CDFJ audio/waveforms/envelopes
Andrew Davie
Can someone point me towards some documentation on CDFJ capability (and examples...?) for CDFJ audio streaming.  Particularly the "3 channels" that I've seen alluded to. I have some decent "normal" music playing in my game (envelope-based) but would like to see how CDFJ/streaming could improve this.
  • 2 weeks later...
Hmm, apparently I'd neglected to "follow" the Harmony/Melody club, so was unaware of your request until today. That's been rectified.
We have a simple music, and a simple speech demo, used for testing the CDFJ driver as we made changes to it. I'll track down the most current versions and post them later today.
I also ported the music driver from Stay Frosty 2 to CDFJ for John to use in Mappy. It does on-the-fly manipulation of the waveforms to generate ADSR. I'll track that down and post it as well.
TY.  I have ADSR in my own effort, but it's not using streams; just 60Hz manipulation of AUDV from hardwired ADSR envelopes, using preset AUDC/AUDF.  First time I've ever done anything music related, so I'm on a steep learning curve. It does a surprisingly "good" job of simulating different instruments, though, rudimentary as it is. I'll PM you the latest to have a listen to.  I'm somewhat bad at audio stuff, as my ears are nowhere near even slightly capable of hearing this stuff properly.
CDFJ music demo
cdfj_music.zip
When using Music Mode the CDFJ driver supports playing back 3 voice music similar to the music in Pitfall 2.  Unlike Pitfall 2's square waves only, CDFJ supports custom waveforms for a wider variety of sounds. Examples of this can be heard in Stay Frosty 2 and Mappy. Note: while SF2 uses the DPC+ driver, the ARM enhanced audio is basically the same as when using the CDFJ driver. The music only uses TIA's voice 0, voice 1 is available for your game's sound effects.
In your 6507 code
  • Set the mode to music
  • update AUDV0 once per scanline
  • call your ARM routines with Audio Interrupt turned on
In your ARM code:
  • Copy the waveforms from ROM into Display Data RAM
  • call setWaveform() for each voice
  • call setNote() for each voice
6507 code
When updating SETMODE make sure to use the AUDIOMUSIC constant:
    ldx #AUDIOMUSIC|FASTON
    stx SETMODE
Read from AMPLITUDE and update AUDV0 once per scanline. For best audio quality do the update on the same cycle on every scanline, though this is not always possible.
    lda #AMPLITUDE
    sta AUDV0
NOTE: lda #AMPLITUDE requires SETMODE to have been set with FASTON constant.
WARNING: Do NOT do this, you cannot "read ahead" from AMPLITUDE
    lda #AMPLITUDE
    ... any other 6507 code
    sta AUDV0
When calling your ARM routines you will want to turn on the Audio Interrupt so the updates to AUDV0 will still occur about once per scanline.
    ldx #$FE            ; Run ARM code with digital audio interrupt
    stx CALLFN          ; Call Function
The $FE tells CALLFN to trigger an ARM interrupt about once per scanline. The interrupt routine will calculate the current audio value, then output this sequence to the 6507's bus:
    LDX #value
    STX AUDV0
    NOP
And yes, this means the value in the 6507's X register will no longer be $FE after stx CALLFN has finished executing.
NOTE: Using the audio interrupt will cause about a 10% hit in performance for your C code.
ARM code
For CDFJ driver performance reasons the waveforms must be located in RAM.  The waveforms also need to be aligned on 32 byte boundaries. Search for "Waveform Tables" in cdf1_music.asm for more info and example waveforms.
C function setWaveform(voice, waveform), located in defines_cdfj.h, is used to set the waveform buffer used by each voice.
  • voice = 0 - 2
  • waveform = which 32 byte waveform buffer.  Basically the address offset into Display Data / 32.
C function setNote(voice, frequency), located in defines_cdfj.h, is used to set the frequency of each voice.
  • voice = 0 - 2
  • frequency = frequency of the note. Use getPitch(note) , located in defines_cdfj.h, to calculate the frequency. note = 1-88 where 1 = A0 and 88 = C7
While the waveforms default to 32 bytes in size, you can change that using setWaveSize(voice, size), also located in defines_cdfj.h. I don't believe anybody has used this feature yet.
31 minutes ago, bithopper said:
Couldn't resist playing around with your danube song ...
Actually @cd-w's song. He also used it when experimenting with the DPC's music abilities back in 2010:
I also did a DPC experiment around the same time frame, though mine was with graphics:
Our experiments with the Harmony's support for DPC lead to the creation of DPC+, and eventually CDFJ.
Quote
some experiment with dynamic wave forms for the lead voice.
 Fun!
CDFJ speech demo (sample playback)
cdfj_speech.zip
When using Sample Mode the CDFJ driver supports playing back digital audio samples. Examples of this can be heard in Draconian. The samples only uses TIA's voice 0, voice 1 is available for your game's sound effects. If you're creative, you can still use voice 0 for sound effects whenever a sample is not playing. This also can be heard in Draconian.
In your 6507 code
  • Set the mode to sample
In your ARM code:
  • Start sample
  • Test for end of sample
6507 code
When updating SETMODE make sure to use the AUDIOSAMPLE constant:
    ldx #AUDIOSAMPLE|FASTON
    stx SETMODE
    lda #AMPLITUDE
    sta AUDV0
    lda #AMPLITUDE
    sta AUDV0
The $FE tells CALLFN to trigger an ARM interrupt about once per scanline. The interrupt routine will extract the next sample value, then output this sequence to the 6507's bus:
    LDX #value
    STX AUDV0
    NOP
ARM code
Start sample
To start a sample reset the sample to the beginning, set the playback rate, and set the pointer to the sample's position.
    resetWave(0);
    setNote(0, rate);
    setNote(1, 0);
    setNote(2, 0);
    setSamplePtr(sample);
Stop playback at end of sample
Retrieve getWavePtr(0) to get the current playback position of the sample. Once end has been reached then stop playback (or start a new sample).
  if (sample_size > getWavePtr(0) >> 21)
    // if sample has been fully played stop playback
    setNote(0, 0);
    resetWave(0);
Sample info
Samples are 4 bit values, which are packed 2 per byte.   Upper nybble of the byte is played back before the lower nybble. Max size of the packed sample data is 2K - which is 4096 sample values when the bytes are split into nybbles for playback.
This C utility will convert a raw 8-bit audio file to the packed format. A raw file means there's no header information in the file, just digital samples.
raw_to_dpc.c
I used SOX to create raw 8-bit audio files.
I've tracked down the Stay Frosty 2 music driver I ported for John for Mappy. It's using an old version of the CDF driver, so I'll need to update it to CDFJ before posting it.
In regards to this, the performance hit is less than 10%.  Your custom ARM code is idled once per scanline for this sequence of 6507 opcodes:
  • 0-2 cycles waiting for the currently executing NOP to finish
  • 2 cycles for LDX #value
  • 3 cycles for STX AUDV0
  • 0 cycles for NOP - custom ARM code resumes after putting this NOP on the bus
For 5 - 7 cycles of run time per scanline, which is 6.6% - 9.2%, or a 7.9% performance hit on average.
There's also a slight amount of time spent calculating the audio value, but its minuscule in comparison to the time it takes the 6507 to run those opcodes, so we could say about an 8% hit on average.
