Help me with reading data statements
Words Fail
I am trying something with data statements.
Let's say I have this
a=2
level1
 sdata lev1=e
 14,4,15,4,17,4,18,4,11,6,12,6,14,6,15,6,17,6,18,6,20,6,21,6,8,8,9,8,23,8,24,8,23,10,24,10,23,12,24,12,23,14,24,14,11,16,12,16,14,16,15,16,17,16,18,16,20,16,21,16
 end
 return otherbank
level2
 sdata lev2=e
 end
 return otherbank
How can I load sdata with a name?
like this:
t = sread (lev(a))
In the above example I want to read data from the one called lev2.. which is represented by variable a. I can't figure out if that's doable. I get errors when trying to compile.
Edited by Words Fail
Have you read the last paragraph here:
https://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#sdata
Quote
Note that all data tables, sequential or otherwise, must be located in the same bank where they are read. If you try to access data that lives in another bank, there will be no errors, but the data you get will certainly be incorrect. Check out the example program called Sound With Background “Music” to see how sdata can be used for music.
at the risk of being more confusing than helpfull...
  v = sread(dat)
  the sread is sort of like this
  v = dat[pointer]
  pointer = pointer + 1
  data dat
  [data]
end
  except that with the normal data statement pointer is 8 bits
  so you can only address 256 bytes of data
  with the normal data statement dat is the name of the location of the data
  and with sdata the name is the name of a pointer which points to the data
  sdata dat = p
  [data]
end
  is sort of like
  dim dat = q.p
  const datlo = <dat_        ;  the lo byte of dat_
  const dathi = >dat_        ;  the hi byte of dat_
  p = datlo
  q = dathi
  data dat_
  [data]
end
  with the data statement dat is the name for the location of the data
  with the sdata statement dat is the name of a 16 bit pointer (instead of "pointer")
  which is a little like an 8.8 variable except it's 16.
  and that pointer is intialized with the location of the data
  and since it's 16 bits you can reach 65536 bytes of data
  but sread only goes through them sequentially
  however you can change the pointer
  I don't think you even need the sdata statement
  you just need to pass sread a pointer/variable
Edited by bogax
a=2
level1
 sdata lev1=e
 end
 return otherbank
level2
 sdata lev2=e
 end
 return otherbank
like this:
t = sread (lev(a))
The short answer is that sdata doesn't work like that, and you can't do reads in the way you are wanting here. if you reuse the same variables for both sdata blocks like you do here, then you would need to run the initialization before reading from the data blocks so it is reading from the correct one. The more normal case would be to use different variables for different data tables, and then use an if/then or on ... goto to select which one you want to read from.
The long answer is what bogax is saying about sdata being implemented as pointers in assembly "under the hood", which can be useful if you want to learn the assembly side of things.
a has nothing to do with reading data. a is the level number I wish to load.
if a = 1 then goto level1
if a = 2 then goto level2
if a = 3 then goto level3
if a = 4 then goto level4
if a = 5 then goto level5
if a = 6 then goto level6
if a = 7 then goto level7
if a = 8 then goto level8
if a = 9 then goto level9
if a = 10 then goto level10
if a = 11 then goto level11
if a = 12 then goto level12
if a = 13 then goto level13
if a = 14 then goto level14
if a = 15 then goto level15
if a = 16 then goto level16
.. etc
I am trying to shorten that code with a variable.. goto level(a) or something..
So the game starts and a=0 which means to load my title screen.. after you press fire it does a=a+1 so now a=1..
so now that a=1 then it would gosub level(a) or something.. I can't figure out how to get that to work.. so it goes to level(a) in this case level1 which initializes our sdata.
level1
 sdata lev1=e
 end
 return
level2
 sdata lev2=e
 end
 return
etc
  if you just need to change the pointer to point to the level data you could do something like this
  e = levplo[a]
  f = levphi[a]
  t = sread(e)
  data levplo
  <lev1, <lev2, <lev3, etc
end
  data levphi
  >lev1, >lev2, >lev3, etc
end
 data lev1
 end
 data lev2
 end
etc
  e = levplo[a]
  f = levphi[a]
  t = sread(e)
  data levplo
end
  data levphi
end
 data lev1
 end
 data lev2
 end
etc
I have no idea what that means. I have no idea why there are two sets of data levelplo and lev1, and then levphi and lev2. No idea what lev lo and hi are for.
Posted (edited)
49 minutes ago, Karl G said:
Check out "on...goto" and "on...gosub" in the bB manual.
so
on a goto level1 level2 level3 level4
return
is the same as
if a=1 then goto level1
if a=2 then goto level2
if a=3 then goto level3
if a=4 then goto level4
11 minutes ago, Words Fail said:
so
return
is the same as
Close. It starts counting from 0 instead of 1, but otherwise correct.
  normal bB variables are one byte, 8 bits and can have values 0..255
  data addresses go upto 65535 and need two bytes
  sread needs a two byte pointer
  sdata lev1 = e
  defines e as the 16 bit pointer and since e only holds 8 bits the next byte, f holds the other 8 bits
  its kind of like
  dim lev1 = e
  except its 16 bits so maybe it's more like
  dim lev1 = f.e
  sdata also loads the 16 bit address of the data in to the lev1/f.e pointer
  data lev1
  makes lev1 the name for the 16 bit address where the data is
  <lev1 is the lower 8 bits of lev1
  >lev1 is the high 8 bits of lev1
  data levplo
end
  creates a table of the lower 8 bits of the locations of the level data
  e = levplo[a]
  f = levphi[a]
  assign the lower 8 bits to e and the high 8 bits to f
  sread doesn't need you to assign a name for the pointer it just needs the the name of the variable
  that is the low byte of the pointer
  t = sread(e)
Edited by bogax
Posted (edited)
  sdata lev1 = e
  its kind of like
  dim lev1 = e
  dim lev1 = f.e
  data lev1
  data levplo
end
  e = levplo[a]
  f = levphi[a]
  t = sread(e)
I'm gonna take a break from programming for a bit as I don't understand any of that (I should say data statement programming) and just work on my game as is. I mean, my game works without the data statements, I just have a great idea to use data statements and think it'll make something really spectacular here. I have no idea what lo and hi are and I can't get data statements to read anything so far.
All I wanna do is read the first two pieces of sdata. I'll come back for the rest later. So it reads the first 2 numbers and stores them as variables, does something, reads the second two, does something, etc.
The data statement would really offer something special for my game.. it would offer me some professional polish, and I think may allow me to cram more levels in.
    lo and hi are just abbreviations for low and high in the names to remind me what they are
    and help me keep things straight
    all these values are binary and bytes and stuff and we write them as hexadecimal
    suppose it was decimal
    I define a byte as two decimal digits
    normal bB variables are one byte and can only hold values 0..99
    but memory be it RAM or ROM is numbered 0..9999
    suppose I have a data table that starts at location 1234
    12 is the hi byte of location 1234
    34 is the lo byte of location 1234
    suppose I have a table at location 1234
    data data_table
    [some data]
end
    data_table is the name for (location) 1234
    <data_table is 34
    >data_table is 12
    I have a pointer named a it's a bB variable and it only holds values 0..99
    it's a pointer because it holds a number which is the location in memory of
    some data, it points at the data
    suppose a contains 51
    v = data_table[a] takes 1234 (the value of data_table) adds 51 (the contents of a)
    gets the data that's at location 1285 and sticks it in v
    since the pointer a can only hold values up to 99 you can only get to 99 values in the table
    that way
    an sdata statement makes the pointer 4 digits so you can get at 9999 values in a table
    four digits needs 2 bytes
    you specify a variable and the sdata statement assumes that the location after it is
    the second byte (that's the way the processor works) and the name you specify is
    not the name of the location of the table it's the name of the variable that contains
    the location of the data (the 4 digit 2 byte pointer)
    if you specify variable a then the 4 digit 2 byte pointer will be variables b,a
    (the variables are in order in memory b comes after a, f comes after e
    that's just the way bB does things)
    b contains 12, a contains 34
    sread takes what ever variable you pass to it assumes that that is the low byte of a 2 byte pointer
    gets whatever is at the location pointed to by the pointer and increments the pointer
    if the pointer is the variables b,a and contains 1234 it will get what ever is at location 1234
    and increment the pointer to point at 1235 for the next sread
    b will contain 12
    a will contain 35
    the 2 byte pointer is just a couple of variables you can point them at anything you want
    if you want the pointer to point at a paticular table you just set the pointer to the location
    of that table
    with sdata you don't know the location. the name is the name of the pointer that contains the location.
    with a data statement the name is for the location of the table/data and that is 4 digits, 2 bytes
    in a const declaration or in specifying of table data you can choose which byte by prepending
    < for the low byte or > for the high byte
    so if data_table is the name for 1234
    <data_table = 34
    >data_table = 12
    so you can create a couple of tables containing the hi bytes and the lo bytes of the locations
    of your level data tables and use variable a, your level number, to pick the corresponding location out
    of the levplo and levphi tables which contain the locations of you level data tables (lev1, lev2, etc)
    and copy the level data table location to your chosen sread pointer which in this case are variables f,e
    I used abbreviations levplo and levphi for level pointer lo, level pointer hi for the names
    of the tables conaining the lo and hi bytes of the locations of the level data tables
  e = levplo[a]
  f = levphi[a]
  t = sread(e)
  data levplo
end
  data levphi
end
 data lev1
 end
 data lev2
 end
etc
Edited by bogax
In my previous program I had room for 30 levels and ran out space in the graphics bank.
With the new program using data statements I shoved 28 levels in bank5, can fit another 28 or so in bank6 (depends on size of each level). I've got bank2 open for a bit more code, but banks3 and 4 wide open for code.
So depending on how much the rest of my code uses up, I could fit more levels there.
I still don't know how my sread is working.. example:
Based on what level you are on it gosubs the sdata and then it loads the first two pieces of my data.. but as you can see in the example below I am doing an sread(rack1).. and for some reason all the levels load just fine. I was assuming I needed something like
d = sread(level(a)) -- in there a would be the variable for what level you're on. But somehow all the levels load.
 bank 5
  temp1=temp1
levelread
 d = sread(level1): e = sread(level1)
 return otherbank
level1
 sdata level1=b
 14,3,15,3,17,3,18,3,11,5,12,5,14,5,15,5,17,5,18,5,20,5,21,5,8,7,9,7,23,7,24,7,8,9,9,9,23,9,24,9,8,11,9,11,23,11,24,11,8,13,9,13,23,13,24,13,11,15,12,15,14,15,15,15,17,15,18,15,20,15
 21,15,14,17,15,17,17,17,18,17,255
end
 return otherbank
level2
 sdata level2=b
 20,3,21,3,5,5,6,5,17,5,18,5,23,5,24,5,2,7,3,7,8,7,9,7,20,7,21,7,5,9,6,9,14,11,15,11,11,13,12,13,17,13,18,13,26,13,27,13,14,15,15,15,23,15,24,15,29,15,30,15,26,17,27,17,255
end
 return otherbank
the sdata statement sets the pointer
it doesn't matter if two sdata statements use the same variables for the pointer
it will be whatever the last sdata statement executed set it to (unless you change it and of course sread increments it)
Edited by bogax
I tried naming them all "level" and that did not work, so I definitely have to make them all different I guess. But whatever the differences are it doesn't matter. Sort of like how you can't have two of the same subroutine names.
  you can reuse the variable. in this case variable e
  when you use the sdata statement bB makes the name you give it
  an alias for the variable
  lev1 becomes an alias for the variable e like you'd dimmed it
  dim lev1 = e
  bB also declares a lable derived from the sdata name by appending _begin
  so here the lable would be lev1_begin
  if you use the same sdata name twice bB will try to declare the same lable twice with different values
  so yes similar to two subroutines with the same lable
Edited by bogax
