Open Club  ·  64 members
DASM
DOS build?
Andrew Davie
I will note that there was a section of code in main.c that needed to be changed.  Inside the cleanup() function, around line 954, there are some variable definitions that need to be moved to the beginning of the block for the code to compile.
Surprisingly, I believe that was the only issue that needed to be corrected.
