+Ksarul Posted August 10, 2022 Share Posted August 10, 2022 Thanks for all the hard work, Albert! 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 10, 2022 Share Posted August 10, 2022 That's right, Albert, you da man. I've got it on my phone and it works. Thank you 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 10, 2022 Share Posted August 10, 2022 Here here! Very un-eventful transition. Congratulations. 1 2 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted August 10, 2022 Share Posted August 10, 2022 (edited) Is it no longer possible to ignore a topic? Edited August 10, 2022 by Asmusr Quote Link to comment Share on other sites More sharing options...
Albert Posted August 10, 2022 Share Posted August 10, 2022 1 minute ago, Asmusr said: Is it no longer possible to ignore a topic? It will be, once I update the third-party plugin for that (it's not a standard feature in the forum). ..Al 2 Quote Link to comment Share on other sites More sharing options...
Albert Posted August 10, 2022 Share Posted August 10, 2022 2 hours ago, Asmusr said: Is it no longer possible to ignore a topic? This has now been re-enabled, you should see the "Ignore this topic" button near the top of the page. ..Al 2 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted August 10, 2022 Share Posted August 10, 2022 @Albert, I'm on my Android phone, can't seem to find the "mark forum as read" button. Quote Link to comment Share on other sites More sharing options...
jrhodes Posted August 10, 2022 Share Posted August 10, 2022 Just got home on my laptop, the "mark forum as read" button is there and working. Its not there that i can find on android though. 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted August 12, 2022 Share Posted August 12, 2022 Where am I? What is the meaning of life? ...Send in the mice!🐭 4 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 13, 2022 Share Posted August 13, 2022 On 8/10/2022 at 4:29 PM, jrhodes said: Just got home on my laptop, the "mark forum as read" button is there and working. Its not there that i can find on android though. A little different now for cell phone users for sure Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted August 13, 2022 Share Posted August 13, 2022 Had my first (suspected) drought-related issue today. Our next-door neighbor rang our doorbell around 7pm to tell us we had water coming out of the ground near the utility area. He proceeded to help me shut off the water at the street, find parts and glue, and repair the broken PVC elbow. Playing in the dirt with the fire ants, mosquitoes, and tree roots is not my idea of a fun Friday evening 2 2 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted August 13, 2022 Share Posted August 13, 2022 1 hour ago, InsaneMultitasker said: Had my first (suspected) drought-related issue today. Our next-door neighbor rang our doorbell around 7pm to tell us we had water coming out of the ground near the utility area. He proceeded to help me shut off the water at the street, find parts and glue, and repair the broken PVC elbow. Playing in the dirt with the fire ants, mosquitoes, and tree roots is not my idea of a fun Friday evening Glad it was a relatively easy fix though. Water pipes can be a serious pain. . . 3 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted August 13, 2022 Share Posted August 13, 2022 1 hour ago, Ksarul said: Glad it was a relatively easy fix though. Water pipes can be a serious pain. . . The break is fixed but I'm going to have a plumber come look at everything tomorrow or Monday. This all may have been a blessing in disguise: I had to hunt down the water softener bypass valve and discovered that the plumber-from-hell installed the system. There are at least three different types of pipes and fittings with various parts and pieces that look to me like odds and ends were stuck together to "make things work". There is visible corrosion of the joints and a trail of at least two feet of corrosion on one pipe where they used a piece of galvanized metal. I just loooove plumbing. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted August 13, 2022 Share Posted August 13, 2022 I have seen similar. There is a variety of PVC that is for high temperature that is purposefully a different diameter (despite what it says on the box) to prevent the parts from being used together. I have also seen galvanized pipe used... Inappropriately... many times. My own bathroom has the latter problem; I have replaced most of it, but not the vertical to the shower. Replacing it would require knocking out the whole goddamn wall in the kitchen, because it was installed by an insane contractor. (To even get to the tub fittings, I had to personally install a plumbing access on said wall. Because said insane contractor just boarded up the wall after installing galvanized pipe, connected to brass tub fittings. "Like a Pro!". Said wall is.. Let's just say it has entirely too much material to mess with. It's about 2 inches thick of plywood underneath drywall, before you even get to the plumbing. There is just the normal plumbing gap space in there to work with for said vertical, and a footing board underneath to prevent just snaking it out to replace it from the crawlspace below. "Very Professional." At some point I will get sufficiently fed up that I will go in there with small rotary tools, and hack the vertical into manageable bits, and remove it piece wise, then replace it with steel braided-mesh reinforced flexible water tubing. That at least will be manageable in the future.) anyhow, I hope you get that all sorted out. 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 13, 2022 Share Posted August 13, 2022 I wanted to put up a really sad 😭 face but I see the update didn't change any of those, but my phone allows it . Quote Link to comment Share on other sites More sharing options...
digdugnate Posted August 15, 2022 Share Posted August 15, 2022 On 8/13/2022 at 2:04 AM, InsaneMultitasker said: The break is fixed but I'm going to have a plumber come look at everything tomorrow or Monday. This all may have been a blessing in disguise: I had to hunt down the water softener bypass valve and discovered that the plumber-from-hell installed the system. There are at least three different types of pipes and fittings with various parts and pieces that look to me like odds and ends were stuck together to "make things work". There is visible corrosion of the joints and a trail of at least two feet of corrosion on one pipe where they used a piece of galvanized metal. I just loooove plumbing. On 8/13/2022 at 4:55 AM, wierd_w said: I have seen similar. There is a variety of PVC that is for high temperature that is purposefully a different diameter (despite what it says on the box) to prevent the parts from being used together. I have also seen galvanized pipe used... Inappropriately... many times. My own bathroom has the latter problem; I have replaced most of it, but not the vertical to the shower. Replacing it would require knocking out the whole goddamn wall in the kitchen, because it was installed by an insane contractor. (To even get to the tub fittings, I had to personally install a plumbing access on said wall. Because said insane contractor just boarded up the wall after installing galvanized pipe, connected to brass tub fittings. "Like a Pro!". Said wall is.. Let's just say it has entirely too much material to mess with. It's about 2 inches thick of plywood underneath drywall, before you even get to the plumbing. There is just the normal plumbing gap space in there to work with for said vertical, and a footing board underneath to prevent just snaking it out to replace it from the crawlspace below. "Very Professional." At some point I will get sufficiently fed up that I will go in there with small rotary tools, and hack the vertical into manageable bits, and remove it piece wise, then replace it with steel braided-mesh reinforced flexible water tubing. That at least will be manageable in the future.) anyhow, I hope you get that all sorted out. I feel everyone's pain with these plumbing woes. We ended up with a crack in our fiberglass shower/tub that rotted out the floor around said tub so now the whole %$&^%$ thing has to be refloored along with a new tub. We're having a heck of a time finding a contractor around here to do the work. Quote Link to comment Share on other sites More sharing options...
jrhodes Posted August 16, 2022 Share Posted August 16, 2022 Semi-colon: U+003B ; Greek question mark: U+037E ; 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 16, 2022 Share Posted August 16, 2022 5 minutes ago, jrhodes said: Semi-colon: U+003B ; Greek question mark: U+037E ; This is how office violence begins. 1 1 3 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted August 16, 2022 Share Posted August 16, 2022 Yet another genius has left the stage ... Wolfgang Petersen died on August 12. Known as a director of - The NeverEnding Story - Das Boot - Enemy Mine - Outbreak - Air Force One - The Perfect Storm - Troy 6 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted August 17, 2022 Share Posted August 17, 2022 1 Quote Link to comment Share on other sites More sharing options...
suberbanator Posted August 17, 2022 Share Posted August 17, 2022 6 hours ago, mizapf said: Yet another genius has left the stage ... Wolfgang Petersen died on August 12. Known as a director of - The NeverEnding Story - Das Boot - Enemy Mine - Outbreak - Air Force One - The Perfect Storm - Troy another TIer gone RIP and thanks for your contributions 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 17, 2022 Share Posted August 17, 2022 5 hours ago, HOME AUTOMATION said: This is what I was doing last year. When I was done, it worked again. This is my Second thing that I had working in 100 years. 1 Quote Link to comment Share on other sites More sharing options...
wierd_w Posted August 18, 2022 Share Posted August 18, 2022 I just had a horrible idea for a new game. "Swimming with sharks: Tropical theme park" Premise: You are a resort hotel owner living in an island economy tropical country (aka, a banana republic). You are exploiting the extremely lax laws of your country, (and battling against graft and corruption to stay in business) to run a novel tourist destination where tourists pay to swim with sharks. Since fish cost lots of money, in order to stay in business you must: 1) decide which tourists to feed to the sharks to keep them healthy and happy. 2) balance the perceived risk tourists have over being eaten against their risk taking impulses 3) maintain a hotel at sufficiently luxurious levels to keep tourists happy without going broke. 4) sustain a large enough school of sharks for tourists to be satisfied 5) deal with the logistics if tourist body size, shark consumption needs/ability, risk of survival and lawsuit/liability, and general sassyness of different kinds of tourist relative to their income 6) bribe the officials to stay in operation. I am not sure I want to dust off my programming abilities to make it, but the idea was too fun not to share. 2 Quote Link to comment Share on other sites More sharing options...
Serafini Lapo Posted August 18, 2022 Share Posted August 18, 2022 Io ne ho una ancora più orrenda!! Un'astrovave che va e spara a qualsiasi cosa. Riempitela di mostri e astronavi, fatelo in stile Parsec e avremo un nuovo shoot'em'up.. vi prego!😉 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 18, 2022 Share Posted August 18, 2022 "Theme Park Tycoon: Shark Island" 2 Quote Link to comment Share on other sites More sharing options...
