jchase1970 Posted December 19, 2022 Share Posted December 19, 2022 (edited) I needed binary operations in basic and I created some simple nibble operations routines to go from dec to 4 bits 4 bits to dec dec to hex hex to dec 4 bits to hex hex to 4 bits I reserve variables DEC,HEX$,BITS$ They are string functions but if it is a decimal out come it will be a value not a string All functions are a single line and could be set up as User-Defined Functions in extended basic I have made them all gosubs so I can use them in compiled basic. The code include a example of each function converting 0-15, 0-F, 0000-1111 Not sure if anyone needs these but I have used the binary functions many times including for bitwise operators which I will post next time. I have made good use of them so maybe someone else can too REM SET UP HEX AND BIN STRINGS 1 HEXSET$="0123456789ABCDEF" 2 BINSET$="B0000B0001B0010B0011B0100B0101B0110B0111B1000B1001B1010B1011B1100B1101B1110B1111" REM RESERVE VARIABLEs REM DEC,HEX$,BITS$ REM EXAMPLES 10 CALL CLEAR 20 PRINT"WORKING WITH A NIBBLE(4BITS)" 30 PRINT"SEND 0-15 AND RETURNS HEX$ 0-F" 40 FOR DEC=0 TO 15 50 GOSUB 1000 60 PRINT DEC,HEX$ 70 NEXT DEC 80 GOSUB 900 90 PRINT"SEND HEX$ 0-F AND RETURN 0-15" 100 FOR VALUE=0 TO 15 110 DEC=VALUE 120 GOSUB 1000 130 DEC=0::REM CLEAR DEC VALUE TO KNOW WE ARE RETURNING A VALYE 140 GOSUB 1010 150 PRINT HEX$,DEC 160 NEXT VALUE 170 GOSUB 900 180 PRINT"SEND 0-15 RETURN NIBBLE BIT VALUE" 190 FOR DEC=0 TO 15 200 GOSUB 1020 210 PRINT DEC,BITS$ 220 NEXT DEC 230 GOSUB 900 240 PRINT"SEND NIBBLE BITS$ AND RETURN DEC" 250 FOR VALUE=0 TO 15 260 DEC=VALUE 270 GOSUB 1020::REM GET BITS$ TO SEND 280 DEC=0 ::REM CLEAR DEC TO KNOW WE ARE RETURNING A DEC FOR BITS$ 290 GOSUB 1030 300 PRINT BITS$,DEC 310 NEXT VALUE 320 GOSUB 900 330 PRINT"SEND HEX$ AND GET NIBBLE BITS$" 340 FOR DEC=0 TO 15 350 GOSUB 1000 360 GOSUB 1040 370 PRINT HEX$,BITS$ 380 NEXT DEC 385 GOSUB 900 390 PRINT"SEND NIBBLE BITS$ AND RETURN HEX$ (0-F)" 400 FOR DEC=0 TO 15 410 GOSUB 1020::REM GET BIT FOR DEC 420 GOSUB 1050::REM GET HEX$ FOR BITS$ 430 PRINT BITS$,HEX$ 440 NEXT DEC 450 GOSUB 900 899 END 900 PRINT"PRESS ANY KEY" 910 CALL KEY(0,K,S) 920 IF S=0 THEN 910 930 RETURN REM ALL ROUTINES FOR BIT FUNCTION FOR HEX AND BINARY NUMBERS REM ALL STORED IN STRINGS FOR SAVING SPACE REM ROUTINES WORK ON NIBBLES(4 BITS) REM NO ERROR CHECKING REM RETURN NIBBLE HEX FROM DEC REM SET DEC TO 0-15 NUMBER REM RETURN WILL BE HEX$ 1000 HEX$=SEG$(HEXSET$,DEC+1,1) 1001 RETURN REM RETURN NIBBLE DEC FROM HEX REM SET HEX$ TO HEX VALUE REM RETURN 0-15 IN DEC 1010 DEC=POS(HEXSET$,HEX$,1)-1 1011 RETURN REM RETURN NIBBLE BITS FROM DEC REM SET DEC TO 0-15 REM RETURNS NIBBLE BITS(4 BITS) 1020 BITS$=SEG$(BINSET$,DEC*5+2,4) 1021 RETURN REM RETURN DEC FROM NIBBLE BITS REM SEND BITS$ REM RETURNS DEC 1030 DEC=(POS(BINSET$,BITS$,1)-2)/5 1031 RETURN REM RETURN NIBBLE BITS FROM HEX REM SEND HEX VALUE IN HEX$ REM RETURNS BITS$ 1040 BITS$=SEG$(BINSET$,(POS(HEXSET$,HEX$,1)-1)*5+2,4) 1041 RETURN REM RETURN SINGLE HEX FROM NIBBLE BITS(4 BITS) REM RETURNS 0-F FOR A 4 BIT STRING REM SET BITS$ TO 4 BITS 1050 HEX$=SEG$(HEXSET$,(POS(BINSET$,BITS$,1)-2)/5+1,1) 1051 RETURN Edited December 19, 2022 by jchase1970 4 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 19, 2022 Share Posted December 19, 2022 2 Quote Link to comment Share on other sites More sharing options...
