Harry Potter Posted January 14 Share Posted January 14 Hi! I'm currently working on updating AdvSkelVic65 and AdvSkel65 and am having problems with the former: the Atari8 cartridge version is moving the screen slightly then displaying a blank screen, and the PET version, when I type a noun, displays garbage on the top-left corner of the screen. I think the former is due to my AtaSimpleIO library and the latter when the ScanWord() routine is called. The following is the code that handles identifying the noun: [code] static unsigned char __fastcall__ ScanWord (char* Dest) { #ifdef __DOFE3__ unsigned char j, c; for (j=0; (c=bankgetbyte((unsigned) Dest+j)) && c == (s[j])/*Sour[j]*/; ++j); // return c==0; #else __asm__ ( "\tjsr\tpopax\n" "\tsta\tptr4\n" "\tstx\tptr4+1\n" "\tldy\t#0\n" "@a01:\n" "\tlda\t(ptr4),y\n" "\tsta\t%v\n" "\tcmp\t(%v),y\n" "\tbne\t@a03\n" "\tlda\t%v\n" "\tbeq\t@a03\n" "\tiny\n" "\tbne\t@a01\n" "@a03:\n", c, s, c ); #endif return c==0; } //Searches for user-inputted item #. //Returns 0xFF if not found. unsigned char __fastcall__ FindItem (void) { #ifdef __DOFE3__ //s=&Input[CurPos]; //char* s; #endif /* Search for item in Input */ for (CurItem=0; CurItem < NumItems; ++CurItem) { #ifdef __DOFE3__ //printh (bankgetword(&Item[CurItem].Name)); printcr (); //s=bankgetword(&Item[CurItem].Name); if (ScanWord(bankgetword(&Item[CurItem].Name))) { ItemPtr=&Item[CurItem]; return CurItem; #else if (ScanWord((ItemPtr=&Item[CurItem])->Name)) { return CurItem; #endif } } /* Search item aliases */ // for (CurItem=0; CurItem < NumItemAliases; ++CurItem) // { // //if (ScanWord((char*)&ItemAlias[CurItem].Name, Input)) { // if (find2(ItemAlias[CurItem].Name))) { // return ItemAlias[CurItem].Num; // } // } /* Search directions */ //++brdrcol; //printc ('a'); for (CurItem = 0; CurItem < 4; ++CurItem) { if (ScanWord((char*)&RoomDir[CurItem])) { return CurItem | 160; } } return -1; } [/code]BTW, __DOFE3__ is for large cartridges and not applicable here. Quote Link to comment Share on other sites More sharing options...
Harry Potter Posted January 14 Author Share Posted January 14 I solved the bug: in a __fastcall__ function, I popped the stack early and exited using a C return command, and, apparently, this caused stack corruption. Now it works. I believe there's a similar bug in AdvSkel65, though. The symptom is, on the 128k Plus4 version, when I type in certain instructions, I get the monitor. This doesn't happen in the 64k version or most other versions. The 128k Plus4 version uses MemBankP4. I attached the crt0.s file I'm using and some functions responsible for parsing user input. plus4a_crt0_bank1.s advskel65 verbs_nouns.txt Quote Link to comment Share on other sites More sharing options...
