mr_gw454 Posted December 20, 2022 Share Posted December 20, 2022 Hello everyone, Been spending time trying to find a version of BASIC that will work under T-DOS and not having any luck. They all begin to load and then just lock the system up. My preferred environment is using an IDE controller with the NIAD v2.3 - 100Mb (Dual) CF Card images. I have tried booting T-DOS from FujiNet as well, but same results when trying to load multiple versions of MS BASIC. I believe these BASIC's are compatible with CP/M, however, I don't know of any CP/M version that will work from an IDE HDD system. Thanks for anyone who can help! Quote Link to comment Share on other sites More sharing options...
NIAD Posted December 20, 2022 Share Posted December 20, 2022 I’ll have a look through the NIAD CP/M PD Volumes when I get a chance to see if any of the versions of Basic available on them will work with T-DOS. BTW, have you tried an original version of MS-Basic (that MicroSoft released for CP/M computers) in T-DOS seeing as those that are available on the ADAM were probably configured for ADAM CP/M’s screen formatting… a process that I have never done or had the need to learn until now. Quote Link to comment Share on other sites More sharing options...
mr_gw454 Posted December 20, 2022 Author Share Posted December 20, 2022 33 minutes ago, NIAD said: I’ll have a look through the NIAD CP/M PD Volumes when I get a chance to see if any of the versions of Basic available on them will work with T-DOS. BTW, have you tried an original version of MS-Basic (that MicroSoft released for CP/M computers) in T-DOS seeing as those that are available on the ADAM were probably configured for ADAM CP/M’s screen formatting… a process that I have never done or had the need to learn until now. I have only tried the various BASIC versions on the Adam Archive. Let me see what I can find for a more "generic" version and try it. Please let me know what you find as well. Thank you! Quote Link to comment Share on other sites More sharing options...
mr_gw454 Posted December 20, 2022 Author Share Posted December 20, 2022 I found some generic versions of MS BASIC to try out. What is the best way to get these files onto a CP/M (T-DOS) disk image? I've tried using Adam Image Manager v1.1.1.0 (under Windows 10) but no luck (buggy or perhaps I just don't know how to use it properly). Thanks Quote Link to comment Share on other sites More sharing options...
NIAD Posted December 21, 2022 Share Posted December 21, 2022 5 hours ago, mr_gw454 said: I found some generic versions of MS BASIC… With ADAM Image Manager, I’ve had some issues with transferring files to a CP/M disk image as well. Try transferring the file(s) to an EOS format disk image. Then use the T-DOS utility to convert ADAM EOS files to T-DOS (forget the name) and test. if you have an old PC with a 5 1/4” disk drive, 22Disk is a great DOS utility to transfer the file(s). The EOS counterpart is The ADAM Connection. Also, since you have a FujiNet, couldn’t you use Ncat to enter the website address and download the file directly to the ADAM? It’s supposed to support a lot of web formats such as FTP, etc. Direct connecting the PC to the ADAM via Serial Interface, a Null Modem cable/adapter and telecom software would be another option but I have never done this to offer further help. Quote Link to comment Share on other sites More sharing options...
mr_gw454 Posted December 21, 2022 Author Share Posted December 21, 2022 Quick update: I was able to get ADAM Image Manager to copy a MBASIC.COM file to an existing BLANK CP/M DSK image without issue (this would not work when creating a new DSK image using that function within ADAM Image Manager). T-DOS recognized it as well (great). Unfortunately, the MBASIC.COM binary I found won't load and dies with an error. Not necessarily surprising, but figured I would try (based on your suggestion). It sure looks like MBASIC will need to be updated/patched to work under T-DOS. Quote Link to comment Share on other sites More sharing options...
