speccery Posted December 22, 2022 Share Posted December 22, 2022 (edited) Updated 2022-12-30: The board works! Only GROM support tested so far. Original message: I have several Raspberry Pi Pico microcontroller boards which I find quite adorable as they are very affordable, in some respects very powerful and in other respects not too much so. Nevertheless I have been playing around with them for a while and trying various things, I built a prototype eurorack synthesiser sequencer with one for example. I've also used them with some boards I bought from Pimoroni to drive VGA screens and DVI monitors. In the last pandemic call which I participated (I guess around a week and a half ago) we also talked about them. Anyway it was high time for me to get one connected to a TI-99/4A. I know that other folks such as @arcadeshopper and @jedimatt42 have also contemplated the same idea. Perhaps someone has already done it, but if so I'm not aware of it and anyway making boards is fun when there is time for it. So I designed a prototype board and just submitted an order for them. I did not quite have enough time to really do this well, so I decided what the heck, let's see what happens with a quick design. It's a bit bulky, and will not fit into an ordinary cartridge case. This of course also means that I have no idea if this is going to work for sure, but of course I have reason to believe it will. It is not too different design-wise from the StrangeCart, except that the microcontroller is different. The RP2040 chip which powers the Raspberry Pi Pico is not 5V tolerant, so I threw in four 74LVC245 buffer chips and some other stuff. Since the board is large, I used some of the extra space to add a prototyping area, and I added breakouts for three SOT-23-5 footprints and two extra SOIC-8 footprints as well. One SOIC-8 footprint, U5, is fully connected to a SPI port and can serve as flash memory expansion or alternatively house a PSRAM (pseudo static RAM chip). As can be seen from the pictures, the buffers are through hole components, the idea being that if I get it to work and others are interested in these, it would be quite easy for people to build these. I don't like through hole resistors or capacitors, so I used 0805 sized surface mount parts for those. In my opinion they are easy to work with. The only slightly challenging part to solder for some could be the 74LVC1G125 buffer I put in to drive the GREADY signal. It can be replaced with a transistor circuit in the prototype area. To get quickly up to speed, I used FlashGROM99 board as the basis. I removed everything else except the outline, regulator and the edge connector and started from there, to have a basis for the design in Kicad. After placing the parts it became obvious it would be hard to make this fit inside a cartridge housing, so I just gave the board more space which made it easy to route the signals to the Raspberry Pi Pico. Now I just need to wait to get the boards and hope for the best during bringup... Edited January 3 by speccery Added pictures of actual board. 22 1 Quote Link to comment Share on other sites More sharing options...
Duewester Posted December 22, 2022 Share Posted December 22, 2022 BRAVO @speccery, I have a wide variety of the 2040 boards (Pico, Pico W, Adafruit Pico Feather, headers on, headers off...) and have been waiting for someone to head up a project like this. I'm not much of a board designer (I mainly use someone elses designs) - why reinvent the wheel - when I can. I think addressing one of these with some Python or Circuit Python on it will be interesting. Way to go. 2 Quote Link to comment Share on other sites More sharing options...
PeteE Posted December 22, 2022 Share Posted December 22, 2022 This is exactly the board I've been dreaming of. I have my own Pico board and some 74LVC245 chips and a breadboard, but you beat me to the punch. I would love to have one of your boards when they become available. 4 Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted December 23, 2022 Share Posted December 23, 2022 (edited) Also very interested in the Pico board. I’m a total hardware noob, but ok with software side of things. This would make a great platform to tinker with. Edited December 23, 2022 by retroclouds 1 Quote Link to comment Share on other sites More sharing options...
Switch1995 Posted December 23, 2022 Share Posted December 23, 2022 If you are exceeding the standard cartridge form factor, perhaps "go nuts" and expand to fit this as a cool retro case: http://www.mainbyte.com/ti99/hardware/nav_expand.html 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 23, 2022 Share Posted December 23, 2022 So what exactly does the board do? 1 Quote Link to comment Share on other sites More sharing options...
Duewester Posted December 23, 2022 Share Posted December 23, 2022 I think it may be possible to think of this as substitute for a programmable ROM? You could program it using python. Surely a library could be developed to address the VDP (Oh wow, what could be done with a F18a!). Is Doom on a Ti-99 in our future? 1 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted December 25, 2022 Share Posted December 25, 2022 On 12/22/2022 at 11:32 AM, speccery said: I have several Raspberry Pi Pico microcontroller boards which I find quite adorable as they are very affordable, in some respects very powerful and in other respects not too much so. Nevertheless I have been playing around with them for a while and trying various things, I built a prototype eurorack synthesiser sequencer with one for example. I've also used them with some boards I bought from Pimoroni to drive VGA screens and DVI monitors. In the last pandemic call which I participated (I guess around a week and a half ago) we also talked about them. Anyway it was high time for me to get one connected to a TI-99/4A. I know that other folks such as @arcadeshopper and @jedimatt42 have also contemplated the same idea. Perhaps someone has already done it, but if so I'm not aware of it and anyway making boards is fun when there is time for it. So I designed a prototype board and just submitted an order for them. I did not quite have enough time to really do this well, so I decided what the heck, let's see what happens with a quick design. It's a bit bulky, and will not fit into an ordinary cartridge case. This of course also means that I have no idea if this is going to work for sure, but of course I have reason to believe it will. It is not too different design-wise from the StrangeCart, except that the microcontroller is different. The RP2040 chip which powers the Raspberry Pi Pico is not 5V tolerant, so I threw in four 74LVC245 buffer chips and some other stuff. Since the board is large, I used some of the extra space to add a prototyping area, and I added breakouts for three SOT-23-5 footprints and two extra SOIC-8 footprints as well. One SOIC-8 footprint, U5, is fully connected to a SPI port and can serve as flash memory expansion or alternatively house a PSRAM (pseudo static RAM chip). As can be seen from the pictures, the buffers are through hole components, the idea being that if I get it to work and others are interested in these, it would be quite easy for people to build these. I don't like through hole resistors or capacitors, so I used 0805 sized surface mount parts for those. In my opinion they are easy to work with. The only slightly challenging part to solder for some could be the 74LVC1G125 buffer I put in to drive the GREADY signal. It can be replaced with a transistor circuit in the prototype area. To get quickly up to speed, I used FlashGROM99 board as the basis. I removed everything else except the outline, regulator and the edge connector and started from there, to have a basis for the design in Kicad. After placing the parts it became obvious it would be hard to make this fit inside a cartridge housing, so I just gave the board more space which made it easy to route the signals to the Raspberry Pi Pico. Now I just need to wait to get the boards and hope for the best during bringup... yes! I knew someone would do this if I kept talking about it keep us updated and I'm definitely interested in these 2 1 Quote Link to comment Share on other sites More sharing options...
speccery Posted December 25, 2022 Author Share Posted December 25, 2022 On 12/22/2022 at 11:01 PM, Duewester said: BRAVO @speccery, I have a wide variety of the 2040 boards (Pico, Pico W, Adafruit Pico Feather, headers on, headers off...) and have been waiting for someone to head up a project like this. I'm not much of a board designer (I mainly use someone elses designs) - why reinvent the wheel - when I can. I think addressing one of these with some Python or Circuit Python on it will be interesting. Way to go. The handling of the IT's bus is likely going to 100% of the attention of one of the CPU cores in the Pico. That code also has to be native code, python code is almost certainly not going to be fast enough to handle the buffer control signals. In the similar StrangeCart the M0 core is spending all its time babysitting the TMS9900 bus, and that is a simpler design which does not require buffers nor bus multiplexing like is needed with the fewer pins of the Pico. Having said that, Python or Circuit Python could still be used, if a native library doing the bus handling is used. I don't know how CircuitPython handles multiple CPU cores, one would need to be reserved to serve cartridge bus. Quote Link to comment Share on other sites More sharing options...
speccery Posted December 25, 2022 Author Share Posted December 25, 2022 On 12/23/2022 at 1:35 AM, PeteE said: This is exactly the board I've been dreaming of. I have my own Pico board and some 74LVC245 chips and a breadboard, but you beat me to the punch. I would love to have one of your boards when they become available. Great! I'd be happy to send you a board, either bare PCB or with SMD components fitted. I need to get one up and running first though (and receive the PCBs, they're still in manufacturing) so that we know these actually work 1 Quote Link to comment Share on other sites More sharing options...
speccery Posted December 25, 2022 Author Share Posted December 25, 2022 On 12/23/2022 at 3:22 PM, Switch1995 said: If you are exceeding the standard cartridge form factor, perhaps "go nuts" and expand to fit this as a cool retro case: http://www.mainbyte.com/ti99/hardware/nav_expand.html That certainly could be an option The choice to make the board big at the prototype phase stems from the desire to use through hole buffer chips and only a 2 layer PCB. Those buffer chips are available in much smaller SMD form factors (I have them also in the TSSOP-20 packaging), but I think that will limit the number of people inclined to building these themselves, and at the prototype phase it would be nice if others can participate. 1 Quote Link to comment Share on other sites More sharing options...
speccery Posted December 25, 2022 Author Share Posted December 25, 2022 On 12/23/2022 at 9:09 PM, Duewester said: I think it may be possible to think of this as substitute for a programmable ROM? You could program it using python. Surely a library could be developed to address the VDP (Oh wow, what could be done with a F18a!). Is Doom on a Ti-99 in our future? The same limits that we have with the StrangeCart would apply - a cartridge cannot access the directly VDP without asking the TMS9900 to do it, which seriously limits the bandwidth. Quote Link to comment Share on other sites More sharing options...
speccery Posted December 30, 2022 Author Share Posted December 30, 2022 (edited) It works! At least to the extent that it emulates GROMs properly. I received the PCBs earlier this week and assembled one of these prototypes. In terms of prototyping process for my latest ideas, I have realised it is faster to just sketch an initial design and get a board produced instead of creating manually wired designs like I used to do. The logic is that this way I get not only prototype boards, but also a schematic to go with it . And once there is a board, making revisions is fast - and this one was no exception. I did not use copper pours here, since cutting traces is easier if there are only traces rather than large chunks of copper. Having said that, nothing needed cutting so far. I adapted my TI-GROMmy2 source files, and got GROM functionality working today on the picocart. Pictures below, and story continues after those. The biggest difference here when comparing to my GROMmy boards is that since the RP2040 chip is not 5V tolerant, level conversion between 3.3V and 5V is required. The 74LVC245 chips take care of that. As anyone playing around '245 would know, these chips have 8 bidirectional buffers which share two control lines: DIR direction (port A to B, or port B to A) and #OE output enable signal. These need to be handled by software; also since the pico doesn't have enough I/O pins to handle all of the necessary signals, I created a shared 8 bit bus which is multiplexed by software. This bus can 1) read low 8 bits of address bus, 2) read high 8 bits of address bus (only 5 available from the edge connector, rest brought to a header), 3) read data bus or 4) write data bus. The output enable signals need to be handled in a proper way for this to work. One of the '245 chips just buffers and handles level conversion of #WE, #GS, #ROMS and DBIN signals. They buffered signals directly connect to four GPIO lines of the RP2040. For this buffer, the direction is fixed and output enable always on. For the RP2040 chip these four signals are permanently inputs and can be read at any time. One '245 connects the TI's data bus to 8 GPIO pins (the board's internal data bus). This buffer needs to be controlled both for direction and enable under software control. One '245 connects the low 8 bits of the address bus to the board's internal data bus. The direction is fixed, but the enable signal is under software control. The last '245 connects the high 8 bits of the address bus to the board's internal data bus. Also here the direction is fixed, but the enable signal is under software control. Thus in total there are three output enable pins to manage, and one direction pin (for the data bus buffer). In addition to controlling the external buffers, also the RP2040 chip's GPIO direction for 8-bit bus needs to be controlled. And this needs to be done in the right order, so that there are no bus collisions between the '245 buffers, the TI's data bus, or between the buffers and the RP2040 chip. It is not hard but care is needed. As I have only so far implemented GROM support, I don't need to worry about the address bus in its entirety yet. In the next step, adding ROM support, I need to manage the address bus fully too. As an example, for GROM read cycles to the data array, the code roughly does this: See if #GS has gone low (GROM cycle). The steps below only apply if #GS has gone low. Check that #WE is high (inactive), i.e. we are dealing with a read cycle. Check the GROM address counter (maintained by software) so that it matches a GROM address the picocart is serving. Turn RP2040 port direction to inputs for the 8 bit board bus. Enable the low address bus '245 buffer Read the low address. Here we need A1 address bit (2nd to LSB) to distinguish between address counter and GROM data array reads. Disable the low address bus '245 buffer Enable data bus '245 buffer, and set its direction towards the TI's data bus. Turn RP2040 port direction to output for the 8 bit board bus. After this step any data presented in the GPIO pins by the RP2040 will be readable by the TMS9900. Set the GPIO pins appropriately for the data being read. After this increment the GROM address counter managed by software. Raise GREADY so that the GROM read cycle can end. Wait for #GS go high, i.e. end of read cycle. Very quickly deactive the '245 driving the cartridge data bus, so that it does not collide with anything else. Turn the RP2040 data bus back into input mode. Return GREADY back to low in anticipation of next GROM cycle. So as can be seen here, there are quite a few opportunities for bugs even if this is a simple sequence... But it works now. Edited January 3 by speccery 11 3 Quote Link to comment Share on other sites More sharing options...
speccery Posted December 31, 2022 Author Share Posted December 31, 2022 (edited) Ran out of time for today, but I have now been able to play TI Invaders with the picocart. So the ROM emulation works there, at least enough for this one game. The time critical code for ROM emulation must be run from RAM, something I saw today. It's not a surprise though, the same is done with the StrangeCart. I've also tested with Parsec, but I get some weird errors with the landscape graphics (the landscape sometimes is flat). It's hardly surprising, since there are so many timing details which might be off. This might relate to the fact that Parsec has more than one GROM, perhaps something is off there. Or someplace else... Edited December 31, 2022 by speccery 8 Quote Link to comment Share on other sites More sharing options...
Duewester Posted December 31, 2022 Share Posted December 31, 2022 Two M0 cores - Two GROMS? 1 Quote Link to comment Share on other sites More sharing options...
speccery Posted January 1 Author Share Posted January 1 15 hours ago, Duewester said: Two M0 cores - Two GROMS? You don't need more than one core to handle GROMs, regardless of the amount. The limiting factor is memory space. In fact due to the existence of the GREADY signal in the cartridge bus, what happens is that the TI-99/4A effectively stops when accessing the GROM. The pico can then on its leisure respond to the bus access, and pulse GREADY suitably (in a time critical section of the code). In practice this happens a lot faster than what a normal GROM could do. The same is not true for cartridge ROM access, they cannot be delayed. That's what actually keeps one of the cores busy. It's also something I didn't write in the previous message - I did modify the code already so that it runs of both cores. One core is busy serving ROM and GROM accesses, while the other at the moment is not doing much at all. 6 Quote Link to comment Share on other sites More sharing options...
Duewester Posted January 1 Share Posted January 1 That's what is so great about these forums, I learn new stuff every time I open it up. 1 Quote Link to comment Share on other sites More sharing options...
PeteE Posted January 2 Share Posted January 2 (edited) @speccery Thanks for the detailed write-up. I was curious if the ROM emulation would be fast enough despite multiplexing the address and data bus. How would you say the Pico board compares to your StrangeCart? I'm assuming the Pico cart could use the same LI instruction method of writing data quickly to the VDP. Maybe the second core could be rendering/generating the LI instructions as the first core serves the bus. This has my project idea neurons tingling. Edited January 2 by PeteE Quote Link to comment Share on other sites More sharing options...
speccery Posted January 3 Author Share Posted January 3 (edited) 12 hours ago, PeteE said: @speccery Thanks for the detailed write-up. I was curious if the ROM emulation would be fast enough despite multiplexing the address and data bus. How would you say the Pico board compares to your StrangeCart? I'm assuming the Pico cart could use the same LI instruction method of writing data quickly to the VDP. Maybe the second core could be rendering/generating the LI instructions as the first core serves the bus. This has my project idea neurons tingling. I think the ROM emulation will be fast enough. After all, the Pico runs at 133MHz which is faster than the 96MHz initial clock speed of the StrangeCart. The strangest thing happened with the strangecart (pun intended): when I initially started to play around with the LPC54114 chip, its max clock speed was 100MHz. Then I noticed something remarkable - the maximum clock speed of the chip had been updated 150 MHz. Indeed when comparing the data sheets, on older data sheets they say it goes at 100 MHz, and newer talk about 150 MHz. Also the official APIs with a new SDK changed to support 150 MHz clock speed, and indeed it runs at that speed just fine. The RP2040 also overclocks extremely well, people routinely run it at 250 MHz. There are YouTube videos showing it running much faster than that as well. So if it comes to it, the clock speed can be just increased. I have already noticed with 133 MHz that when the '245 buffer is enabled, I have to insert NOP instructions before reading the pins for the data to be stable. In other words, this clock speed already is in the same class as the propagation delays of the buffer chips! Comparing the StrangeCart and Picocart - once I get this working - the biggest difference will probably be the type of the second processor core. One of the cores (in both cases a M0 core) will be completely busy serving the bus (and handling the multiplexing in the case of Pico). The "free" core with the Pico is another M0 core, while on the strangecart it is a M4F core. Not only is this core faster on per clock basis, but it also has a hardware floating point unit and other enhancements. My understanding is that the M4F can do a single cycle floating point multiply accumulate, putting the peak performance at 150MHz to 300 MFLOPS. Of course in practice you rarely have code which can optimally use the FPU. Compared to the M0, the M4F is more than an order of magnitude faster when it comes to floating point operations. Yes, the same LI instruction streaming approach will work If you want to participate in the bring up / software development, I can send you a board, just PM me. Edited January 3 by speccery 4 Quote Link to comment Share on other sites More sharing options...
speccery Posted January 3 Author Share Posted January 3 I had a rather embarrassing bug - a left over from an earlier test which restricted GROM space to 8k... After removing that Parsec immediately started to work properly. I also tested Atari's Defender, which is a 8K ROM cartridge (no GROM). I really enjoyed playing Defender after a while So while I was trying to find a problem from the new ROM handling code, the bug actually was in the GROM handling code... Typical. Of course, one thing normally leads to another: in order to test defender, I needed to have a joystick. Defender does not support keyboard play. I wanted to continue to use my setup where I have microcontroller connected to the keyboard connector, and the actual keyboard data is coming from my Mac. Thus I needed to extend both the microcontroller software somewhat and the Mac application for key forwarding to support joystick as well. Same way as @Tursi did with Classic99: tab key is the fire button, and the arrow keys are the directional buttons. I then proceeded to testing with extended basic, but didn't get that to work yet. Extended basic requires ROM paging. It's simple conceptually, but requires support for writes to ROM area. This is something I have done many times over with StrangeCart and other projects. I have some kind of a timing issue. I am trying to avoid going to the basement storage locker to dig up my logic analyser, and resorted the various ad hoc tests, which did not work yet. At least my four channel scope is readily available, need to continue with that. The root issue probably is that the ROM handling loop becomes a bit more complex when it has to differentiate between reads and writes. The conditionals to test for writes probably delay the handling of reads just enough to skew things off. Still, I am happy about this progress - at least I have simultaneous GROM space with multiple GROM "chips" and ROM space reads working for non-banked cartridges. 6 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted January 3 Share Posted January 3 2 hours ago, speccery said: At least my four channel scope is readily available, need to continue with that. An old dual-beam, perhaps? 1 Quote Link to comment Share on other sites More sharing options...
speccery Posted January 14 Author Share Posted January 14 On 1/3/2023 at 11:58 PM, HOME AUTOMATION said: An old dual-beam, perhaps? Unfortunately not, a Rigol DS1054Z, purely digital beast. Affordable. 1 Quote Link to comment Share on other sites More sharing options...
speccery Posted January 14 Author Share Posted January 14 I did a small hardware modification to the picocart. This enables reading of address line 0 of the cartridge port at any time trough one of the I/O pins. That in turn greatly simplifies handling of read cycles. The result is that Extended Basic works and I was even able to run Megademo a few times, although that latter one is not supposed to work. More about that later. Above can be seen the modification. A0 is routed to one of the unused buffers in one of the LVC245 chips. This chip buffers also the other control signals, the output enable is always on and direction is hardwired from the TI to the pico. The buffer signal, at 3.3V level, is connected to GPIO28, previously unused pin. The cartridge port bus has a nasty behaviour pattern: I added labels above to explain the four signals seen on the oscilloscope screen capture. Write handler - a debug output driven by software on the pico. High when the pico is handling a write signal. Read handler - a debug output driven by software on the pico. High when the pico is driving the first byte of a 16-bit read on the bus. #CS - this is the chip select for cartridge port, buffered to 3.3V level. #WE - this is write signal for the cartridge port, buffered to 3.3V level. In this screen capture I have a software version before the modification running. In that version of the software choice of which byte to present to the TI was based on a software delay loop. It will first present the odd byte (LSB=1) and then after a while the even byte (LSB=0). This worked fine for non-banked ROM only cartridges: Invaders, Parsec. But for Extended Basic and many other banked cartridges also writes are done to select the cartridge bank. In this capture we're looking at reads and writes in the cartridge space whenever #CS is low. By now you are probably wondering what is the nasty behaviour I mentioned. Well, if you look at the capture, the chip select signal #CS does not go high just after the write cycle! The write cycle is when we see #WE going low twice in a rapid succession. Instead of temporarily going high, #CS remains low as we proceed from the from the write cycle to the following read cycle! As also can be seen from the capture, this does not seem to be true for consecutive read cycles before the write cycle. With those #CS does go high between the read cycles. Thus for read cycle sequences a simple logic of detecting chip select signal going low is enough to detect the beginning for a read cycle. Remember that with the picocart the address low byte, address high byte and data are all multiplexed. When the picocart is driving data for the TI to read, it cannot monitor changes of the address bus, since that would mean temporarily stopping to drive the data byte to the TI while it would be checking what's going on with the address bus. To describe the behaviour in a bit more detail, it's probably so that if there are only consecutive reads from the cartridge space, #CS would stay low from one read cycle to the next. But in practice nearly all instructions need to touch RAM (mostly scratchpad) between reads, so #CS does go high while non-cartridge areas are being accessed. So all of this is a very long way of saying that we need to be able to detect changes on the address bus to know when we go from one read cycle to the next, or as in the case of this screenshot, we go from a write cycle to a read cycle. The simplest way of doing this is to be able to monitor the LSB of the address bus, as that is high in the beginning of every memory cycle and goes low halfway through a memory cycle. The LSB of the address bus (byte select) is created by the infamous 16-to-8 bit multiplexer on the TI-99/4A, it's not a signal the CPU offers. So I patched that signal, and now the Pico has a better idea what is going on during bus cycles. I was surprised to see that megademo worked at all since it cannot be served from the on-chip SRAM. In order to stabilise timing, I copy the cartridge ROM contents to a 32K SRAM buffer in the pico's on-chip SRAM. But this cannot be done with the megademo, since the pico has "only" just over 256k of SRAM and megademo is bigger than that. So for a cartridge of this size I instead keep it on the off-chip flash on the pico board. But this off-chip flash is a QPI flash chip, meaning it is connected via a 4-bit bus to the pico's CPU. In order to read something from this flash chip, multiple 4-bit bus cycles are needed. Several cycles are first needed to send the address (24 bits) to the flash chip, before the data can be returned, I assume in 32-bit chunks. Flash accesses are cached by a hardware cache on the RP2040 chip and the 4-bit bus runs at a very high frequency, I haven't checked but it might be something like 66MHz or 133MHz. But despite these great hardware features, there is a long latency of reading a new piece of information from the flash chip. I indirectly measured this in the beginning of working with the picocart, and it appears we might be talking something like 500 ns access latency for data which is not in the cache. If the latency is this high, it is significant enough to not be able to serve the TI's bus fast enough. To make understanding of the timing even more complex, both CPU cores can access the off chip flash. If the other core has started to read something from the external flash just before we need another byte for the megademo, the core serving the TI's bus will probably have to wait for two cache line fills from the off-chip flash: one for the first core to satisfy whatever its doing, and then read the cache line containing the data we want. Well this became quite a long story, hopefully it was of interest to the hardware design inclined people here 9 1 Quote Link to comment Share on other sites More sharing options...
speccery Posted Sunday at 11:44 AM Author Share Posted Sunday at 11:44 AM I uploaded the current version of the design to GitHub . Still might lacking some bits and pieces - at least ROM images which I did not want to upload. Feel free to ask or contribute if you want! 5 1 Quote Link to comment Share on other sites More sharing options...
Archimedes5000 Posted Wednesday at 08:18 AM Share Posted Wednesday at 08:18 AM The gerbers are still not in the Github Repository ? Is it possible to get them ? 1 Quote Link to comment Share on other sites More sharing options...
