Rom Hunter Posted December 14, 2022 Share Posted December 14, 2022 (edited) Two versions of Dodge 'Em were released by Atari in both PAL and NTSC format. The second version had a (bug?) fix, but to my knowledge nobody has found out what this fix actually does. Can someone with enough coding knowledge find out what exactly has been fixed here? Would very much appreciate it. AFAIK it's the only fixed ROM that still carries a secret. I attached the NTSC version (the original and the fixed one). Cheers, Rom Dodge 'Em - Dodger Cars (Head On) (1980) (Atari, Carla Meninsky - Sears) (CX2637 - 49-75158) ~.bin Dodge 'Em - Dodger Cars (Head On) (1980) (Atari, Carla Meninsky - Sears) (CX2637 - 49-75158) [fixed] ~.bin Edited December 14, 2022 by Rom Hunter Quote Link to comment Share on other sites More sharing options...
Supergun Posted December 15, 2022 Share Posted December 15, 2022 This was one of the first 2600 carts that I “finished” so to speak as it has the “1084 perfect game max score auto end.” Could the bug fix have been a modification that corrected this? (after all it basically just takes away your 3 lives even though you never crash and that’s what ends the game) Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted December 15, 2022 Author Share Posted December 15, 2022 6 hours ago, Supergun said: This was one of the first 2600 carts that I “finished” so to speak as it has the “1084 perfect game max score auto end.” Could the bug fix have been a modification that corrected this? (after all it basically just takes away your 3 lives even though you never crash and that’s what ends the game) There are more than one speculations about what this fix contains, but I need 100% proof. Both versions are quite different, since new code and a new variable was inserted. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 15, 2022 Share Posted December 15, 2022 Anyone else getting "Access denied" errors when trying to download the ROMs? Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted December 15, 2022 Share Posted December 15, 2022 18 minutes ago, Thomas Jentzsch said: Anyone else getting "Access denied" errors when trying to download the ROMs? Me too Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted December 15, 2022 Author Share Posted December 15, 2022 Me too. Weird. Anyway, they are both in my V17 collection (and also both PAL versions). Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 15, 2022 Share Posted December 15, 2022 I took a little bit of extra time to compare both ROMs. The effective differences are quite small, but it takes a time to analyze them. As of now, I found one difference: When the game is over, the right car's color is changed from brown to green in the non-fixed version. Also, when switching B/W mode, the right car does not change color immediately in the fixed version. Both changes seem to go into the wrong direction for a fixed version. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 15, 2022 Share Posted December 15, 2022 13 hours ago, Supergun said: This was one of the first 2600 carts that I “finished” so to speak as it has the “1084 perfect game max score auto end.” Could the bug fix have been a modification that corrected this? (after all it basically just takes away your 3 lives even though you never crash and that’s what ends the game) Nope. Still there. Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted December 15, 2022 Author Share Posted December 15, 2022 2 hours ago, Thomas Jentzsch said: I took a little bit of extra time to compare both ROMs. The effective differences are quite small, but it takes a time to analyze them. As of now, I found one difference: When the game is over, the right car's color is changed from brown to green in the non-fixed version. Also, when switching B/W mode, the right car does not change color immediately in the fixed version. Both changes seem to go into the wrong direction for a fixed version. Interesting. And the bug described on this page is also still there in both versions?http://www.atarimania.com/game-atari-2600-vcs-dodge--em_18170.html Quote Link to comment Share on other sites More sharing options...
JetSetIlly Posted December 15, 2022 Share Posted December 15, 2022 2 hours ago, Thomas Jentzsch said: I took a little bit of extra time to compare both ROMs. The effective differences are quite small, but it takes a time to analyze them. As of now, I found one difference: When the game is over, the right car's color is changed from brown to green in the non-fixed version. Also, when switching B/W mode, the right car does not change color immediately in the fixed version. Both changes seem to go into the wrong direction for a fixed version. That's all I'm seeing too. Gopher2600's comparison tool highlights the difference (Fixed version on the large screen and the original version in the comparison window) How did you spot this Thomas? Are you just inspecting the code or do you have a tool? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 15, 2022 Share Posted December 15, 2022 31 minutes ago, Rom Hunter said: Interesting. And the bug described on this page is also still there in both versions?http://www.atarimania.com/game-atari-2600-vcs-dodge--em_18170.html No idea. How do you trigger that bug? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 15, 2022 Share Posted December 15, 2022 21 minutes ago, JetSetIlly said: How did you spot this Thomas? Are you just inspecting the code or do you have a tool? I disassembled both ROMs using Stella and then manually converted the result into one common source code file (attached). Afterwards, the source code differences became minimal. Using the FIXED assembler switch, you can create both NTSC versions from it. Dodge 'Em.asm Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted December 15, 2022 Author Share Posted December 15, 2022 44 minutes ago, Thomas Jentzsch said: No idea. How do you trigger that bug? I have no idea. It was discovered here: Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted December 15, 2022 Author Share Posted December 15, 2022 (edited) I noticed that the PAL 'fixed' version only shows different colors after the game ends. No differences in B/W mode. Edited December 15, 2022 by Rom Hunter Quote Link to comment Share on other sites More sharing options...
JetSetIlly Posted December 15, 2022 Share Posted December 15, 2022 4 hours ago, Thomas Jentzsch said: Using the FIXED assembler switch, you can create both NTSC versions from it I'm getting the access denied error for this file like the ROMs in the original post. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 15, 2022 Share Posted December 15, 2022 11 minutes ago, JetSetIlly said: I'm getting the access denied error for this file like the ROMs in the original post. @Albert Can you help here? Quote Link to comment Share on other sites More sharing options...
Albert Posted December 15, 2022 Share Posted December 15, 2022 4 minutes ago, Thomas Jentzsch said: @Albert Can you help here? Well, that's something I haven't seen before. I will have to submit a ticket to have Invision look at it. I also cannot download any of the attachments in this thread. ..Al Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 16, 2022 Share Posted December 16, 2022 @Albert I just tried to create a new thread to be able to post my attachment. But I got the same problem there. So it seems the problem is not local. Quote Link to comment Share on other sites More sharing options...
+batari Posted December 26, 2022 Share Posted December 26, 2022 I wonder if one of the versions has a bug I found as a kid. We bought Dodge ‘Em when it was first released. Normally you can move your car one slot while going fast or two when going slow. But as a kid I used to be able to move my car three slots at once occasionally. I have never been able to replicate that trick in the modern day. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 26, 2022 Share Posted December 26, 2022 22 hours ago, batari said: Normally you can move your car one slot while going fast or two when going slow. But as a kid I used to be able to move my car three slots at once occasionally. I have never been able to replicate that trick in the modern day. It would be cool to find out how it worked. I suppose you do not remember any details? Quote Link to comment Share on other sites More sharing options...
+batari Posted December 27, 2022 Share Posted December 27, 2022 3 hours ago, Thomas Jentzsch said: It would be cool to find out how it worked. I suppose you do not remember any details? Yeah, I recall it might only have worked for up or down, and I remember having to hit up or down at exactly the right time, maybe single frame timing. I have never seen any other reports of others experiencing the same thing so I’d wondered if my console had an issue until today when I saw there may be two versions. Or, I wondered if it was an effect that only works on consoles and not emulators, such as if joysticks are only read once a frame and not continuously as they are on A console. Quote Link to comment Share on other sites More sharing options...
Keatah Posted December 27, 2022 Share Posted December 27, 2022 Tried D'L the roms and the filenames were messed up. Quote Link to comment Share on other sites More sharing options...
+batari Posted December 27, 2022 Share Posted December 27, 2022 Downloads may be fixed - they both worked for me? Quote Link to comment Share on other sites More sharing options...
Reality Studio Posted December 27, 2022 Share Posted December 27, 2022 On 12/25/2022 at 4:38 PM, batari said: I wonder if one of the versions has a bug I found as a kid. We bought Dodge ‘Em when it was first released. Normally you can move your car one slot while going fast or two when going slow. But as a kid I used to be able to move my car three slots at once occasionally. I have never been able to replicate that trick in the modern day. I remember that happening as well playing it as a kid but it was rare, never did figure out how to do it. Quote Link to comment Share on other sites More sharing options...
+batari Posted December 27, 2022 Share Posted December 27, 2022 2 hours ago, Reality Studio said: I remember that happening as well playing it as a kid but it was rare, never did figure out how to do it. I am glad to hear someone else experienced this, as this gives more evidence to it being a bug in the game rather than something with my console. I kind of remember bring able to replicate it several times back then. Certainly not every time, but sometimes if I pulled the joystick up or down just right I could do it. Though I do recall pulling "harder" than normal to get it to work, though knowing today that the CX-40 is just a digital stick, this doesn't make much sense. Quote Link to comment Share on other sites More sharing options...
