LLightning Posted December 5, 2022 Share Posted December 5, 2022 As you can see from the video the power switch seems to have something to do with my Atarivox problem. If I switch to ON normally I get the static and garbled voice IMG_8184.MOV but if I switch to ON super carefully (kind of like halfway) sometimes I can get the Atarivox to work. I have taken the switch apart and cleaned everything and put more of a bow in the contacts. The issue remained so I actually swapped the power switch with the TV Type switch (because I assume it has had much less use) and that’s where I am right now. Atarivox works perfectly fine on my 7800 and one of my other 2600s. The 2600 in the video is my daily driver and works beautifully other than this issue. Is there a filter or something that I can put on the legs or a modification of the switch to prevent the static? Quote Link to comment Share on other sites More sharing options...
