mutantcamel1979 Posted December 5, 2022 Share Posted December 5, 2022 So I have acquired a great Quick Disk for the TI74. It works fine using device "8", the same as the CC40. I thought I would try plug the homemade adapter I have which allows me to use the PC Interface with the CC40 with the Quick Disk! No surprise, it doesn't work. Obviously not just a case of using a Dockbus to Hexbus adapter. The CC40 Quick Disk must have software in it, that the TI-74 version doesn't have! Pity Really. Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 5, 2022 Share Posted December 5, 2022 The Hexbus/Dockbus protocol is the same, and should be 100% cross compatible. Make sure you double check the pinout of your adapter. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted December 5, 2022 Share Posted December 5, 2022 I have a premade adapter in my store if you need 1 Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted January 1, 2023 Author Share Posted January 1, 2023 On 12/5/2022 at 10:25 PM, arcadeshopper said: I have a premade adapter in my store if you need Thank you. Looks like my adapter just needs the 2 wires for the battery terminal re-soldering. If not I will buy your adapter! 2 Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted July 2, 2023 Author Share Posted July 2, 2023 (edited) After several attempts of trying to fix my adapter, I can't get it to work and I am looking to buy an hexbus to dockbus adapter. For the TI74 Quickdisk to work on my CC40...Would I simply plug an hexbus cable into my CC40, insert the other end straight into the pins of the adapter and then insert the adapter's dockbus pins directly into the dockbus plug of the Quickdisk? On another thread there was mention of using a dupont cable, but I can't see the need for one. Edited July 2, 2023 by mutantcamel1979 Quote Link to comment Share on other sites More sharing options...
