Pirate ship for Commodore Pet 2001
Frozone212
It's real short and too easy but Fun to program for. Commodore basic does not support the ELSE statement. Therefore, I am somewhat screwed with decision making so the majority of commands done through INPUT. Bad practice but AFAIK, there is no extension that adds the command, I could be wrong here. I hope to expand this down the road.
Enjoy
Pirate Ship.d64
While it's a little more complex, you can use GOTO to implement IF/ELSE logic.
To cover multiple lines do this:
10 if 2 < 1 then goto 60
20 rem this is start of ELSE logic
30 print "in the ELSE block"
40 print "still in ELSE block
50 goto 90
60 rem this is start of IF TRUE logic
70 print "in the IF block"
80 print "still in IF block"
90 rem endif
You can sometimes use ON .. GOTO to simulate IF/THEN/ELSE:
10 IF A$="THIS" THEN 20 ELSE 30
Becomes:
10 ON (A$="THIS")+2 GOTO 20,30
This relies on the fact that if A$="THIS" is true, it is assigned the value -1 (except on Applesoft, where it is assigned the value 1), and if A$="THIS" is false, it is assigned the value 0.  Adding 2 to the result makes it 1 for the true result, and 2 for the false result.  You'll need to add a GOTO or something to skip around the code for the false result (so the true result doesn't fall through to the false result).
You can also do this with GOSUB:
10 ON (A$="THIS")+2 GOSUB 20,30
11 STOP:REM OR GOTO SOMEWHERE ELSE
20 PRINT "TRUE":RETURN
30 PRINT "FALSE":RETURN
