screen JMP HCHAR2 * see if more HCHARX B @PAGER * return to caller *********************************************************** * CALL VCHAR(row,column,character#,repetition[,...]) * *********************************************************** * CALL VCHAR(row,column,character#,repetition) * R0 VDP ADDRESS = PAD2 * R1 CHARACTER = PAD * R3 COUNTER = FAC VCHAR MOV R11,R9 * save return address MOV @PAD2,R0 * VDP ADDRESS MOV R0,R7 * Copy VDP ADDRESS VCHART CI R7,31 * VDP ADDRESS>=31 top? JLE VCHARD * column<=31 top found AI R7,-32 * VDP ADDRESS-32 JMP VCHART * Loop VCHARD CI R7,31 * column=31? JNE VCHARR * 0 to 30 CLR R7 * Reset column to 0 JMP VCHARZ VCHARR INC R7 * column+1 VCHARZ MOV @PAD,R1 * Character to display MOV @FAC,R3 * Repetition VCHAR1 BL @VWADD * write out VRAM write address LI R8,VDPWD * Register faster then @ MOVB R1,*R8 * write next VRAM byte from R1 CI R0,768 * End of screen? JEQ VCHARE * Yes CI R0,735 * next to last ROW? JLE VCHAR3 * Yes VCHARE MOV R7,R0 * VDP ADDRESS=COPY VDP ADDRESS INC R7 * column+1 CI R7,31 * Next row past last column? JLE VCHAR2 * No CLR R7 * Wrap Column back VCHAR2 DEC R3 * repetition-1 JNE VCHAR1 * No done yet JMP VCHAR4 * Exit VCHAR3 AI R0,32 * ROW+1 CI R0,768 * Off screen? JHE VCHARE * Yes reset DEC R3 * REPETITION-1 JNE VCHAR1 * No loop VCHAR4 B @PAGER * RETURN TO XB ********************************************************** * CALL HPUT(row,column,$variable,...) * * CALL HPUT(row,column,number-variable,...) * ********************************************************** * CALL HPUT(row,column,string or number) * R0 VDP SCREEN ADDRESS = PAD2 R5,R0 * R4 VDP STRING ADDRESS = FAC4 R4,R0 * R3 COUNTER = FAC6 R3 * HPUT MOV R11,R9 * save return address MOV @PAD2,R5 * VDP SCREEN ADDRESS MOV @FAC4,R4 * String address or number MOV @FAC6,R3 * Length LI R7,BIAS * Get Screen bias off set LI R1,VDPWD * Register faster then @ LI R8,VDPRD * Register faster then @ CI R3,0 * Length=0? JEQ HPUT2 * Yes HPUT0 MOV R4,R0 * Get String/number address BL @VWADDA * read out VDP address R4 MOVB *R8,R6 * Get $/# from R4 byte into R6 AB R7,R6 * Add bias MOV R0,R4 * Get new update into R4 INC R4 * STRING ADDRESS+1 MOV R5,R0 * Get SCREEN ADDRESS BL @VWADD * write out VDP write address R5 MOVB R6,*R1 * Put R6 onto screen address R0 MOV R0,R5 * Get new update into R5 INC R5 * SCREEN ADDRESS+1 CI R5,768 * Last row:col? JNE HPUT1 * No, so continue loop CLR R5 * Reset back to top row:col HPUT1 DEC R3 * count by -1 JNE HPUT0 * count=0? Restart at top row:col HPUT2 B @PAGER * return to caller ********************************************************** * CALL VPUT(row,column,$variable,...) * * CALL VPUT(row,column,number-variable,...) * ********************************************************** * CALL VPUT(row,column,string or number) * R0 VDP SCREEN ADDRESS = PAD2 R5,R0 * R4 VDP STRING ADDRESS = FAC4 R4,R0 * R3 COUNTER = FAC6 R3 * VPUT MOV R11,R9 * save return address MOV @PAD2,R5 * VDP ADDRESS MOV @FAC4,R4 * String address or number MOV @FAC6,R3 * Length LI R7,BIAS * Get Screen bias off set LI R1,VDPWD * Register faster then @ LI R8,VDPRD * Register faster then @ CI R3,0 * Length=0? JEQ VPUT2 * Yes VPUT0 MOV R4,R0 * Get String/number address BL @VWADDA * read out VDP address R4 MOVB *R8,R6 * Get $/# from R4 byte into R6 AB R7,R6 * Add bias MOV R0,R4 * Get new update into R4 INC R4 * STRING ADDRESS+1 MOV R5,R0 * Get SCREEN ADDRESS BL @VWADD * write out VDP write address R5 MOVB R6,*R1 * Put R6 onto screen address R0 MOV R0,R5 * Get new update into R5 CI R5,767 * OFF SCREEN? JEQ VPUT3 * Yes CI R5,735 * Last ROW? JGT VPUT4 * Yes AI R5,32 * ROW+1 VPUT1 DEC R3 * Length-1 JNE VPUT0 * No loop VPUT2 B @PAGER * return to XB VPUT3 CLR R5 * RESET TO TOP LEFT CHARACTER JMP VPUT1 * Always loop VPUT4 AI R5,-735 * Reset back to top ROW JMP VPUT1 * Always loop ********************************************************** * CALL HGET(row,column,length,$variable) * ********************************************************** * R0 VDP SCREEN ADDRESS = PAD2 R5,R0 * R4 VDP STRING ADDRESS = PAD4 R4,R0 * R3 Length = PAD6 R3 * HGET MOV R11,R9 * save return address MOV @PAD2,R5 * VDP SCREEN ADDRESS MOV @PAD4,R4 * String address MOV @PAD6,R3 * Length LI R7,BIAS * Get Screen bias off set LI R1,VDPWD * Register faster then @ LI R8,VDPRD * Register faster then @ HGET0 MOV R5,R0 * Get Screen Address BL @VWADDA * read out VDP address R5 MOVB *R8,R6 * Get Screen byte into R6 SB R7,R6 * Subtract bias MOV R0,R5 * Get new update into R5 INC R5 * SCREEN ADDRESS+1 CI R5,768 * Last row:col? JNE HGET1 * No, so continue loop CLR R5 * Reset back to top row:col HGET1 MOV R4,R0 * Get STRING ADDRESS BL @VWADD * write out VDP write address R4 MOVB R6,*R1 * Put R6 onto String address R0 MOV R0,R4 * Get new String update into R4 INC R4 * STRING ADDRESS+1 DEC R3 * Length-1 JNE HGET0 * count=0? Restart at top row:col HGET2 B @PAGER * return to caller ********************************************************** * CALL VGET(row,column,length,$variable) * ********************************************************** * R0 VDP SCREEN ADDRESS = PAD2 R5,R0 * R4 VDP STRING ADDRESS = PAD4 R4,R0 * R3 Length = PAD6 R3 * VGET MOV R11,R9 * save return address MOV @PAD2,R5 * VDP ADDRESS MOV @PAD4,R4 * String address or number MOV @PAD6,R3 * Length LI R7,BIAS * Get Screen bias off set LI R1,VDPWD * Register faster then @ LI R8,VDPRD * Register faster then @ VGET0 MOV R5,R0 * Get Screen address BL @VWADDA * read out VDP address R5 MOVB *R8,R6 * Get Screen from R5 into R6 SB R7,R6 * Subtact bias MOV R0,R5 * Get new Screen update into R5 CI R5,735 * Last ROW? JLE VGET2 * Yes, ROW+1 CI R5,767 * OFF SCREEN? JHE VGET1 * Yes, reset ROW:COL to Zero INC R5 * COL+1 S @PAD2,R5 * Original address-screen address JMP VGET3 * Save to String VGET1 CLR R5 * Reset back to top row:col JMP VGET3 * Save to String VGET2 AI R5,32 * ROW+1 VGET3 MOV R4,R0 * Get STRING ADDRESS BL @VWADD * write out VDP write address R4 MOVB R6,*R1 * Put R6 onto screen address R0 MOV R0,R4 * Get new update into R4 INC R4 * STRING ADDRESS+1 DEC R3 * Length-1 JNE VGET0 * No loop B @PAGER * return to XB ********************************************************** * CALL INVERSE(chr#,...) * * CALL INVERSE(ALL,...) * ********************************************************** * R0 TEMP VDP * R1 CHARACTER ADDRESS = FAC * R2 NUMBER CHAR COUNT = PAD * R3 ADDRESS OF R4 TO R7 INVERS MOV R11,R9 * save return address MOV @FAC,R1 * CHARACTER ADDRESS CI R1,0 * ALL flag? JNE INV1 * No single character defintion LI R1,>03F0 * Cursor first character LI R2,129 * Load number of characters JMP INV2 * Go do ALL INV1 LI R2,1 * Load 1 character * Get 4 bytes of character definition INV2 LI R3,>83E8 * BUFFER in R4 to R7 MOV R1,R0 * Copy VDP Char Address BL @VWADDA * read out VDP address LI R8,VDPRD * Register faster then address MOVB *R8,*R3+ * read next VDP byte to RAM MOVB *R8,*R3+ * read next VDP byte to RAM MOVB *R8,*R3+ * read next VDP byte to RAM MOVB *R8,*R3+ * read next VDP byte to RAM MOVB *R8,*R3+ * read next VDP byte to RAM MOVB *R8,*R3+ * read next VDP byte to RAM MOVB *R8,*R3+ * read next VDP byte to RAM MOVB *R8,*R3+ * read next VDP byte to RAM INV R4 * INVERT BITS INV R5 * INVERT BITS INV R6 * INVERT BITS INV R7 * INVERT BITS LI R3,>83E8 * BUFFER in R4 to R7 MOV R1,R0 * Copy VDP Char Address BL @VWADD * write out VDP address LI R8,VDPWD * Register faster then address MOVB *R3+,*R8 * write next VDP byte from RAM MOVB *R3+,*R8 * write next VDP byte from RAM MOVB *R3+,*R8 * write next VDP byte from RAM MOVB *R3+,*R8 * write next VDP byte from RAM MOVB *R3+,*R8 * write next VDP byte from RAM MOVB *R3+,*R8 * write next VDP byte from RAM MOVB *R3+,*R8 * write next VDP byte from RAM MOVB *R3+,*R8 * write next VDP byte from RAM AI R1,8 * Next Character Definition DEC R2 * Character counter -1 JNE INV2 * 0? No keep looping B @PAGER * return to XB ************************************************************* * CALL COLLIDE(#SPR,#SPR,TOLERANCE,DOTROW,DOTCOL) * ************************************************************* * PAD = SPRITE 1 RETURN=ROW * PAD2 = SPRITE 2 RETURN=COLUMN * FAC = TOLERANCE COLLSP MOV R11,R9 * save return address * LOOK FOR SPRITE COINCIDENCE COLL LI R8,PAD * PAD CLR R0 * ZERO OUT MOVB *R8+,R0 * Sprite #1 ROW in high byte CLR R4 * ZERO OUT MOVB *R8+,R4 * Sprite #1 COL in high byte CLR R1 * ZERO OUT MOVB *R8+,R1 * Sprite #2 ROW in high byte CLR R5 * ZERO OUT MOVB *R8+,R5 * Sprite #2 COL in high byte MOV @FAC,R7 * TOLERANCE SWPB R7 * Put into high byte CLR @PAD * zero out CLR @PAD2 * zero out *** CHECK FOR OFF SCREEN LI R6,>C000 * Off screen value C R0,R6 * To Sprite #1 ROW to high? JHE COLL * Yes defualt zero C R1,R6 * To Sprite #2 ROW to high? JHE COLL * Yes defualt zero *** Row comparison MOV R1,R8 S R0,R8 * Sprite #2 ROW-Sprite #1 ROW ABS R8 * No negative value C R8,R7 * Within tolerance? JGT COLL * No defualt zero *** Column comparison MOV R5,R8 S R4,R8 * Sprite #2 COL-Sprite #1 COL ABS R8 * No negative value C R8,R7 * Within tolerance? JGT COLLO * No defualt zero SWPB R0 * Sprite #1 ROW in low byte MOV R0,@PAD * Save Sprite #1 ROW to XB SWPB R4 * Sprite #1 COL in low byte MOV R4,@PAD2 * Save Sprite #1 COL to XB COLLO B @PAGER * return to XB *********************************************************** * CALL CLEARPRINT * *********************************************************** CLEARP MOV R11,R9 * save return address LI R0,2 * Screen address start COL 3 LI R1,>8000 * Space Character LI R3,24 * ROW counter LI R4,2 * COL copy LI R8,VDPWD * put VDPWD in R8 for faster loop CLEARL BL @VWADD * write out VRAM write address LI R2,28 * Count COL 28 CLEARR MOVB R1,*R8 * Write a byte to next VRAM location DEC R2 * COUNT-1 JNE CLEARR * No loop AI R4,32 * Start COL copy +32 MOV R4,R0 * Get new ROW:COL DEC R3 * ROW-1 JNE CLEARL * Not zero continue B @PAGER * return to XB *********************************************************** * RXB CALL INIT XB ASSEMBLY ROUTINE * CINIT MOV R11,R9 * save return address LI R0,>2000 * RAM destination address LI R1,ALCEND * ROM source address LI R2,>0274 * COUNT INITLP MOV *R1+,*R0+ * Write next RAM word 1 MOV *R1+,*R0+ * Write next RAM word 2 MOV *R1+,*R0+ * Write next RAM word 3 MOV *R1+,*R0+ * Write next RAM word 4 MOV *R1+,*R0+ * Write next RAM word 5 MOV *R1+,*R0+ * Write next RAM word 6 MOV *R1+,*R0+ * Write next RAM word 7 MOV *R1+,*R0+ * Write next RAM word 8 DEC R2 * COUNT-1 JNE INITLP * Repeat if not done MOV *R1+,*R0+ * Last word to load B @PAGER * DONE RETURN TO XB *********************************************************** ALCEND DATA >205A,>24F4,>4000,>AA55 DATA >2038,>2096,>2038,>217E DATA >2038,>21E2,>2038,>234C DATA >2038,>2432,>2038,>246E DATA >2038,>2484,>2038,>2490 DATA >2038,>249E,>2038,>24AA DATA >2038,>24B8,>2038,>2090 DATA >0000,>0000,>0000,>0000 DATA >0000,>0000,>0000,>0000 DATA >0000,>0000,>0000,>0000 DATA >0000,>0000,>0000,>0000 DATA >6520,>C060,>2004,>0281 DATA >4000,>130E,>C001,>0202 DATA >834A,>8CB0,>1606,>8CB0 DATA >1604,>8CB0,>1602,>C030 DATA >0450,>0221,>0008,>10EF DATA >0200,>2500,>C800,>8322 DATA >02E0,>83E0,>0460,>00CE DATA >C81D,>8322,>10F9,>C01D DATA >C06D,>0002,>06A0,>20DC DATA >C0C1,>0603,>0223,>8300 DATA >D0D3,>1361,>0983,>0643 DATA >1612,>C000,>165C,>C0C5 DATA >05C3,>06A0,>2406,>1653 DATA >05C3,>06A0,>23CA,>0204 DATA >834A,>0202,>0008,>DC74 DATA >0602,>15FD,>0380,>06A0 DATA >20F8,>10F5,>C041,>1347 DATA >0A81,>9060,>8312,>1143 DATA >0981,>C141,>0A35,>0225 DATA >0008,>A160,>8310,>045B DATA >C24B,>0643,>1634,>C0C5 DATA >06A0,>23CA,>C0C1,>06A0 DATA >2406,>112D,>06A0,>211C DATA >06A0,>23CA,>6004,>0A30 DATA >A040,>0459,>C28B,>0A51 DATA >09D1,>C201,>D120,>8343 DATA >0984,>1303,>0600,>1123 DATA >0580,>0206,>0001,>C0C5 DATA >0223,>0004,>06A0,>23CA DATA >C0C1,>0643,>05C3,>06A0 DATA >23CA,>0581,>6044,>3981 DATA >C186,>1611,>C187,>0608 DATA >15F5,>0606,>A184,>8180 DATA >150A,>05C3,>045A,>0200 DATA >0700,>0460,>2084,>0200 DATA >1C00,>0460,>2084,>0200 DATA >1400,>0460,>2084,>C01D DATA >C06D,>0002,>06A0,>20DC DATA >C0C1,>0603,>0223,>8300 DATA >D0D3,>0983,>160E,>C000 DATA >1622,>0202,>0008,>0204 DATA >834A,>C0C5,>06A0,>23CA DATA >CD01,>05C3,>0642,>15FA DATA >0380,>0643,>160F,>C000 DATA >1612,>C0C5,>05C3,>06A0 DATA >2406,>160B,>05C3,>06A0 DATA >23CA,>C101,>0201,>834A DATA >0460,>20CA,>06A0,>20F8 DATA >10F8,>0460,>2166,>0460 DATA >216E,>C81D,>2038,>C82D DATA >0002,>83E2,>C82D,>0004 DATA >2044,>02E0,>83E0,>C80B DATA >2040,>C020,>2044,>06A0 DATA >20DC,>C0C1,>0603,>0223 DATA >8300,>D0D3,>0983,>0603 DATA >1332,>0643,>164A,>C2A0 DATA >2038,>162D,>C0C5,>05C3 DATA >06A0,>2406,>9801,>2058 DATA >1620,>0206,>0008,>0204 DATA >834A,>C0C5,>06A0,>23CA DATA >CD01,>05C3,>0646,>15FA DATA >06A0,>22DA,>0225,>0004 DATA >C105,>C046,>06A0,>23E6 DATA >05C4,>D050,>0981,>06A0 DATA >23E6,>C2E0,>2040,>C820 DATA >203E,>830C,>02E0,>2038 DATA >0380,>0200,>0700,>C2E0 DATA >2040,>0460,>2084,>0200 DATA >1C00,>0460,>226E,>C08B DATA >0643,>16F3,>C0C5,>06A0 DATA >23CA,>C0C1,>06A0,>2406 DATA >1102,>0460,>226A,>C020 DATA >2038,>06A0,>211C,>6004 DATA >0A10,>A0C0,>06A0,>23CA DATA >0452,>06A0,>227E,>0206 DATA >834A,>CD83,>DDA0,>2058 DATA >DD84,>CD81,>C0C1,>1602 DATA >04D6,>1005,>0603,>06A0 DATA >2406,>0981,>C581,>C020 DATA >2044,>06A0,>22DA,>0460 DATA >225A,>C80B,>203A,>C805 DATA >203C,>C2E0,>601E,>069B DATA >C020,>2044,>C160,>203C DATA >D190,>0986,>C820,>830C DATA >203E,>C806,>830C,>C806 DATA >8350,>C2E0,>6012,>069B DATA >C020,>2044,>0206,>834A DATA >0204,>001C,>CD84,>DDA0 DATA >2058,>DD84,>C5A0,>831C DATA >C0A0,>830C,>1309,>C116 DATA >C0C0,>0583,>D073,>06A0 DATA >241A,>0584,>0602,>15FA DATA >C2E0,>6028,>069B,>C020 DATA >2044,>C160,>203C,>C2E0 DATA >203A,>045B,>C01D,>C06D DATA >0002,>06A0,>20DC,>C0C1 DATA >0603,>0223,>8300,>D0D3 DATA >0983,>0603,>1302,>0643 DATA >1623,>C000,>1628,>C02D DATA >0004,>C0C5,>05C3,>06A0 DATA >2406,>9801,>2058,>161D DATA >05C3,>06A0,>23CA,>C041 DATA >1307,>C181,>0601,>C0C1 DATA >06A0,>2406,>9050,>1A15 DATA >DC01,>1309,>C0C6,>0981 DATA >C141,>06A0,>2406,>DC01 DATA >0583,>0605,>15FA,>0380 DATA >06A0,>227E,>C02D,>0004 DATA >10E6,>0460,>2166,>0460 DATA >216E,>0200,>1300,>0460 DATA >2084,>06C3,>D803,>8C02 DATA >06C3,>D803,>8C02,>1000 DATA >D060,>8800,>06C1,>D060 DATA >8800,>06C1,>045B,>06C4 DATA >D804,>8C02,>06C4,>0264 DATA >4000,>D804,>8C02,>1000 DATA >D801,>8C00,>06C1,>D801 DATA >8C00,>06C1,>045B,>06C3 DATA >D803,>8C02,>06C3,>D803 DATA >8C02,>1000,>D060,>8800 DATA >045B,>06C4,>D804,>8C02 DATA >06C4,>0264,>4000,>D804 DATA >8C02,>1000,>D801,>8C00 DATA >045B,>C83E,>83E2,>02E0 DATA >83E0,>C80B,>204E,>C081 DATA >0281,>0040,>1B0A,>C0A1 DATA >6010,>0281,>0004,>1605 DATA >C0A2,>0002,>0692,>2466 DATA >1001,>0692,>02E0,>2038 DATA >C80B,>83F6,>0380,>0200 DATA >0B00,>0460,>2084,>02E0 DATA >83E0,>C80B,>204E,>06A0 DATA >000E,>02E0,>2038,>C80B DATA >83F6,>0380,>06A0,>24CA DATA >D82D,>0002,>8C00,>0380 DATA >06A0,>24CA,>D831,>8C00 DATA >0602,>16FC,>0380,>06A0 DATA >24D0,>DB60,>8800,>0002 DATA >0380,>06A0,>24D0,>DC60 DATA >8800,>0602,>16FC,>0380 DATA >C05D,>D82D,>0001,>8C02 DATA >0261,>8000,>D801,>8C02 DATA >0380,>0201,>4000,>1001 DATA >04C1,>C09D,>D820,>203D DATA >8C02,>E081,>D802,>8C02 DATA >C06D,>0002,>C0AD,>0004 DATA >045B ********************************************************** EAINIT MOV R11,R9 * save return address CLR R0 * ZERO OUT R0 LI R1,>2000 * Start address LI R2,8192 * Counter CLRINT MOV R0,*R1+ * CLEAR WORD DECT R2 * Counter-2 JNE CLRINT * ZERO? LI R0,LOW1 * FOUR WORDS LI R1,>2000 * Set up init BL @FOURWS * LOAD IT LI R0,LOW2 * FOUR WORDS LI R1,>2024 * Set up list BL @FOURWS * LOAD IT LI R0,LOW3 * Routines LI R1,>20FA * Set up routines LI R2,1404 * Counter SLOW3 MOV *R0+,*R1+ * LOAD IT DECT R2 * Counter-2 JNE SLOW3 * ZERO? LI R0,LOW4 * Name List LI R1,>3F38 * NAMES & Address LI R2,200 * Counter SLOW4 MOV *R0+,*R1+ * LOAD IT DECT R2 * Counter-2 JNE SLOW4 * ZERO? B @PAGER * return to XB ************************ FOURWS MOV R11,R10 MOV *R0+,*R1+ MOV *R0+,*R1+ MOV *R0+,*R1+ MOV *R0+,*R1+ B *R10 ********************************************************** * EDITOR ASSEMBLER LOWER 8K SUPPORT * Data for Initialization of * Memory Expansion *********************************** LOW1 DATA >A55A,>2128,>2398,>225A LOW2 DATA >A000,>FFD7,>2676,>3F38 LOW3 DATA >0064,>2000,>2EAA,>2094 DATA >21C4,>2094,>2196,>2094,>21DE,>2094,>21F4 DATA >2094,>2200,>2094,>220E,>2094,>221A,>2094,>2228 DATA >209A,>22B2,>20DA,>23BA,>C80B,>2030,>D060 DATA >8349,>2060,>20FC,>132A,>C020,>8350,>1311,>06A0 DATA >2646,>101E,>0281,>3F38,>1319,>C001,>0202 DATA >834A,>8CB0,>1611,>8CB0,>160F,>8CB0,>160D,>C810 DATA >2022,>02E0,>20BA,>C020,>2022,>1309,>0690 DATA >02E0,>83E0,>C2E0,>2030,>045B,>0221,>0008,>10E4 DATA >0200,>0F00,>D800,>8322,>02E0,>83E0,>0460 DATA >00CE,>5820,>20FC,>8349,>02E0,>2094,>0380,>C83E DATA >83E2,>02E0,>83E0,>C80B,>20AA,>C081,>0281 DATA >8000,>1B07,>09C1,>0A11,>0A42,>09B2,>A0A1,>0CFA DATA >C092,>0692,>02E0,>2094,>C80B,>83F6,>0380 DATA >D060,>8373,>0981,>C87E,>8304,>F820,>20FC,>8349 DATA >02E0,>83E0,>C2E0,>2030,>045B,>02E0,>83E0 DATA >C80B,>20AA,>06A0,>000E,>02E0,>2094,>C80B,>83F6 DATA >0380,>06A0,>223A,>D82D,>0002,>8C00,>0380 DATA >06A0,>223A,>D831,>8C00,>0602,>16FC,>0380,>06A0 DATA >2240,>DB60,>8800,>0002,>0380,>06A0,>2240 DATA >DC60,>8800,>0602,>16FC,>0380,>C05D,>D82D,>0001 DATA >8C02,>0261,>8000,>D801,>8C02,>0380,>0201 DATA >4000,>1001,>04C1,>C09D,>D820,>2099,>8C02,>E081 DATA >D802,>8C02,>C06D,>0002,>C0AD,>0004,>045B DATA >0204,>834A,>C014,>C184,>04F6,>04F6,>C140,>1323 DATA >0740,>0203,>0040,>04F6,>04D6,>0280,>0064 DATA >1A13,>0280,>2710,>1A08,>0583,>C040,>04C0,>3C20 DATA >20FA,>D920,>83E3,>0003,>0583,>C040,>04C0 DATA >3C20,>20FA,>D920,>83E3,>0002,>D920,>83E1,>0001 DATA >D520,>83E7,>0545,>1101,>0514,>045B,>C17E DATA >53E0,>20FC,>C020,>8356,>C240,>0229,>FFF8,>0420 DATA >2114,>D0C1,>0983,>0704,>0202,>208C,>0580 DATA >0584,>80C4,>1306,>0420,>2114,>DC81,>9801,>20FE DATA >16F6,>C104,>1352,>0284,>0007,>154F,>04E0 DATA >83D0,>C804,>8354,>C804,>2036,>0584,>A804,>8356 DATA >C820,>8356,>2038,>02E0,>83E0,>04C1,>020C DATA >0F00,>C30C,>1301,>1E00,>022C,>0100,>04E0,>83D0 DATA >028C,>2000,>1332,>C80C,>83D0,>1D00,>0202 DATA >4000,>9812,>20FF,>16EE,>A0A0,>20A4,>1003,>C0A0 DATA >83D2,>1D00,>C092,>13E6,>C802,>83D2,>05C2 DATA >C272,>D160,>8355,>1309,>9C85,>16F2,>0985,>0206 DATA >208C,>9CB6,>16ED,>0605,>16FC,>0581,>C801 DATA >203A,>C809,>2034,>C80C,>2032,>0699,>10E2,>1E00 DATA >02E0,>209A,>C009,>0420,>2114,>09D1,>1604 DATA >0380,>02E0,>209A,>04C1,>06C1,>D741,>F3E0,>20FC DATA >0380,>C80B,>2030,>02E0,>20BA,>0420,>2124 DATA >02E0,>83E0,>1303,>C2E0,>2030,>045B,>D820,>20BA DATA >8322,>0460,>00CE,>04E0,>2022,>53E0,>20FC DATA >C020,>8356,>0420,>2120,>0008,>1332,>0220,>FFF7 DATA >0201,>0200,>0420,>210C,>0580,>C800,>202E DATA >C1E0,>2024,>C147,>04CC,>06A0,>25E0,>0283,>0001 DATA >1624,>058C,>04C3,>1023,>0283,>0046,>161E DATA >04C2,>06A0,>262E,>0283,>003A,>16F7,>C020,>202E DATA >0600,>0201,>0100,>0420,>210C,>06A0,>25E0 DATA >C020,>2022,>1307,>06A0,>2646,>1005,>CB4E,>0016 DATA >C3A0,>2022,>0380,>D740,>F3E0,>20FC,>0380 DATA >06A0,>25C2,>04C4,>D123,>2662,>0974,>C808,>202C DATA >06A0,>2594,>0464,>23F8,>0580,>0240,>FFFE DATA >C120,>2024,>A100,>1808,>8804,>2026,>1B05,>C160 DATA >2024,>C804,>2024,>100A,>C120,>2028,>A100 DATA >8804,>202A,>140C,>C160,>2028,>C804,>2028,>C1C5 DATA >0209,>0008,>06A0,>262E,>0609,>16FC,>10B6 DATA >0200,>0800,>10CC,>A005,>C800,>2022,>10AF,>A800 DATA >202C,>13AC,>0200,>0B00,>10C2,>A005,>C1C0 DATA >10A6,>A005,>DDC0,>DDE0,>20DB,>10A1,>A005,>06A0 DATA >2566,>C000,>1316,>0226,>FFF8,>8106,>1B02 DATA >0514,>1096,>8594,>16F8,>89A4,>0002,>0002,>16F4 DATA >89A4,>0004,>0004,>16F0,>C0E6,>0006,>C250 DATA >C403,>C009,>16FC,>0224,>0008,>C804,>202A,>10EA DATA >A005,>06A0,>2566,>0226,>FFF8,>8106,>13E3 DATA >C296,>1501,>050A,>8294,>16F7,>89A4,>0002,>0002 DATA >16F3,>89A4,>0004,>0004,>16EF,>C296,>1516 DATA >C0E6,>0006,>C253,>C4C0,>C0C9,>16FC,>C246,>6244 DATA >C286,>022A,>0008,>C0C6,>0643,>064A,>C693 DATA >0649,>16FB,>0224,>0008,>C804,>202A,>10D9,>CB44 DATA >0002,>0200,>0C00,>0460,>2432,>0460,>2494 DATA >C28B,>0209,>0006,>C1A0,>202A,>0226,>FFF8,>C106 DATA >8806,>2028,>1AF3,>C806,>202A,>06A0,>262E DATA >DDA0,>20E1,>0609,>16FA,>C580,>0206,>4000,>045A DATA >C28B,>04C0,>C30C,>1308,>06A0,>262E,>D020 DATA >20E1,>06A0,>262E,>A003,>045A,>0209,>0004,>06A0 DATA >262E,>06A0,>25C2,>0A40,>A003,>0609,>16F8 DATA >045A,>0223,>FFD0,>0283,>000A,>1A05,>0223,>FFF9 DATA >0283,>0019,>1B01,>045B,>0200,>0A00,>0460 DATA >2432,>02E0,>83E0,>0200,>2032,>C330,>C270,>C830 DATA >8354,>C830,>8356,>C050,>1D00,>9820,>4000 DATA >20FF,>161D,>0699,>101B,>1E00,>02E0,>20DA,>C020 DATA >202E,>0201,>20DB,>0202,>0004,>0420,>2118 DATA >7000,>0950,>1610,>0982,>C001,>0201,>203C,>0420 DATA >2118,>04C8,>0602,>11D7,>D0F1,>0983,>A203 DATA >045B,>02E0,>20DA,>04C0,>06C0,>0460,>2432,>0201 DATA >3F40,>0221,>FFF8,>C011,>1105,>8060,>202A DATA >16F9,>05CB,>045B,>0200,>0D00,>045B,>2D52,>5163 DATA >6483,>8455,>045C,>5B5F,>5EF0,>F003,>F0F0 DATA >4700,>00C8,>3F38 LOW4 DATA >5554,>4C54,>4142,>2022,>5041,>4420,>2020,>8300 DATA >4750,>4C57,>5320,>83E0,>534F,>554E,>4420 DATA >8400,>5644,>5052,>4420,>8800,>5644,>5053,>5441 DATA >8802,>5644,>5057,>4420,>8C00,>5644,>5057 DATA >4120,>8C02,>5350,>4348,>5244,>9000,>5350,>4348 DATA >5754,>9400,>4752,>4D52,>4420,>9800,>4752 DATA >4D52,>4120,>9802,>4752,>4D57,>4420,>9C00,>4752 DATA >4D57,>4120,>9C02,>5343,>414E,>2020,>000E DATA >584D,>4C4C,>4E4B,>2104,>4B53,>4341,>4E20,>2108 DATA >5653,>4257,>2020,>210C,>564D,>4257,>2020 DATA >2110,>5653,>4252,>2020,>2114,>564D,>4252,>2020 DATA >2118,>5657,>5452,>2020,>211C,>4453,>524C DATA >4E4B,>2120,>4C4F,>4144,>4552,>2124,>4750,>4C4C DATA >4E4B,>2100 *********************************************************** * RXB Character set *********************************************************** CHRLDR MOV R11,R9 * save return address LI R0,>03F8 * VDP destination address BL @VWADD * write out VDP write address LI R1,CHARS * CHARACTER LIST LI R2,96 * COUNT LI R8,VDPWD * Register faster then address CHRLP MOVB *R1+,*R8 * write next VDP byte from ROM 1 MOVB *R1+,*R8 * write next VDP byte from ROM 2 MOVB *R1+,*R8 * write next VDP byte from ROM 3 MOVB *R1+,*R8 * write next VDP byte from ROM 4 MOVB *R1+,*R8 * write next VDP byte from ROM 5 MOVB *R1+,*R8 * write next VDP byte from ROM 6 MOVB *R1+,*R8 * write next VDP byte from ROM 7 MOVB *R1+,*R8 * write next VDP byte from ROM 8 DEC R2 * COUNT-1 JNE CHRLP * Repeat if not done B @PAGER * DONE ************************************************** CHARS BYTE >00,>00,>00,>00,>00,>00,>00,>00 * 31 BYTE >00,>00,>00,>00,>00,>00,>00,>00 * 32 BYTE >00,>10,>10,>10,>10,>00,>10,>00 * ! 33 BYTE >00,>28,>28,>28,>00,>00,>00,>00 * " 34 BYTE >00,>28,>7C,>28,>28,>7C,>28,>00 * # 35 BYTE >00,>38,>54,>30,>18,>54,>38,>00 * $ 36 BYTE >00,>44,>4C,>18,>30,>64,>44,>00 * % 37 BYTE >00,>20,>50,>20,>54,>48,>34,>00 * & 38 BYTE >00,>08,>10,>20,>00,>00,>00,>00 * ' 39 BYTE >00,>08,>10,>10,>10,>10,>08,>00 * ( 40 BYTE >00,>20,>10,>10,>10,>10,>20,>00 * ) 41 BYTE >00,>00,>28,>10,>7C,>10,>28,>00 * * 42 BYTE >00,>10,>10,>7C,>10,>10,>00,>00 * + 43 BYTE >00,>00,>00,>00,>00,>30,>10,>20 * , 44 BYTE >00,>00,>00,>7C,>00,>00,>00,>00 * - 45 BYTE >00,>00,>00,>00,>00,>30,>30,>00 * . 46 BYTE >00,>04,>08,>10,>20,>40,>00,>00 * / 47 BYTE >00,>3C,>4C,>54,>64,>44,>38,>00 * 0 48 BYTE >00,>10,>30,>10,>10,>10,>38,>00 * 1 49 BYTE >00,>38,>44,>08,>10,>20,>7C,>00 * 2 50 BYTE >00,>38,>44,>18,>04,>44,>38,>00 * 3 51 BYTE >00,>08,>18,>28,>48,>7C,>08,>00 * 4 52 BYTE >00,>78,>40,>78,>04,>44,>38,>00 * 5 53 BYTE >00,>38,>40,>78,>44,>44,>38,>00 * 6 54 BYTE >00,>7C,>04,>08,>10,>20,>20,>00 * 7 55 BYTE >00,>38,>44,>38,>44,>44,>38,>00 * 8 56 BYTE >00,>38,>44,>44,>3C,>04,>78,>00 * 9 57 BYTE >00,>00,>30,>30,>00,>30,>30,>00 * : 58 BYTE >00,>00,>30,>30,>00,>30,>10,>20 * ; 59 BYTE >00,>00,>10,>20,>40,>20,>10,>00 * < 60 BYTE >00,>00,>00,>7C,>00,>7C,>00,>00 * = 61 BYTE >00,>00,>10,>08,>04,>08,>10,>00 * > 62 BYTE >00,>38,>44,>08,>10,>00,>10,>00 * ? 63 BYTE >00,>38,>44,>54,>58,>40,>3C,>00 * @ 64 BYTE >00,>38,>44,>44,>7C,>44,>44,>00 * A 65 BYTE >00,>78,>24,>38,>24,>24,>78,>00 * B 66 BYTE >00,>38,>44,>40,>40,>44,>38,>00 * C 67 BYTE >00,>78,>24,>24,>24,>24,>78,>00 * D 68 BYTE >00,>7C,>40,>78,>40,>40,>7C,>00 * E 69 BYTE >00,>7C,>40,>78,>40,>40,>40,>00 * F 70 BYTE >00,>38,>44,>40,>4C,>44,>38,>00 * G 71 BYTE >00,>44,>44,>7C,>44,>44,>44,>00 * H 72 BYTE >00,>38,>10,>10,>10,>10,>38,>00 * I 73 BYTE >00,>04,>04,>04,>04,>44,>38,>00 * J 74 BYTE >00,>44,>48,>50,>70,>48,>44,>00 * K 75 BYTE >00,>40,>40,>40,>40,>40,>7C,>00 * L 76 BYTE >00,>44,>6C,>54,>44,>44,>44,>00 * M 77 BYTE >00,>44,>64,>54,>54,>4C,>44,>00 * N 78 BYTE >00,>38,>44,>44,>44,>44,>38,>00 * O 79 BYTE >00,>78,>44,>44,>78,>40,>40,>00 * P 80 BYTE >00,>38,>44,>44,>54,>4C,>3C,>00 * Q 81 BYTE >00,>78,>44,>44,>78,>48,>44,>00 * R 82 BYTE >00,>38,>44,>30,>08,>44,>38,>00 * S 83 BYTE >00,>7C,>10,>10,>10,>10,>10,>00 * T 84 BYTE >00,>44,>44,>44,>44,>44,>38,>00 * U 85 BYTE >00,>44,>44,>44,>44,>28,>10,>00 * V 86 BYTE >00,>44,>44,>44,>54,>54,>28,>00 * W 87 BYTE >00,>44,>28,>10,>10,>28,>44,>00 * X 88 BYTE >00,>44,>44,>28,>10,>10,>10,>00 * Y 89 BYTE >00,>7C,>08,>10,>20,>40,>7C,>00 * Z 90 BYTE >00,>38,>20,>20,>20,>20,>38,>00 * [ 91 BYTE >00,>00,>40,>20,>10,>08,>04,>00 * \ 92 BYTE >00,>38,>08,>08,>08,>08,>38,>00 * ] 93 BYTE >00,>10,>38,>54,>10,>10,>10,>00 * ^ 94 BYTE >00,>00,>00,>00,>00,>00,>7C,>00 * _ 95 BYTE >00,>20,>10,>08,>00,>00,>00,>00 * ` 96 BYTE >00,>00,>00,>38,>48,>48,>3C,>00 * a 97 BYTE >00,>20,>20,>38,>24,>24,>38,>00 * b 98 BYTE >00,>00,>00,>1C,>20,>20,>1C,>00 * c 99 BYTE >00,>04,>04,>1C,>24,>24,>1C,>00 * d 100 BYTE >00,>00,>00,>1C,>28,>30,>1C,>00 * e 101 BYTE >00,>0C,>10,>38,>10,>10,>10,>00 * f 102 BYTE >00,>00,>00,>1C,>24,>1C,>04,>38 * g 103 BYTE >00,>20,>20,>38,>24,>24,>24,>00 * h 104 BYTE >00,>10,>00,>30,>10,>10,>38,>00 * i 105 BYTE >00,>08,>00,>08,>08,>08,>48,>30 * j 106 BYTE >00,>20,>20,>24,>38,>28,>24,>00 * k 107 BYTE >00,>30,>10,>10,>10,>10,>38,>00 * l 108 BYTE >00,>00,>00,>78,>54,>54,>54,>00 * m 109 BYTE >00,>00,>00,>38,>24,>24,>24,>00 * n 110 BYTE >00,>00,>00,>18,>24,>24,>18,>00 * o 111 BYTE >00,>00,>00,>38,>24,>38,>20,>20 * p 112 BYTE >00,>00,>00,>1C,>24,>1C,>04,>04 * q 113 BYTE >00,>00,>00,>28,>34,>20,>20,>00 * r 114 BYTE >00,>00,>00,>1C,>30,>0C,>38,>00 * s 115 BYTE >00,>10,>10,>38,>10,>10,>0C,>00 * t 116 BYTE >00,>00,>00,>24,>24,>24,>1C,>00 * u 117 BYTE >00,>00,>00,>44,>28,>28,>10,>00 * v 118 BYTE >00,>00,>00,>44,>54,>54,>28,>00 * w 119 BYTE >00,>00,>00,>24,>18,>18,>24,>00 * x 120 BYTE >00,>00,>00,>24,>24,>1C,>04,>38 * y 121 BYTE >00,>00,>00,>3C,>08,>10,>3C,>00 * z 122 BYTE >00,>0C,>10,>10,>20,>10,>10,>0C * { 123 BYTE >00,>10,>10,>10,>00,>10,>10,>10 * | 124 BYTE >00,>60,>10,>10,>08,>10,>10,>60 * } 125 BYTE >00,>00,>20,>54,>08,>00,>00,>00 * ~ 126 ********************************************************** * CALL HEX($variable,variable,...) * * CALL HEX(variable,$variable,...) * * CALL HEX(">####",variable,...) * ********************************************************** * HEX VDP to RAM (String to Address) LES version * R0 TEMP ASC TO HEX * R1 HEX ADDRESS = FAC * R2 STRING = PAD * R3 COUNTER = R3 ASCHEX MOV R11,R9 * save return address CLR R1 * clear result reg LI R2,PAD * assume 4-bytes in PAD-PAD3 LI R3,4 * load counter HEX01 CLR R0 * zero out work reg MOVB *R2+,R0 * Get ASC byte SWPB R0 * get byte to LSB * ASC CHECK VALUE CI R0,103 * g ? JHE ERROR * ERROR BAD ARGUMENT CI R0,97 * a ? JHE HEX02 * Valid CI R0,71 * G ? JHE ERROR * ERROR BAD ARGUMENT CI R0,65 * A ? JHE HEX02 * Valid CI R0,58 * : ? JHE ERROR * ERROR BAD ARGUMENT CI R0,47 * / ? JLE ERROR * ERROR BAD ARGUMENT * Convert ASC to value HEX02 AI R0,>FFD0 * correct for 0-9 in LSB CI R0,>000A * LSB < 10? JLT HEX03 * we're good AI R0,>FFF9 * correct LSB for A-F * Add digit and shift if not done HEX03 A R0,R1 * add hex digit to result reg LSB DEC R3 * decrement counter JEQ HEX04 * return if done SLA R1,4 * shift hex digit left 1 nybble JMP HEX01 * get another hex digit HEX04 MOV R1,@FAC * get result to FAC for CIF B @PAGER * return to XB ERROR LI R1,>994A * ERROR CODE FLAG NERROR MOV R1,@ARG * LOAD ERROR CODE FLAG B @PAGER * return to XB *********************************************************** * CALL ALPHALOCK(numeric-variable) * *********************************************************** ALPHA MOV R11,R9 * save return address MOV R12,R8 * save R12 value for later CLR R12 * ZERO OUT R12 SBZ 21 * PUT ALPHA LOCK STROBE SRC R12,14 * WAIT TB 7 * ALPHA LOCK DOWN? SBO 21 * RESET ALPHA LOCK STROBE JEQ ALPHAF * RETURN ALPHA LOCK OFF LI R1,>994A * ALPHA LOCK ON ALPHAO MOV R8,R12 * Restore R12 MOV R1,@FAC * Save value to FAC B @PAGER * return to XB ALPHAF CLR R1 * ZERO OUT FLAG JMP ALPHAO * ALPHA LOCK OFF *********************************************************** * CALL ISRON(variable) * *********************************************************** XISRON MOV R11,R9 * save return address MOV @FAC,@ISR * Put FAC into ISR Interupt hook JMP NEXIT * exit *********************************************************** * CALL ISROFF(variable) * *********************************************************** XISROF MOV R11,R9 * save return address MOV @ISR,@ISR * Compare if new ISR HOOK JEQ NHOOK * No MOV @ISR,@FAC * Put ISR Hook into FAC NHOOK CLR @ISR * Clear ISR Hook NEXIT CLR @STATUS * Clear GPL stuse byte B @PAGER * return to XB ************************ SPRLP MOVB R1,*R8 * Write a byte to next VRAM location DEC R2 * COUNT-1 JNE SPRLP * LOOP RT *********************************************************** AORG >7FFA PAGER CLR @>6000 * RESTORE PAGE ONE B *R9 * return to caller *********************************************************** END 2 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted December 6, 2022 Share Posted December 6, 2022 Thank you. What did you intend to demonstrate with it? 1 Quote Link to comment Share on other sites More sharing options...
+RXB Posted December 6, 2022 Share Posted December 6, 2022 2 hours ago, apersson850 said: Thank you. What did you intend to demonstrate with it? Yea going to show some video after some code clean up. Quote Link to comment Share on other sites More sharing options...
apersson850 Posted December 7, 2022 Share Posted December 7, 2022 Since we discuss BL versus BLWP and you argued for using BLWP when programming for the console, I thought you wanted to show that. But I checked - there isn't a single BLWP in there. Quite a few BL, though. Are you trying to say you changed your opinion on this? 3 Quote Link to comment Share on other sites More sharing options...
Willsy Posted December 7, 2022 Author Share Posted December 7, 2022 I also looked at Rich's code. Firstly, it's nice code. But the code itself doesn't really support the argument I think Rich was making (unless I misunderstood him). The subroutines presented all save their return address (usually into R9) and then only BL one level deep. Sometimes there a couple of BL's in the same routine, but they're not nested. In this scenario, the action Rich has chosen (saving the return address into a register, taking a BL, and then returning to the parent via the address in the saved register) is absolutely the correct one. Also, as Rich and @apersson850 pointed out up-thread, when you're working in a stock console environment you basically have no memory at all, so a BLWP is a major luxury. It's frankly a miracle that TI/Microsoft/Whoever-the-hell-wrote-the-TI-OS managed to make it all work at all. Just as an aside, I noticed that the last three or four subroutines in Rich's code save the return address, but don't take a BL. In those cases the MOV R11,R9 (or whatever they were) could be removed. I'm more interested in knowing where the tipping point is in selecting BLWP over BL - assuming you have expansion memory in which to host a workspace. My current hunch is: If you're saving more than two registers elsewhere and having to restore them, you might as well take a BLWP and have the luxury of hosting your subroutine in it's own register space. Or, as I might be inclined to do, have workspaces for each logical layer of my code. TurboForth (the only major assembly language application I have written for the TI) does not do this, however there are places in the code where I wish I had done that. The block editor is the first area of the code-space that springs to mind. It's totally un-related to the rest of the Forth system - it's basically a stand-alone program/utility. It would have made much more sense to host it in its own workspace. 4 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted December 7, 2022 Share Posted December 7, 2022 (edited) Another way of describing a tipping point is if the number of registers involved in hosting the arguments needed by the subroutine you call plus the number of working registers the subroutine need for its internal processing exceed what you have available in the workspace (remember that you may have some global variables there too), then you have two options: Replace the BL call by a BLWP call. Consider if a simple LWPI is sufficient to get a new workspace without actually calling a subroutine as well. Note that you can also do this inside the subroutine called by BL, not only in inline code. Then you don't need to save R11. It will still be there, in the previous workspace. The advantage of LWPI is that R13-R15 are free to use as well, since they aren't needed for return linkage. The disadvantage is that you don't automatically get a pointer to your previous workspace injected into R13. You have to provide access to the previous workspace in a different way, if your arguments are there. It's simple enough - LWPI R13, OLDWORKSAPCE will fix it, but that's another instruction to execute. Another disadvantage, if you use the BL instruction to call a subroutine and do LWPI inside, is that to be able to reset the workspace you need to know which workspace was used by the caller. The TMS 9900 does have STWP (STore Workspace Pointer, i.e. save what it is now to a register), but not LWP (Load Workspace Pointer, i.e. set the new value from a register). Instead you have to move the stored value to the word after the LWPI instruction where you restore the caller's registers, which requires self modifying code, and that doesn't run from ROM, if that's a desire you have. If you make the subroutine for a specific program, then you probably do know the caller's workspace, but if you try to write a more general subroutine, then BLWP is a better option, since you never know what the caller is up to. There you go for a different tipping point, not based on the number of registers you save, but the intended use case for the subroutine. Edited December 7, 2022 by apersson850 3 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted December 7, 2022 Share Posted December 7, 2022 2 hours ago, Willsy said: Just as an aside, I noticed that the last three or four subroutines in Rich's code save the return address, but don't take a BL. In those cases the MOV R11,R9 (or whatever they were) could be removed. It's for consistency. The return to BASIC is via the PAGER routine, and that uses R9 to return via, regardless of whether the routine that ends there did or did not call any subroutine. 1 Quote Link to comment Share on other sites More sharing options...
speccery Posted December 7, 2022 Share Posted December 7, 2022 2 hours ago, Willsy said: I'm more interested in knowing where the tipping point is in selecting BLWP over BL - assuming you have expansion memory in which to host a workspace. My current hunch is: If you're saving more than two registers elsewhere and having to restore them, you might as well take a BLWP and have the luxury of hosting your subroutine in it's own register space. Or, as I might be inclined to do, have workspaces for each logical layer of my code. TurboForth (the only major assembly language application I have written for the TI) does not do this, however there are places in the code where I wish I had done that. The block editor is the first area of the code-space that springs to mind. It's totally un-related to the rest of the Forth system - it's basically a stand-alone program/utility. It would have made much more sense to host it in its own workspace. My opinion is that never To be more precise, in my opinion BLWP type activities are fine if you're calling an operating system function (although a XOP would be better but requires a proper ROM vectors), or doing a context switch (perhaps for an interrupt but also for other things). Otherwise I'd prefer BL. In fact the only cases where I've used BLWP have been for debug or I/O purposes, to output a value in a register without messing any of the other registers. For this thing BLWP is very convenient. In those cases the workspace might even be in external slow RAM, since for debug purposes you typically don't care about performance. When you use BL and "manually" stack the registers you need, you create reentrant code. Which can support recursion. It doesn't have to be immediate recursion, i.e. the function calling itself, but also indirect: so you're at function A, and you call function B, which then calls back function A. Or however deep this might be. The point is, that with reentrant code you don't need to know if a routine you're calling is eventually calling the very same routine again, before returning. This topic is also closely related to calling conventions. The C language calling convention could use R10 as a stack pointer (and could use the same register for the frame pointer). In a C calling convention you'd typically pass the first four arguments to the function in R0-R3, permit the called function to destroy the values in R0-R3 but preserve other registers, and provide the return value in R0 for example. If this is standardised it becomes easy to know how a function is supposed to behave. 5 Quote Link to comment Share on other sites More sharing options...
Switch1995 Posted December 7, 2022 Share Posted December 7, 2022 As someone learning ASSM, I've really enjoyed following this discussion. Good stuff! 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 7, 2022 Share Posted December 7, 2022 45 minutes ago, speccery said: When you use BL and "manually" stack the registers you need, you create reentrant code. Thanks for reminding us of this. I kind of take for granted given my bias. 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted December 7, 2022 Share Posted December 7, 2022 1 hour ago, speccery said: My opinion is that never Then you are concerned about execution performance, I presume? In my programming life I also care about programming performance and reliability, not only execution speed. To isolate caller from called a BLWP could be handy, and isolation is usually good to prevent one stupid mistake to kill more than itself. Unless it's real-time programming where performance is cruical, or it simply doesn't work. But the stacking concept is good for recursion, direct or indirect. Using R0-R3 as arguments could work, but not allowing the called routine any work registers (except destroy the arguments) doesn't sound efficient to me. I would probably prefer to pass arguments on the stack in that case, and make a local copy if I want to access it frequently before the subroutine has finished its job. Having the stack pointer also be the frame pointer/environment pointer, isn't that a bit confusing if you need to push/top temporaries on the stack? I've always preferred a separate frame pointer. 1 Quote Link to comment Share on other sites More sharing options...
