retrodroid Posted December 7, 2022 Share Posted December 7, 2022 Folks, I'm new here, been trying to get the XB Compiler working using latest version of JUWELL99. However, I'm consistently seeing the error noted in the posting above. I'm wondering if anyone can provide advice on how to proceed? Is someone able to confirm that the "HELLO" example compiles and assembles fine using the latest version of JUWELL99 on their system? All help is appreciated. Quote Link to comment Share on other sites More sharing options...
retrodroid Posted December 7, 2022 Author Share Posted December 7, 2022 I was able to use the Asm994a assembler on the windows machine and it produced a warning. The error log is: If I try to LOAD the assembled HELLO-O.obj file it fails with * NUMERIC OVERFLOW IN 280 Another dead end. Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted December 7, 2022 Share Posted December 7, 2022 Well... This seems to crash the E/A's assembler ...you can tell, because it throws you into option 3, when you hit ENTER. ...That seems to be caused by the wrong DEVICE names in the COPY directives... DEF RUNEA,RUN,RUNV,CON RUNEA B @RUNEA5 FRSTLN L10 DATA PRINT,SC1 L20 DATA GOTO,L10 LASTLN DATA STOP OPTBAS DATA 0 NC0 ZERO DATA 0 ONE DATA 1 PI DATA 3 RND DATA 0 NV0 SC0 SC1 DATA SC1+2 BYTE 5,72,69,76,76,79 EVEN SV0 SA0 NA0 FRSTDT LASTDT EVEN ENDCC COPY "RUNTIME1.TXT" COPY "RUNTIME2.TXT" COPY "RUNTIME3.TXT" END 4 Quote Link to comment Share on other sites More sharing options...
retrodroid Posted December 8, 2022 Author Share Posted December 8, 2022 Woot! I had accidentally/ignorantly used the JUWEL99 directory for my DSK1, when I should have been using the JUWEL4 directory for classic99. It is working now! Thank-you! 2 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted December 8, 2022 Share Posted December 8, 2022 ...Dunno... Quote Link to comment Share on other sites More sharing options...
