SviRu Posted December 31, 2022 Share Posted December 31, 2022 I got this HDD drive with my 520ST. I was wondering does anybody know what is the max capacity for this SCSI controller? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted December 31, 2022 Share Posted December 31, 2022 (edited) The SCSI controller can take 7 drives, the capacity of each drive is limited by TOS as is the number of partitions. It's an AdSCSI Plus ST made by ICD so will work well with ICD Pro Drivers, here's a link to the manual. https://archive.org/details/ICD_AdSCSI_ST_Series_Owners_Manual_ST_Plus_ST_Micro_ST_SCSI_Host_Adaptors_1990 and here's the drivers:- The floppy is set to autoboot the drivers, so if your drive isn't formatted/set to boot, the floppy will install the drivers and tell you what it finds. To help identify what you have we need more (better quality) photo's, maybe the outer case too. It may be it's one that someone made themselves, I certainly did and still have an ICD controller in a custom case and PSU ICDPro.st Edited December 31, 2022 by TGB1718 Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 3, 2023 Author Share Posted January 3, 2023 On 12/31/2022 at 1:54 PM, TGB1718 said: The SCSI controller can take 7 drives, the capacity of each drive is limited by TOS as is the number of partitions. It's an AdSCSI Plus ST made by ICD so will work well with ICD Pro Drivers, here's a link to the manual. https://archive.org/details/ICD_AdSCSI_ST_Series_Owners_Manual_ST_Plus_ST_Micro_ST_SCSI_Host_Adaptors_1990 and here's the drivers:- The floppy is set to autoboot the drivers, so if your drive isn't formatted/set to boot, the floppy will install the drivers and tell you what it finds. To help identify what you have we need more (better quality) photo's, maybe the outer case too. It may be it's one that someone made themselves, I certainly did and still have an ICD controller in a custom case and PSU ICDPro.st 720 kB · 1 download Thank you for reply! This is precious info. There is a sticker in the back. Photo attached :). This drive is autobooting on a 520st that I got with it. Several partitions. I assume this is 105s quantum drive. Around 100mb? I read something about comparator but this is beyond my knowledge for now. Would you say that this piece of "art" is something precious now? Worth keeping? How much can it be worth? I have no idea. Is there a possibility to connect some kind of a SCSI2sd device??? Or that does not make any sense? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 3, 2023 Share Posted January 3, 2023 12 hours ago, SviRu said: Is there a possibility to connect some kind of a SCSI2sd device??? Or that does not make any sense? As it has the second port, you should be able to connect any other 19 pin device to that port SCSI2SD would work, you would need to set the device ID of the second device to be different to the attached device which is normally set to device 0 . Just had a closer look, your device is '0' nice to have the selector external. Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 3, 2023 Author Share Posted January 3, 2023 Just now, TGB1718 said: As it has the second port, you should be able to connect any other 19 pin device to that port SCSI2SD would work, you would need to set the device ID of the second device to be different to the attached device which is normally set to device 0 . Just had a closer look, your device is '0' nice to have the selector external. Yes Thanks! Quote Link to comment Share on other sites More sharing options...
Tillek Posted January 3, 2023 Share Posted January 3, 2023 Yeah, the 105s is a 105mb drive according to the specs I saw on it. Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 3, 2023 Author Share Posted January 3, 2023 1 hour ago, Tillek said: Yeah, the 105s is a 105mb drive according to the specs I saw on it. I have heard that there is no size limit is it true? Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 3, 2023 Share Posted January 3, 2023 I have systems setup with ICD AdSCSI Pro and a SCSI2SD and 32GB microSD cards. HDDriver sees all 32GB. The only limitations are the number and size of the partitions, based on your preferences and TOS ver. Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 3, 2023 Author Share Posted January 3, 2023 (edited) 5 minutes ago, SoulBuster said: I have systems setup with ICD AdSCSI Pro and a SCSI2SD and 32GB microSD cards. HDDriver sees all 32GB. The only limitations are the number and size of the partitions, based on your preferences and TOS ver. This SCSI2SD can be connected to the blue external port? Or do you have to do it internally? (could you point me into the right direction - what kind od SCSI2SD should I buy?) Edited January 3, 2023 by SviRu Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 3, 2023 Share Posted January 3, 2023 46 minutes ago, SviRu said: This SCSI2SD can be connected to the blue external port? No, the blue external port is an old style 50 pin SCSI connector, you would need to connect your new device to the unused 19 pin D connector. Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 3, 2023 Author Share Posted January 3, 2023 6 minutes ago, TGB1718 said: No, the blue external port is an old style 50 pin SCSI connector, you would need to connect your new device to the unused 19 pin D connector. great. can I buy one of those?? https://www.scsi2sd.com/index.php?title=SCSI2SD Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 3, 2023 Share Posted January 3, 2023 The SCSI2SD is mounted inside the case and uses a 50 conductor ribbon cable replacing the hard drive or in addition an existing hard drive. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 3, 2023 Share Posted January 3, 2023 (edited) 9 minutes ago, SviRu said: great. can I buy one of those?? https://www.scsi2sd.com/index.php?title=SCSI2SD Those are internal devices, you see the ribbon cable connected to your existing drive, those connect to that. So your ribbon cable would need another 50 pin IDC connector on it, so you could connect 2 devices. Assuming there's room for another device in the case. There are other SCSI2SD devices that use the 19 pin connector Have a look at this thread:- Edited January 3, 2023 by TGB1718 1 Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 3, 2023 Author Share Posted January 3, 2023 10 minutes ago, TGB1718 said: Those are internal devices, you see the ribbon cable connected to your existing drive, those connect to that. So your ribbon cable would need another 50 pin IDC connector on it, so you could connect 2 devices. Assuming there's room for another device in the case. There are other SCSI2SD devices that use the 19 pin connector Have a look at this thread:- I think I would be fine with getting rid of this old 105mb drive. It is almost more than ancient Prone to failure for sure. So just to be sure. If I get rid of the internal HDD I would be good with one of mentioned SCSI2SD cards from the website? https://www.scsi2sd.com/ Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 3, 2023 Share Posted January 3, 2023 If as it says it's standard SCSI then it looks like it should, but I've never used one, maybe someone here can advise further. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 4, 2023 Share Posted January 4, 2023 I have several of them in operation. 3 are the second drive in Megafile 44s along with the 44meg drives changed out for 200 meg drives. I made a Syquest tower, you can read about it here Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 4, 2023 Author Share Posted January 4, 2023 (edited) 3 minutes ago, SoulBuster said: I have several of them in operation. 3 are the second drive in Megafile 44s along with the 44meg drives changed out for 200 meg drives. I made a Syquest tower, you can read about it here This is great. I will have more noob questions for sure. I was Amiga all the way back then... jumped from 800xl to a500. I want to feel the atari ST magic that passed me by. Edited January 4, 2023 by SviRu 1 Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 16, 2023 Author Share Posted January 16, 2023 On 1/4/2023 at 2:44 PM, SoulBuster said: I have several of them in operation. 3 are the second drive in Megafile 44s along with the 44meg drives changed out for 200 meg drives. I made a Syquest tower, you can read about it here Came into possession of this drive. VORTEX HDPLUS. Does anyone know anything about this? It is MFM drive? I found that it might have ACSI <-> ST506/412 inside? Should I keep it? Considering I already have the AdSCSI Plus ST? Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 16, 2023 Author Share Posted January 16, 2023 Came into possession of this drive. VORTEX HDPLUS. Does anyone know anything about this? It is MFM drive? I found that it might have ACSI <-> ST506/412 inside? Should I keep it? Considering I already have the AdSCSI Plus ST? Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 16, 2023 Share Posted January 16, 2023 That is a 20 meg hd and the adapter is indeed ST506. I have never seen that adapter before. One of the chips looks like it reads "OMTI". It has some historical value. You could change out that adapter for an AdSCSI and make use of the case ... maybe a SCSI2SD, even. Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 16, 2023 Author Share Posted January 16, 2023 2 minutes ago, SoulBuster said: That is a 20 meg hd and the adapter is indeed ST506. I have never seen that adapter before. One of the chips looks like it reads "OMTI". It has some historical value. You could change out that adapter for an AdSCSI and make use of the case ... maybe a SCSI2SD, even. Thanks. It looks ancient. I guess you can only connect MFM HDD drive here. It is built like a tank 4.5kg. Really nice job. I'll try to sell it. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 17, 2023 Share Posted January 17, 2023 If it's like my old setup, you would only need to remove the OMTI card/cables and drive, then use what looks like an ICD interface under the OMTI card with a 50 pin cable directly to a replacement drive. That's what I have now Still have the OMTI card which used to work with an old Syquest 10MB removable drive, but although it runs (quite noisy) and goes through a full format, it doesn't manage to read the disks afterward. Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 17, 2023 Author Share Posted January 17, 2023 1 hour ago, TGB1718 said: If it's like my old setup, you would only need to remove the OMTI card/cables and drive, then use what looks like an ICD interface under the OMTI card with a 50 pin cable directly to a replacement drive. That's what I have now Still have the OMTI card which used to work with an old Syquest 10MB removable drive, but although it runs (quite noisy) and goes through a full format, it doesn't manage to read the disks afterward. So... there is a chance that after connecting 50PIN SCSI drive it might work? I thought this is non expandable solution. Did you have the same? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 17, 2023 Share Posted January 17, 2023 I have the 50 pin internal connector from the IDC interface to a 4.5GB SCSI drive, not using the OMTI card I have removed that. I got the drive on Ebay for about £8.99 including postage, sold as working and it did. I had to used an adaptor, but I had many of those https://www.ebay.co.uk/itm/275605060451? Quote Link to comment Share on other sites More sharing options...
SviRu Posted January 17, 2023 Author Share Posted January 17, 2023 16 minutes ago, TGB1718 said: I have the 50 pin internal connector from the IDC interface to a 4.5GB SCSI drive, not using the OMTI card I have removed that. I got the drive on Ebay for about £8.99 including postage, sold as working and it did. I had to used an adaptor, but I had many of those https://www.ebay.co.uk/itm/275605060451? That is very interesting stuff! Do you by any chance have any photos of the current setup? Interior of the drive? And is there a capacity limit of the disk used? I was thinking about scsi2sd. Quote Link to comment Share on other sites More sharing options...
