Brian's Man Cave Posted December 22, 2022 Share Posted December 22, 2022 Hey, For my venture game I seem to be having an issue with the collision detection. I am using a similar method to the example IntyPak game where it tries to look ahead to see if the path does not contain a graphic. The approach I am using seems to work sometimes. Here is a video showing what is happening, the monster sprite at the bottom goes through the wall : My code is as follows (Showing the going up check) if #r_mon_3 = 0 then 'Going up #col_chk6 = #backtab((X5-3)/8+((y5 % 256)-1)/8*20 - 20) if #col_chk6 = 0 then #mon_mov3 = 1 end if if #mon_mov3 = 1 then if #r_mon_3 = 0 then y5 = y5 - 1:#mon_mov3 = 0:if y5 <= 10 then y5 = 11 end if If anyone can assist, that would be great Thanks, Brian Quote Link to comment Share on other sites More sharing options...
artrag Posted December 22, 2022 Share Posted December 22, 2022 Why this? y5 % 256 y5 is already a byte Quote Link to comment Share on other sites More sharing options...
Brian's Man Cave Posted December 22, 2022 Author Share Posted December 22, 2022 1 hour ago, artrag said: Why this? y5 % 256 y5 is already a byte I am not sure... this was code that I repurposed. Not even sure what that means. Quote Link to comment Share on other sites More sharing options...
artrag Posted December 22, 2022 Share Posted December 22, 2022 Use this for testing up #backtab(X5/8+y5 /8*20 - 20) Use this for testing down #backtab(X5/8+y5 /8*20 + 20) Use this for testing right #backtab(X5/8+y5 /8*20 + 1) Use this fir testing left #backtab(X5/8+y5 /8*20 - 1) Quote Link to comment Share on other sites More sharing options...
Brian's Man Cave Posted December 22, 2022 Author Share Posted December 22, 2022 51 minutes ago, artrag said: Use this for testing up #backtab(X5/8+y5 /8*20 - 20) Use this for testing down #backtab(X5/8+y5 /8*20 + 20) Use this for testing right #backtab(X5/8+y5 /8*20 + 1) Use this fir testing left #backtab(X5/8+y5 /8*20 - 1) Thanks! I think I found the root of my problem, being so close to the edge of the screen. I changed my code around to see if there is a collision of the background or border, then bounce the sprite back if it does. I was looking at the original Venture game, and it appears to do that Quote Link to comment Share on other sites More sharing options...
Brian's Man Cave Posted December 23, 2022 Author Share Posted December 23, 2022 Tried using Background collision and still getting same problem 🥴 Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted December 23, 2022 Share Posted December 23, 2022 (edited) 1 hour ago, Brian's Man Cave said: Tried using Background collision and still getting same problem 🥴 From the video, it looks like it's jumping back two cards. I have a feeling that the problem lies in the code that handles collision with the border, and not the one for moving up. dZ. Edited December 23, 2022 by DZ-Jay Quote Link to comment Share on other sites More sharing options...
Brian's Man Cave Posted December 23, 2022 Author Share Posted December 23, 2022 50 minutes ago, DZ-Jay said: From the video, it looks like it's jumping back two cards. I have a feeling that the problem lies in the code that handles collision with the border, and not the one for moving up. dZ. Your are right, I removed the code that dealt with the border. I was using if y6 >= 86 then y6 = 85 to prevent the sprite from leaving the screen. I think changing the values should solve this... if y6 > 98 then y6 = 98 Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted December 23, 2022 Share Posted December 23, 2022 2 hours ago, Brian's Man Cave said: Your are right, I removed the code that dealt with the border. I was using if y6 >= 86 then y6 = 85 to prevent the sprite from leaving the screen. I think changing the values should solve this... if y6 > 98 then y6 = 98 First, consider the following: The "y" position of a sprite corresponds to the top edge of the sprite. The sprite plane starts 8 pixels above the background plane. The background plane is 12 cards of 8 pixels high, or 96 pixels. So, if you want to test if the sprite touched the bottom border of the screen, you need to compare its "y" position against: screen-offset + (screen-rows * card-height) - sprite-height If the vertical delay is zero (no scrolling), the "screen-offset" is 8. If the sprite is of standard size, the "sprite-height" is 8. Therefore, 8 + ( 12 * 8 ) - 8 = 96 dZ. Quote Link to comment Share on other sites More sharing options...
Brian's Man Cave Posted December 23, 2022 Author Share Posted December 23, 2022 I think I have it working now. But still not the best method, as the sprite never touches the borders of an object. I assume because I am doing a card check that looks 8 pixels up and if there is a graphic, then it won't go up. I tried using Collision detection with the Background that once the sprite hits a background object, then move it the opposite by 2. This worked a bit but created odd results, like sticking to the object or going through it. Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted December 23, 2022 Share Posted December 23, 2022 6 minutes ago, Brian's Man Cave said: I think I have it working now. But still not the best method, as the sprite never touches the borders of an object. I assume because I am doing a card check that looks 8 pixels up and if there is a graphic, then it won't go up. I tried using Collision detection with the Background that once the sprite hits a background object, then move it the opposite by 2. This worked a bit but created odd results, like sticking to the object or going through it. In my own game, what I do is to test the center of the sprite instead of its origin. In other words, I use the center of the sprite (spritex+4; spritey+4) as the reference point to check collisions. I use that position to check the background card. Also, I do not "look ahead." I do the boundary collision check as part of the sprite movement. Essentially, I compute the new position in a temporary variable, check if it is out of bounds, and adjust it if necessary prior to assigning the new value to the sprite object. -dZ. Quote Link to comment Share on other sites More sharing options...
Brian's Man Cave Posted December 23, 2022 Author Share Posted December 23, 2022 5 minutes ago, DZ-Jay said: In my own game, what I do is to test the center of the sprite instead of its origin. In other words, I use the center of the sprite (spritex+4; spritey+4) as the reference point to check collisions. I use that position to check the background card. Also, I do not "look ahead." I do the boundary collision check as part of the sprite movement. Essentially, I compute the new position in a temporary variable, check if it is out of bounds, and adjust it if necessary prior to assigning the new value to the sprite object. -dZ. by boundary collision are you only looking for a x and y, or are you able to look if the card contains a graphic? Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted December 25, 2022 Share Posted December 25, 2022 1 hour ago, Brian's Man Cave said: by boundary collision are you only looking for a x and y, or are you able to look if the card contains a graphic? Both: by boundary I mean to keep the sprite in the "path," as it were. My algorithm goes something like this. Note that this is off the top of my head. ' Get current position x = sprite_posx y = sprite_posy ' Update position based on speed x = x + speedx y = y + speedy ' Check screen boundaries If (x > max_x) Then x = max_x If (y > max_y) Then y = max_y ' Check path boundaries screen_x = (x / 8) + 1 screen_y = (y / 8) + 1 card = BACKTAB(screen_x + (screen_y * 20)) ' Check if card under sprite is empty (not a wall) ' if so, assign new position to sprite, ' otherwise, discard it. If (card AND CS_CARD_DATA_MASK) = 0) Then sprite_posx = x sprite_posy = y End If Quote Link to comment Share on other sites More sharing options...
Brian's Man Cave Posted December 29, 2022 Author Share Posted December 29, 2022 On 12/25/2022 at 5:22 PM, DZ-Jay said: Both: by boundary I mean to keep the sprite in the "path," as it were. My algorithm goes something like this. Note that this is off the top of my head. ' Get current position x = sprite_posx y = sprite_posy ' Update position based on speed x = x + speedx y = y + speedy ' Check screen boundaries If (x > max_x) Then x = max_x If (y > max_y) Then y = max_y ' Check path boundaries screen_x = (x / 8) + 1 screen_y = (y / 8) + 1 card = BACKTAB(screen_x + (screen_y * 20)) ' Check if card under sprite is empty (not a wall) ' if so, assign new position to sprite, ' otherwise, discard it. If (card AND CS_CARD_DATA_MASK) = 0) Then sprite_posx = x sprite_posy = y End If Thanks for clarifying! I assume then if I wanted the sprite to be able to hit the wall but not go through it, I would need to do a sprite collision? Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted December 29, 2022 Share Posted December 29, 2022 28 minutes ago, Brian's Man Cave said: Thanks for clarifying! I assume then if I wanted the sprite to be able to hit the wall but not go through it, I would need to do a sprite collision? Well, to hit a wall and not go through it is quite simple: Update the sprite position in a temporary variable Test to see if it is inside a wall (by converting the sprite's position into a BACKTAB card and checking the graphic under it) If it is inside a wall, adjust the position in the temporary variable to touch the wall -- that is, to be next to the wall rather than inside it You update the sprite position from the temporary variable. That's what I do. -dZ. Quote Link to comment Share on other sites More sharing options...
Mik's Arcade Posted January 18 Share Posted January 18 (edited) wow...despite the issues, this looks good. Hopefully you can work it all out. I've noticed you are working on MANY projects.....how many games have you completed? I've taken a long break from coding but starting lurking on the formums recently. I've have a soft start by working on my latest raspberry pi build but I'm getting the itch to start making a game again. I added my one game to the Intellivision catalog so it's cool to see it there with the real games...lol I still want to go back and further polish it up but have a list of other game I want to try.. I joined a band a couple months ago and have been focusing on music but if that falls apart (it usually does) , I will use the free time to start coding again. Edited January 18 by Mik's Arcade Quote Link to comment Share on other sites More sharing options...
Brian's Man Cave Posted January 21 Author Share Posted January 21 On 1/18/2023 at 7:58 AM, Mik's Arcade said: wow...despite the issues, this looks good. Hopefully you can work it all out. I've noticed you are working on MANY projects.....how many games have you completed? I've taken a long break from coding but starting lurking on the formums recently. I've have a soft start by working on my latest raspberry pi build but I'm getting the itch to start making a game again. I added my one game to the Intellivision catalog so it's cool to see it there with the real games...lol I still want to go back and further polish it up but have a list of other game I want to try.. I joined a band a couple months ago and have been focusing on music but if that falls apart (it usually does) , I will use the free time to start coding again. @Mik's Arcade I know what you mean... I feel like I piled too many projects on my head and not enough time to do all at once 😁 So far I have 2 games that have been released (Keystone Kopps and Fast Food) and a bunch more that are pretty much ready to go and are to be released this year. I also have many that are in production, it's funny but my idea of taking a small break from programming a game is to start another one... although I bet that is more common than I think it is. I think I have about 7 games on the go... most are close to done. 1 Quote Link to comment Share on other sites More sharing options...
Mik's Arcade Posted January 21 Share Posted January 21 6 hours ago, Brian's Man Cave said: @Mik's Arcade I know what you mean... I feel like I piled too many projects on my head and not enough time to do all at once 😁 So far I have 2 games that have been released (Keystone Kopps and Fast Food) and a bunch more that are pretty much ready to go and are to be released this year. I also have many that are in production, it's funny but my idea of taking a small break from programming a game is to start another one... although I bet that is more common than I think it is. I think I have about 7 games on the go... most are close to done. wow. You are a programming beast! 1 Quote Link to comment Share on other sites More sharing options...
