OldAtAtari Posted January 11 Share Posted January 11 (edited) Hello, all. The karri/nop90 template was no longer working, due to some changes in the cc65 tool. I've uploaded a fixed template. It should work immediately with no bugs, assuming that cc65 has already been correctly installed in your environment. If you see any problems with it, please let me know. The directory is here: https://github.com/OldAtAtari/template/ To clone it directly into your Linux workarea: git clone https://github.com/oldatatari/template/ Edited January 18 by OldAtAtari 2 2 Quote Link to comment Share on other sites More sharing options...
pwwit1 Posted January 15 Share Posted January 15 This works perfectly. Thank you! Just in case anyone is trying to setup a Lynx build environment from a clean Ubuntu install, the full steps are: Install requirements: sudo apt-get install git build-essential checkinstall Install the Atari Lynx tools and compiler: git clone https://bitbucket.org/atarilynx/lynx.git cd lynx/tools make -f Makefile.deb Check the installation worked: $ cc65 cc65: No input files Clone OldAtAtari's template: git clone https://github.com/oldatatari/template/ cd template make This should create a 'game.lnx' in the template/game directory! You can run game.lnx with an emulator, or on actual hardware. For an emulator, you can use 'Mednafen', to set it up: sudo apt-get install mednafen Mednafen requires a lynx boot image called 'lynxboot.img', you can find it online easily. Once downloaded, copy 'lynxboot.img' to where Mednafen requires it: cp ~/Downloads/lynxboot.img ~/.mednafen/firmware/ Now you can run your game.lnx with: mednafen game.lnx Hope this helps! 3 1 Quote Link to comment Share on other sites More sharing options...
OldAtAtari Posted January 18 Author Share Posted January 18 On 1/15/2023 at 1:25 AM, pwwit1 said: This works perfectly. Thank you! Just in case anyone is trying to setup a Lynx build environment from a clean Ubuntu install, the full steps are: Install requirements: sudo apt-get install git build-essential checkinstall Install the Atari Lynx tools and compiler: git clone https://bitbucket.org/atarilynx/lynx.git cd lynx/tools make -f Makefile.deb Check the installation worked: $ cc65 cc65: No input files Clone OldAtAtari's template: git clone https://github.com/oldatatari/template/ cd template make This should create a 'game.lnx' in the template/game directory! You can run game.lnx with an emulator, or on actual hardware. For an emulator, you can use 'Mednafen', to set it up: sudo apt-get install mednafen Mednafen requires a lynx boot image called 'lynxboot.img', you can find it online easily. Once downloaded, copy 'lynxboot.img' to where Mednafen requires it: cp ~/Downloads/lynxboot.img ~/.mednafen/firmware/ Now you can run your game.lnx with: mednafen game.lnx Hope this helps! Thank you! I'm so glad you tried it and got it working with no major issues. And your procedure write-up is terrific. I really appreciate that. 1 Quote Link to comment Share on other sites More sharing options...
42bs Posted January 19 Share Posted January 19 For non-linux, a slight change to Makefile.deb .ONESHELL: installcc65: cd cc65 ifeq ($(findstring linux, ($OSTYPE)),linux) sudo checkinstall --pkgname=cc65 \ --pkgversion="14.09" --backup=no \ --deldoc=yes --fstrans=no --default \ make -f make/gcc.mak install sudo ldconfig cp cc65/cc65*.deb -t $(PKGS) else make -f make/gcc.mak install endif Works on MacOS. 3 Quote Link to comment Share on other sites More sharing options...
