Brufnus Posted December 11, 2022 Share Posted December 11, 2022 During my intense floppy archiving project, I've come across some picture formats I don't recall to have seen before. It doesn't help much that I've been away from it for many, many years, alas... c".) Anyway, I encountered quite a few RLE and Graphx format pics, but don't know with which programs to display these. Any suggestions? Altso, I lack a good gif viewer for the Geneve... Quote Link to comment Share on other sites More sharing options...
Nick99 Posted December 11, 2022 Share Posted December 11, 2022 MaxRLE was the viewer I used back in the days. A gif-viewer for the Geneve should be found in one of the Geneve-threads in this forum. Quote Link to comment Share on other sites More sharing options...
Brufnus Posted December 11, 2022 Author Share Posted December 11, 2022 6 hours ago, Nick99 said: MaxRLE was the viewer I used back in the days. A gif-viewer for the Geneve should be found in one of the Geneve-threads in this forum. In the mean time, I found gif2 which works, although not as user friendly as I could wish for. Do you know where to find MaxRLE? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted December 11, 2022 Share Posted December 11, 2022 My Fractals program uses RLE, but switches to bitmap whenever the RLE overhead becomes too high. 1 Quote Link to comment Share on other sites More sharing options...
Brufnus Posted December 11, 2022 Author Share Posted December 11, 2022 3 hours ago, mizapf said: My Fractals program uses RLE, but switches to bitmap whenever the RLE overhead becomes too high. Okay, I'll take a look into that... think I have a copy. Thanks! Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted December 11, 2022 Share Posted December 11, 2022 There were several formats in use BITD: CSGD (used by a program of the same name), RLE (used by MAXRLE and several others), GRAPHX (used by the program of the same name), TI Artist fonts and instances (used by the program of the same name), PixPro fonts and images (used by the program of the same name), MYART (used by the program of the same name), The Printer's Apprentice/The Geometer's Apprentice pictures/fonts, YAPP images (read GIF and MYART formats, IIRC), and probably one or two others. . . Quote Link to comment Share on other sites More sharing options...
+mizapf Posted December 11, 2022 Share Posted December 11, 2022 2 hours ago, Brufnus said: Okay, I'll take a look into that... think I have a copy. Thanks! This is from my documentation: There are two save and load formats for the pictures. The first is the MyArt compatible format (Dis/Fix 128) which proved to be too space-consuming for complex fractal pictures. To reduce file sizes I invented a new format, referred to as the Fractals format. MyArt format +----+-+------------+ 0 3 4 15 Bit position Color Length Length describes the number of consecutive pixels of the same color (bits 0-3) starting from the current position in a row. Length cannot grow larger than 512 since the format is line-oriented and stops at the end of every line. This means that there are vacant bit position (e.g. bit number 4) useful for further information: Fractals format (1) +----+-0-+------------+ identical with MyArt format 0 3 4 5 15 (2) +----+-1-+------------+ 0 3 4 5 15 Format (2) is to be interpreted as follows: Bits 0-3 are the color of the pixel at the current position; bits 5-15 inform about the number of nybbles following this word which have to be plotted as consecutive points, each with its own color. One dummy nybble may be added to get to the byte boundary. Example: Instead of 1002 4001 3003 F001 in the MyArt format the Fractals format would read like this: 1806 1433 3F. An algorithm decides which format ((1) or (2)) to take to save as much space as possible. This works out in a considerably reduced file size (for the computer scientists among you: best case appr. 75%, worst case 0%, average case (empirically) appr. 50% reduction compared to MyArt format). Furthermore, picture data are stored in the first sector of the file which format is DIS/FIX 255 (also to be distinguished from the MyArt files). The structure of the first sector is listed below: Byte 0: Backdrop color Byte 1: 'C' or 'M' Bytes 2-33: Color palette Bytes 34-67: xmin,xmax,ymin,ymax in RADIX-100, iter in INTEGER Bytes 68-71: Unused Bytes 72-254: Comments in ASCII The following sectors are filled with picture data in the formats (1) and (2). Quote Link to comment Share on other sites More sharing options...
Brufnus Posted December 11, 2022 Author Share Posted December 11, 2022 8 minutes ago, mizapf said: This is from my documentation: There are two save and load formats for the pictures. The first is the MyArt compatible format (Dis/Fix 128) which proved to be too space-consuming for complex fractal pictures. To reduce file sizes I invented a new format, referred to as the Fractals format. MyArt format +----+-+------------+ 0 3 4 15 Bit position Color Length Length describes the number of consecutive pixels of the same color (bits 0-3) starting from the current position in a row. Length cannot grow larger than 512 since the format is line-oriented and stops at the end of every line. This means that there are vacant bit position (e.g. bit number 4) useful for further information: Fractals format (1) +----+-0-+------------+ identical with MyArt format 0 3 4 5 15 (2) +----+-1-+------------+ 0 3 4 5 15 Format (2) is to be interpreted as follows: Bits 0-3 are the color of the pixel at the current position; bits 5-15 inform about the number of nybbles following this word which have to be plotted as consecutive points, each with its own color. One dummy nybble may be added to get to the byte boundary. Example: Instead of 1002 4001 3003 F001 in the MyArt format the Fractals format would read like this: 1806 1433 3F. An algorithm decides which format ((1) or (2)) to take to save as much space as possible. This works out in a considerably reduced file size (for the computer scientists among you: best case appr. 75%, worst case 0%, average case (empirically) appr. 50% reduction compared to MyArt format). Furthermore, picture data are stored in the first sector of the file which format is DIS/FIX 255 (also to be distinguished from the MyArt files). The structure of the first sector is listed below: Byte 0: Backdrop color Byte 1: 'C' or 'M' Bytes 2-33: Color palette Bytes 34-67: xmin,xmax,ymin,ymax in RADIX-100, iter in INTEGER Bytes 68-71: Unused Bytes 72-254: Comments in ASCII The following sectors are filled with picture data in the formats (1) and (2). Thanks for the info! Quote Link to comment Share on other sites More sharing options...
Brufnus Posted December 11, 2022 Author Share Posted December 11, 2022 35 minutes ago, Ksarul said: There were several formats in use BITD: CSGD (used by a program of the same name), RLE (used by MAXRLE and several others), GRAPHX (used by the program of the same name), TI Artist fonts and instances (used by the program of the same name), PixPro fonts and images (used by the program of the same name), MYART (used by the program of the same name), The Printer's Apprentice/The Geometer's Apprentice pictures/fonts, YAPP images (read GIF and MYART formats, IIRC), and probably one or two others. . . Yeah, but the problem is I don't have these two programs... MAXRLE and Graphx. I do have MyArt, TPA, Pix Pro, YAPP, and TI Artist, though. c",) I didn't recall YAPP could be used with gif, but I'll try that - thx! Quote Link to comment Share on other sites More sharing options...
RickyDean Posted December 11, 2022 Share Posted December 11, 2022 41 minutes ago, Brufnus said: Yeah, but the problem is I don't have these two programs... MAXRLE and Graphx. I do have MyArt, TPA, Pix Pro, YAPP, and TI Artist, though. c",) I didn't recall YAPP could be used with gif, but I'll try that - thx! There was a gif veiwing program too! But for the moment I can't think of the name. Quote Link to comment Share on other sites More sharing options...
+9640News Posted December 12, 2022 Share Posted December 12, 2022 1 hour ago, RickyDean said: There was a gif veiwing program too! But for the moment I can't think of the name. 1 hour ago, RickyDean said: Quote Link to comment Share on other sites More sharing options...
+9640News Posted December 12, 2022 Share Posted December 12, 2022 Picture Transfer 2 Quote Link to comment Share on other sites More sharing options...
Nick99 Posted December 12, 2022 Share Posted December 12, 2022 MaxRLE can be found here, it's a zipped folder containing ti-files format. 1210.zip 2 Quote Link to comment Share on other sites More sharing options...
Brufnus Posted December 12, 2022 Author Share Posted December 12, 2022 13 hours ago, 9640News said: Picture Transfer Thanks, I'll see if I can find that one. c",) Quote Link to comment Share on other sites More sharing options...
Brufnus Posted December 12, 2022 Author Share Posted December 12, 2022 6 hours ago, Nick99 said: MaxRLE can be found here, it's a zipped folder containing ti-files format. 1210.zip 54.43 kB · 0 downloads Great, thanks a lot! Quote Link to comment Share on other sites More sharing options...
