vol Posted December 3, 2022 Share Posted December 3, 2022 I have just added results for the Geneve 9640 into my project . The Geneve shows itself very good, its results are much better than results for the Apple IIgs, IBM PC XT, or Sinclair QL. It is only slightly slower than the Amiga 500 or MSX turboR. Maybe it is possible that somebody can write more optimized code for the TMS9995 and overrun the Amiga. However the main loop is only 14 assembly instructions so this is rather unlikely. The TMS9995 also shows an excellent code density, only the DEC T-11 main loop is one instruction shorter. Sorry I was lazy to make a better palette so generated pictures look rather rawish. I can't help but compare several speed results with results of the old good Fractal 2.0 program that can generate and save very impressive images. We can compare the performance for the same Mandelbrot parameters: x in [-2.25, .75], y in [-1.24, 1.24], iterations = 37. Both programs use GRAPHIC6 (512x212, 16 colors), screenshots are below: Fractals 2.0 - about 42 minutes; Super Fast Mandelbrot Generator - about 14 seconds. The generated images are not exactly the same and don't exactly know why. It would be great if someone could run my programs on a real machine (I have to use MAME/MESS) and check several of the results with the results published in the main table of my project. Several screenshots would also be great. My programs don't use delays between using the VDP ports so it a question, can they work at all? 😄 11 1 Quote Link to comment Share on other sites More sharing options...
WhataKowinkydink Posted December 3, 2022 Share Posted December 3, 2022 Impressive!! Thanks for sharing. Reminds me for the second time today that I need to get my old Geneve MESS/MAME setup working again. 1 Quote Link to comment Share on other sites More sharing options...
Nick99 Posted December 3, 2022 Share Posted December 3, 2022 (edited) Where can I download the program, to try it on my Geneve? Edited December 3, 2022 by Nick99 1 Quote Link to comment Share on other sites More sharing options...
vol Posted December 3, 2022 Author Share Posted December 3, 2022 (edited) 1 hour ago, Nick99 said: Where can I download the program, to try it on my Geneve? Sorry, the link needs several clicks to get it from the benchmark page. You can run each program individually or run AUTOEXEC to get a menu. Edited December 3, 2022 by vol 1 2 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted December 3, 2022 Share Posted December 3, 2022 By the way, I recommend to use the "semimonotonic" coloring in Fractals; it will deliver nicer pictures. This mode does not cycle the colors but it advances monotonically for all even and odd iterations. Thus, the color sequence is 1-2-1-2-1-2-...-2-1-2-3-2-3-2-3-2-...-2-3-4-3-4-3-4-3... -15 (highest iteration) - 0 (Mandelbrot set). Fractals uses a fixed point arithmetic that I optimized for the on-chip RAM; it uses 8 bytes, with 2 bytes integer and 6 bytes fraction. The coloring mode does not affect the performance. Also, I followed the brute force approach to run the iteration for each point on the screen without any further optimizations (beyond the math routines). This is the semimonotonic coloring: This is the cyclic coloring: The semimonotonic coloring shows its advantages in deep zooms: 10 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted December 21, 2022 Share Posted December 21, 2022 The longer I look at our Christmas tree, the more I see a Mandelbrot set. Weird. 3 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted December 21, 2022 Share Posted December 21, 2022 1 hour ago, mizapf said: The longer I look at our Christmas tree, the more I see a Mandelbrot set. Weird. Chaos. 2 Quote Link to comment Share on other sites More sharing options...
vol Posted December 25, 2022 Author Share Posted December 25, 2022 (edited) On 12/21/2022 at 9:20 PM, mizapf said: The longer I look at our Christmas tree, the more I see a Mandelbrot set. Weird. I have rotated a 512x424 interlaced picture that was generated by my program and got an Xmas tree! 😀 Happy Holidays for everybody! Edited December 25, 2022 by vol 4 Quote Link to comment Share on other sites More sharing options...
