Auto detect PAL vs NTSC
Lisboa2k6
Hi,
I am searching for a routine to auto detect PAL-50 vs NTSC-60 on Atari VCS 2600? Is it possible to read any registers or otherwise detect it from hardware? I was thinking maybe to use collision detection together with timers, but not sure if that is even possible, or if it will make any distinct difference for PAL vs NTSC. Anyone tried to solve this, or ready to take the challenge?
27 minutes ago, Lisboa2k6 said:
Hi,
Not possible without additional hardware I'm afraid.
The PAL 2600's clock runs around 1% slower than NTSC, but you can't measure the difference using the RIOT timers and TIA registers, because they both measure time in clocks, not the actual time.
@SpiceWare has solved this using the additional ARM chip in the Harmony cartridge, see:
He also shared the code here:
Edited by Dionoid
As noted, you can do it in ARM-based games.  Here's my auto-detect code...
#define DETECT_FRAME_COUNT 10
void detectConsoleType() {
    switch (frame) {
    case 0:
        T1TC = 0;
        T1TCR = 1;
        mm_tv_type = TV_TYPE = 0;                // force NTSC frame
        break;
    case DETECT_FRAME_COUNT: {
        int detectedPeriod = T1TC;
        struct fmt {
            int frequency;
            unsigned char format;
        static const struct fmt mapTimeToFormat[] = {
        // Timings from Gopher, 20220827
#define NTSC_70MHZ      (0xB25FCD * DETECT_FRAME_COUNT / 10)
#define PAL_70MHZ       (0xB3856E * DETECT_FRAME_COUNT / 10)
#define SECAM_70MHZ     (( (PAL_70MHZ - NTSC_70MHZ) / 2 + NTSC_70MHZ) * DETECT_FRAME_COUNT / 10)
            { NTSC_70MHZ,   NTSC,    },
            { SECAM_70MHZ,  SECAM,   },
            { PAL_70MHZ,    PAL_60,  },
#define NTSC_60MHZ      (0x98EB2F * DETECT_FRAME_COUNT / 10)
#define PAL_60MHZ       (0x9A0EEF  * DETECT_FRAME_COUNT / 10)
#define SECAM_60MHZ     (( (PAL_60MHZ - NTSC_60MHZ) / 2 + NTSC_60MHZ) * DETECT_FRAME_COUNT / 10)
            { NTSC_60MHZ,   NTSC,    },
            { SECAM_60MHZ,  SECAM,   },
            { PAL_60MHZ,    PAL_60,  },
        int delta = INT_MAX;
        for (unsigned int i = 0; i < sizeof(mapTimeToFormat) / sizeof(struct fmt); i++) {
            int dist = detectedPeriod - mapTimeToFormat[i].frequency;
            if (dist < 0)
                dist = -dist;
            if (dist < delta) {
                delta = dist;
                mm_tv_type = mapTimeToFormat[i].format;
        menuLineTVType = TV_TYPE = mm_tv_type;
        break;
    default:
        break;
    frame++;
Discounting the ARM chip for a moment, let's imagine that somebody wanted to build a cartridge that was adaptive to NTSC/PAL during the early '80s. What would have been the cheapest/easiest method of achieving it at that time?
It would need a clock in order to measure the console against and it would also need a specific "bankswitching" protocol in order to get information from the clock. The protocol wouldn't need to be complex, just a binary response to the question, "has the clock elapsed since the last time [some address] was accessed?"
