Shift838 Posted December 2, 2022 Share Posted December 2, 2022 (edited) i know a couple of different connectors have been used on the 99/4A to connect the internal power supply to the actual TI-99/4A main board. I am looking for a part number for the one in the photo, for both male and female options. Anyone know what it is? Edited December 2, 2022 by Shift838 Quote Link to comment Share on other sites More sharing options...
Tuxon86 Posted December 2, 2022 Share Posted December 2, 2022 3 minutes ago, Shift838 said: i know a couple of different connectors have been used on the 99/4A to connect the internal power supply to the actual TI-99/4A main board. I am looking for a part number for the one in the photo, for both male and female options. Anyone know what it is? Isn't that just a regular molex? Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 2, 2022 Share Posted December 2, 2022 26 minutes ago, Tuxon86 said: Isn't that just a regular molex? This is what I’ve been using. It fits. 2 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 2, 2022 Author Share Posted December 2, 2022 25 minutes ago, Tuxon86 said: Isn't that just a regular molex? it's some type of molex Quote Link to comment Share on other sites More sharing options...
Tuxon86 Posted December 2, 2022 Share Posted December 2, 2022 15 minutes ago, Shift838 said: it's some type of molex It look the same as an old style PC hard disk drive four pin female molex power connector. Quote Link to comment Share on other sites More sharing options...
Stuart Posted December 2, 2022 Share Posted December 2, 2022 40 minutes ago, Tuxon86 said: It look the same as an old style PC hard disk drive four pin female molex power connector. It's not. The connector used in the TI is a fair bit smaller (but that's hard to tell from the photo) and the chamfering on the corners is different. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted December 2, 2022 Share Posted December 2, 2022 You might want to take a look at this one. . .or maybe this one. Both have the triangular end. . .I bought a few of these a while back, and they seemed to fit fine. 1 Quote Link to comment Share on other sites More sharing options...
emarquis1 Posted December 2, 2022 Share Posted December 2, 2022 I'm looking for the same connectors. I found these on Amazon and ordered a pack. I will let you know if they are correct. Molex 4-Circuits Connector, w/14-20 AWG .093" Pins Panel Mount (Pack of 3 Set): Amazon.com: Industrial & Scientific Ed 2 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 3, 2022 Author Share Posted December 3, 2022 3 hours ago, emarquis1 said: I'm looking for the same connectors. I found these on Amazon and ordered a pack. I will let you know if they are correct. Molex 4-Circuits Connector, w/14-20 AWG .093" Pins Panel Mount (Pack of 3 Set): Amazon.com: Industrial & Scientific Ed Please let me know once you received them. Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 3, 2022 Share Posted December 3, 2022 14 hours ago, emarquis1 said: I'm looking for the same connectors. I found these on Amazon and ordered a pack. I will let you know if they are correct. Molex 4-Circuits Connector, w/14-20 AWG .093" Pins Panel Mount (Pack of 3 Set): Amazon.com: Industrial & Scientific Ed Those appear to be .198 - and the ones that I’ve been using are .156 - they might be a little large. Quote Link to comment Share on other sites More sharing options...
emarquis1 Posted December 4, 2022 Share Posted December 4, 2022 20 hours ago, Shift838 said: Please let me know once you received them. The ones I received are a size larger than the original TI ones. I will be using them anyway. Quote Link to comment Share on other sites More sharing options...
emarquis1 Posted December 4, 2022 Share Posted December 4, 2022 1 hour ago, emarquis1 said: The ones I received are a size larger than the original TI ones. I will be using them anyway. Also, they suck. If you don't cut the pins off of the strips just right, the pins will push all the way to the connector opening. Quote Link to comment Share on other sites More sharing options...
emarquis1 Posted December 4, 2022 Share Posted December 4, 2022 ...and then there is this: MOLEX 76650-0065 .062" 4 CIRCUIT POWER PLUG RECEPTACLE SOCKET SET OF 2 W/ PINS 10151153449 | eBay Quote Link to comment Share on other sites More sharing options...
Shift838 Posted December 5, 2022 Author Share Posted December 5, 2022 I do believe it will be the .062 versions. I have found the below out mouser and based on my dial caliper they seem to be accurate. 03-06-1042 Molex | Mouser 03-06-2042 Molex | Mouser These are the mating pairs. I am going to get some ordered as I need to put in an order any way. 2 Quote Link to comment Share on other sites More sharing options...
emarquis1 Posted December 6, 2022 Share Posted December 6, 2022 These are the correct connectors. Just received a set and verified. Molex (4-Circuits) Male & Female Receptacle Plug, w/Terminal sockets w/18-24 AWG Standard .062" Pins, Pitch 3.68mm: Amazon.com: Industrial & Scientific 2 Quote Link to comment Share on other sites More sharing options...
