Senneman Posted January 5 Share Posted January 5 There are a couple of different ways to connect Videopac G7000 to a monitor. But the easiest way (I think) is just installing an AV mod. As far as I know this is the simplest solution and also easily reversible. I used an Atari 2600 mod kit with a mini jack connection. This one: https://www.thefuturewas8bit.com/shop/atari/deluxe-atari-composite-video-mod.html There are no pictures of the installment, olny the final result. But it's very simple and goes like this: - Unscrew the RF module with a screwdriver and remove the 4 wires by cutting or soldering them out. - Assemble the correct color wires together black -> white (audio) brown -> red (5v) orange -> black (ground) red -> yellow (video) - make sure the mod kit is firmly attached and is equal to the RF cable hole. I taped a few screw washers together and laid them over the plastic so there is a surface for the mod kit to stick to. And added extra reinforcement with a plastic strap. - I had to manipulate the chassis a little. Be careful because the plastic is thinner as you might expect (the advantage is that it is easy to cut) - Put everything back together... enjoy! I really liked the end result. The video quality is pretty good (couldn't captured it well on photo 🙃) and the installation is clean, ALMOST no cut 😏. 2 Quote Link to comment Share on other sites More sharing options...
