masteries Posted December 9, 2022 Share Posted December 9, 2022 (edited) It is a spinner or dial control with 2 buttons; similar to others that are available to use in PC and take advantage of Arkanoid and driving games in MAME With the addition that this controller also provides DB9 output to connect directly to an Atari ST/E or an Amiga 500 / Plus / 600 or other classical or vintage machines. As rotation sensor it uses an industrial grade optical encoder, fully encapsulated; so that it lasts forever. For vintage machines, the control has 4 speeds or resolutions; these are chosen by pressing buttons while connecting power. No pressing any button is the fastest speed. This device contains no 3D printed pieces, knob is made of aluminium. Here a complete video using the Spinner in a PC computer, an Atari ST, and a Commodore Amiga: Manufacturing is under demand, due to the required components are not cheap; and the time needed to assembly one unit is 2 hours, plus testing time, There are two options: -The Spinner controller with DB9 extensor cable (its a 1.5 meters extender cable) a total of 70€ plus shipment. -The Spinner without DB9 extensor (due to you are planning to use this device only in a PC computer) a total of 66€ plus shipment. Currently I need to ask about the shipment of this package, due to it is a small box around 290 grams. Edited: Shipment rates are 14€ for Europe and 16€ for USA - Canada Edited December 15, 2022 by masteries 1 Quote Link to comment Share on other sites More sharing options...
+evg2000 Posted December 10, 2022 Share Posted December 10, 2022 are you using an arduino for decoding the rotary controller and converting to a digital signal for the legacy systems? That's what I did for my CV and INTV paddle controllers. Quote Link to comment Share on other sites More sharing options...
masteries Posted December 15, 2022 Author Share Posted December 15, 2022 On 12/10/2022 at 3:06 PM, evg2000 said: are you using an arduino for decoding the rotary controller and converting to a digital signal for the legacy systems? That's what I did for my CV and INTV paddle controllers. Yes, a STM32 Are the Colecovision paddle based on analog voltage output (read by an ADC input), or variable resistance based such Atari 2600 ones (based in a condenser load until reach high logic level)? Quote Link to comment Share on other sites More sharing options...
+evg2000 Posted December 15, 2022 Share Posted December 15, 2022 I use a 600 P/R rotary encoder attached to an attiny84 which converts to digital pulses sent to optocouplers to open/close the circuits for the CV or InTV controllers. The optocouplers are used to isolate the circuits voltage from the console. here is a picture of the pcb in the controller shell I've open sourced the project for noncommercial use:https://github.com/evg2000/ATTiny84_Version3.1/blob/master/Paddle Controller.pdf Quote Link to comment Share on other sites More sharing options...
masteries Posted January 9 Author Share Posted January 9 Two units manufactured under demand, Yesterday I was using the drill, solder iron, limes xD Quote Link to comment Share on other sites More sharing options...
imstarryeyed Posted January 11 Share Posted January 11 @masteries This looks like a very interesting project, I am very interested in purchasing one from you, have you tested this on an Atari 2600 / 7800 and other classic 9 pin systems? If it works on those systems I think this would be very useful for me, thank you for sharing your project with the community. Quote Link to comment Share on other sites More sharing options...
masteries Posted January 20 Author Share Posted January 20 On 1/11/2023 at 6:51 AM, imstarryeyed said: @masteries This looks like a very interesting project, I am very interested in purchasing one from you, have you tested this on an Atari 2600 / 7800 and other classic 9 pin systems? If it works on those systems I think this would be very useful for me, thank you for sharing your project with the community. Thanks for your post and interest, Currently the USB & DB9 Spinner doesn´t provide analog paddle functionality, in the way Atari 2600, 7800 operate paddles, I researched the needed component to do this, a digital potentiometer (much better and eternal durability than poor common Atari paddle potentiometers) but the major problem is that Aliexpress and these sort of stores do not provide with 1 Mega ohm digital potentiometers, And the rest of stores such Digi-key, Mouser..., have really expensive prices for this component (more than 15€ for a single piece is not affordable) I will continue searching for an affodable 1 Mega ohm digital potentiometer, Quote Link to comment Share on other sites More sharing options...
imstarryeyed Posted January 23 Share Posted January 23 Good luck on your research, it sounds like it is going to be really good. I will continue to follow your topic as I see a real use for this level of compatibility. Thank you for your efforts, they are greatly appreicated! Quote Link to comment Share on other sites More sharing options...
masteries Posted February 10 Author Share Posted February 10 (edited) More components in the way! You can acquire your unit! Edited February 10 by masteries Quote Link to comment Share on other sites More sharing options...
imstarryeyed Posted February 11 Share Posted February 11 @masteries If I was to pay for the upcharge for the necessary parts to make your paddle also compatible with Atari 2600/7800 and other 9 pin systems could you build me one? I think your project would fit nicely with some of my games. Thank you again! Quote Link to comment Share on other sites More sharing options...
+evg2000 Posted February 11 Share Posted February 11 46 minutes ago, imstarryeyed said: @masteries If I was to pay for the upcharge for the necessary parts to make your paddle also compatible with Atari 2600/7800 and other 9 pin systems could you build me one? I think your project would fit nicely with some of my games. Thank you again! the paddle would have to convert the rotary controller to digital. that is how the paddle i created worked for the colecovision and intellivision. the coleco one also worked on the atari Quote Link to comment Share on other sites More sharing options...
masteries Posted February 12 Author Share Posted February 12 On 2/11/2023 at 4:03 AM, imstarryeyed said: @masteries If I was to pay for the upcharge for the necessary parts to make your paddle also compatible with Atari 2600/7800 and other 9 pin systems could you build me one? I think your project would fit nicely with some of my games. Thank you again! I found a way to implement a maintenance free controlled resistor, such original 2600 paddles that uses a potentiometer, but without the worrying low Life expectancy Quote Link to comment Share on other sites More sharing options...
